Part No. For Switch — Parallax Forums
Part No. For Switch
idbruceidbruce Posts: 6,197
edited 2015-04-13 02:23 in General Discussion
I have a Propeller Proto Board with a defective off-on-on switch that I would like to replace. Do anyone know the proper part to replace this? I already have the board all soldered up.
    edited 2015-04-11 08:19
    I'm pretty sure that switch is not listed as a separate part on their web site so you may need to get it through tech support. Short of knowing the vendor and switch part number finding a replacement any other way will be very difficult.
    edited 2015-04-11 09:26
    If, as I suspect, it's the same switch that's used on the Activity Board, the DigiKey part number is CKN9543-ND.
  • idbruceidbruce Posts: 6,197
    edited 2015-04-11 10:45
    Phil and kwinn
    I had an old board laying around, but I think it went in the garbage.
    Bruce
    edited 2015-04-11 21:24
    Bruce,
    I've got some extras. Email me your mailing address, and I'll send you a couple.
    edited 2015-04-11 21:50
    Sorry for the inconvenience, Bruce. Thanks for helping him out, Phil.
    To all others who encounter this thread: we've found a much better switch and it's being used on our newest builds. If anybody has a switch break I'll be happy to replace the board.
    edited 2015-04-11 23:45
    @Phil
    I definitely appreciate the offer, but it is not an absolute necessity, because this switch will eventually be bypassed anyhow, and it still works, but it is a bit finicky. When I am finished with the board, the switch will remain in the 5V position, so I could simply solder a jumper wire in place of the switch.
    Like I said, thanks for the offer.
    By the way, grammatical error in Post #1 :)
    Do anyone know
    I was going to correct it, but... :)
    @Ken
    It is not a big deal, at least not on my end. I remember Parallax was having trouble with one particular switch and I imagine it was this one. Sorry about not mentioning the replacement warranty that you offer, I should have said something about it, but I did not want anyone to think that I wanted the board replaced, and it would have been long winded.
  • GenetixGenetix Posts: 1,775
    Bruce, considering that you often change things just take up Ken's offer so it doesn't become a potential issue later.
