Parallax SD products
idbruce
Here is the scenario.....
If I visit this link: https://www.parallax.com/product/32313 and scroll to the bottom of the page, there is the pic shown below, with no active link. Upon further investigation, I arrive at this page: https://www.parallax.com/product/32312, which states the product is not available. Then if I go to documentation for that product, I end up with a PDF that has a schematic for this product. Now I am wondering if Parallax had a problem with this product and if the schematic is a good working design, and if so, what would be the value for the various resistors?
Bruce, parts of the Parallax website aren't up to date.
Is this what you were looking for?
https://www.parallax.com/product/452-10017
@Genetix
I actually have a couple microSD holders on hand, but I really wish I had one of those adapters shown in Post #1.
If you can wait a few weeks, you could purchase one (or more) of these little boards from ICStation.
I'm using one with my CNC router project and it seems to work fine.
For $1.69 it seems like a good deal. I'm going to order a couple more myself.
If I get one, is there anything that I should do special in the the wiring to get it working?
You can see the resistors in pict 2 .The resistors 103 resistors (10K ohm)
I used jumper wires between the uSD card holder and the QuickStart board.
MISO on the adapter corresponds to DO in the SD object.
MOSI corresponds to DI.
I kind of wish the header pins on the adapter were pointed down rather than up but it's not a big deal and it would be easy to change.
Re: Post #5. April is a busy time for me, either visiting family or attending conferences. New York was lovely on April 2nd. Thanks for noticing.
I'm pretty sure I've used my board from SparkFun without any pull-up resistors at all. Kye mentioned many SD cards have internal pull-ups.
I'm not a fan of SparkFun's uSD board. There isn't a way to mount the board inside an enclosure while maintaining access to the SD card.
I like the $1.69 board from ICStation a lot more than the $9.95 SparkFun board.
It is good to know that you are well and enjoying yourself, instead of going through turmoil and troubles. Last time I asked someone about their reduction in forum participation, they told me some horrible news. I sure hope their situation has improved, but I doubt it.
Thanks for the tip.... It is always nice to have various options.
The fact that the card has an internal pullup on CS\ can be used to detect whether or not a card is present. Bring CS\ pin low briefly then read it a millisecond or two later. If it is high, the card is present. That won't work of course if you add an external pullup on CS\.
