How critical is the resistance value of the ActivityBot 20k ohm p14, P15 resistors?
That's the question. As I solder overlay boards for my ActivityBot, I will need 2 for each board. I have a number of resistor assortments but none have 20k ohm resistors. So what range of resistance would be acceptable?
Tom
Tom
Thanks.
I just mounted my first overlay board on an ActivityBoard. I bought the tilt tones kit during the last sale (primarily to get an extra ActivityBoard), and soldered the tilt tones parts to an overlay board.
When I mounted it, I see that there is enough space between the ABoard breadboard and the under side of the overlay board that the P14/P15 resistors will fit.
So for overlay boards that I build for the ABot, if I cut the power bus header and the Prop pins header 2 pins short each and don't have pins in the P14/P15 and left most 3.3v positions, I can just keep the existing P14/P15 resistors on my ABot in place.
Tom
