Can the EasyVR Recognize a dog bark?
Is there any way to make the EasyVR pick up on a dog bark and have it perform a task? If not, what would be a good alternative? I want to have my back door open and close when my dog barks. He has a very specific bark when he wants to go out or come back in. RFID had crossed my mind but the readers Parallax sells (both of which I own) have a very limited distance.
It would probably be easiest to check with the EasyVR connected to a PC running the GUI program. The trick will be getting the dog to bark on cue. You may need to record the dog's bark and use the recording to train the EasyVR.
I'd give this about a 20% chance of working. I hope you let us know if it works or not.
If the EasyVR won's accept the bark as a word, you could try Phil's speech recognition software for the Propeller. I'm pretty sure I have a link to Phil's thread on the subject in my index but I'm not sure where it is in the index.
http://www.ebay.com/sch/i.html?_odkw=voice+recognition+module&_sop=15&_from=R40%7CR40&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.TRS0&_nkw=voice+recognition+module&_sacat=0
I suspect that you might need to DIY an audio FFT profile for your mutt and then use that same sampling ability to key into his identity. It isn't exactly voice recognition as you are not sorting out different words. But you are profiling his voice print to only him. If you need more than one option -- maybe arf arf can be seperated from a single arf, and so on.
