5VDC Boost Converter - Page 2 — Parallax Forums
2»
    edited 2014-07-16 09:39
    Duane Degn wrote: »
    The USB connector was really easy to remove on one of mine since only the tabs to the metal housing had been soldered. The other four pins were still factory fresh. Thoughtful chaps those guys assembling the board.
    It's almost like they knew you were gonna hack it...
    That's a first!
  • NWCCTVNWCCTV Posts: 3,629
    edited 2014-07-16 21:32
    Under a buck!!! So the only way to use these is to waste a USB cable?
    edited 2014-07-16 21:44
    NWCCTV wrote: »
    I think you ought to read post #29 again. Erco didn't cut a USB cable, he cut the board after removing the USB connector.
    I also removed the USB connector from one of my boards which was easier than normal since only two of the six places which would normally be soldered had been soldered.
    edited 2014-07-16 22:06
    In the thread about aluminum wallets, I found a photo of my boost board with the USB connector removed.
    Here's a close up of the boost board (from a photo found on my hard drive).
    I was using a piece of orange electrical tape on the back of the board to prevent shorts.
    I ended up not needing 5V in the wallet project so the board it waiting to be used in another project.
    647 x 352 - 122K
    edited 2015-04-14 21:03
    I just ordered 4 of these adjustable DC-DC booster modules from ICstation, still having their Easter sale a bit longer: http://www.icstation.com/icstation-mt3608-step-booster-power-apply-module-p-3448.html
    $1.39 with free shipping and Paypal makes it cheaper and as convenient as EBay. 2 amps/28V out and 93% efficiency? We shall see.
    Anyone else try these? CuriousOne probably beat me to it already... :)
    edited 2015-04-16 16:06
    Well, they're still listing it at $1.39 but when added to the cart they charge $1.85. The price isn't a problem, but the principle is.
    It's probably because I didn't enter the discount code "erco"
    edited 2015-04-16 17:52
    Hmmm, I got my four for $1.39 each...
    edited 2015-04-16 22:33
    These are also great:
    http://www.ebay.com/itm/400818396234
    For low price you get quite sturdy enclosure, which has enough free space to add your parts too, has effective boost circuitry, charger, and battery protection. Output current is around 950mA, above it starts to sag considerably.
    edited 2015-04-17 14:41
    They fixed the problem and my six are on the way. BTW, these really look great!
    edited 2015-04-17 17:39
    I have used the ones from eBay and they work great.
    edited 2015-05-19 14:32
    @erco: I would be curious to learn of your experience with this board. The first two I tested do not seem to work. I used a known good Li-ion cell for input, but no matter how much spinning of the pot, in both directions, all that appeared on the output was basically the same voltage that was going in. I've been pretty darn happy with ICStation up to now so I'm allowing for the possibility I'm doing something wrong. But it's a very simple board and I handled both of them quite carefully.
    edited 2015-05-20 05:38
    Thanks for reminding. They arrived but I haven't tried yet. Will test soon.
    edited 2015-05-21 10:34
    Works for me, User Name. A quick test gave me 27V out under load, 2-3 amps in from small Li-Ion battery. I just ordered 3 more. Their last 3 in stock for $1.85. Sorry, never trust a hoarder.
    WRT output voltage not changing as you twirled the pot, it's non-linear. Mine sat at 4.02V and it didn't change for a long while until I spun it pretty far counterclockwise. Suggest you try yours again, you might not have twirled enough. When in doubt, TWIRL.
    edited 2015-05-21 11:50
    Works for me...
    Well... Saw your post and immediately reassembled the necessary stuff. Cranked CCW about ten times more than made sense to my lame brain and, sure enough, the output started going up (and not on account of triboelectricity, either). Thank you, erco-man!
    (Once again I gave up too soon on a situation involving DC-to-DC converters from China. And once again erco saved the day. It is high time I made out another check for the twins' education fund.)
    edited 2015-05-21 13:07
    Excellent news. These are nice little boards, I only wish they had an LED on indicator. Mo' LEDs always be bettah!
    edited 2015-05-21 21:14
    I'm no competitor in getting low prices for these, since I don't use them. Tried to use them several times, never satisfied with voltage stability, input ranges, current handling. So, I'm going DIY way for them. I'm using various ICs, and one of my favorite (a bit expensive, but still OK), is LT1513 IC:
    1. It delivers constant output even when input voltage is lower or higher than output voltage (SEPIC)
    2. Operates from 1.8v to 24v, this means that my gadgets can be run from almost any hobby level power source.
    3. Has ability to set the current limit, so in case of failure, I'm sure that there will be no magic smoke from my devices
    4. Is enclosed in TO-220 case, can be soldered by hand, no fancy tooling or skills required
  • erco wrote: »
    thanks for this advice, i just received 4 of them and none seemed to work - until i twirled madly ccw as you suggested, then hey presto!
  • tonyp12tonyp12 Posts: 1,951
    edited 2016-09-20 16:49
  • Wish I had known about these. I bought a similar item from Sparkfun for $14.95:
    https://www.sparkfun.com/products/10255
    It does work great for powering an RC receiver and a couple servos from a 3.7V LiPo -- for only 1400% more!
