Parallax SD products — Parallax Forums
idbruceidbruce Posts: 6,197
edited 2015-04-12 11:04 in General Discussion
Here is the scenario.....
If I visit this link: https://www.parallax.com/product/32313 and scroll to the bottom of the page, there is the pic shown below, with no active link. Upon further investigation, I arrive at this page: https://www.parallax.com/product/32312, which states the product is not available. Then if I go to documentation for that product, I end up with a PDF that has a schematic for this product. Now I am wondering if Parallax had a problem with this product and if the schematic is a good working design, and if so, what would be the value for the various resistors?
215 x 259 - 10K
    edited 2015-04-10 09:57
    Parallax has been building this into their products now with the Activity Board, Board of Education, QuickStart Human Interface Board, Memory Board, etc. all having SD cards. The Project Board has the pads and traces for an SD card option. This adapter is really for older projects or breadboard-based projects where this form-factor is useful. I've used 10K resistors for the pullups. I'm sure anything from around 3.3K to over 20K would likely work with the usual tradeoffs of power consumption vs noise tolerance and lead length.
  • GenetixGenetix Posts: 1,777
    edited 2015-04-10 10:10
    Mike, the development boards use MicroSD, which are smaller than SD.
    Bruce, parts of the Parallax website aren't up to date.
    Is this what you were looking for?
    https://www.parallax.com/product/452-10017
    edited 2015-04-10 10:20
    Genetix ... Sorry, I was being lazy leaving out the "Micro"
  • idbruceidbruce Posts: 6,197
    edited 2015-04-10 11:10
    Thanks Mike, I appreciate your detailed answer. I don't see you posting much lately. I certainly hope all is well with you.
    @Genetix
    I actually have a couple microSD holders on hand, but I really wish I had one of those adapters shown in Post #1.
    edited 2015-04-10 11:17
    If anyone has a micro-SD Card Adapter (Product ID: 32312) that they do not need, I will happily swap them an SD Card Adapter (Product ID: 32313) for it.
    edited 2015-04-10 11:26
    Bruce,
    If you can wait a few weeks, you could purchase one (or more) of these little boards from ICStation.
    I'm using one with my CNC router project and it seems to work fine.
    For $1.69 it seems like a good deal. I'm going to order a couple more myself.
    edited 2015-04-10 11:43
    Thanks for the heads-up Duane
    If I get one, is there anything that I should do special in the the wiring to get it working?
    edited 2015-04-10 12:22
    Resistor value:
    You can see the resistors in pict 2 .The resistors 103 resistors (10K ohm)
    edited 2015-04-10 12:24
    idbruce wrote: »
    I used jumper wires between the uSD card holder and the QuickStart board.
    MISO on the adapter corresponds to DO in the SD object.
    MOSI corresponds to DI.
    I kind of wish the header pins on the adapter were pointed down rather than up but it's not a big deal and it would be easy to change.
    edited 2015-04-10 13:20
    Thanks Duane
    edited 2015-04-10 21:04
    SparkFun sells a MicroSD card socket on a breakout board (https://www.sparkfun.com/products/544) but without the resistors. I've taken 1/10W 10K resistors and wrapped them around the "back end" of soldered header pins and soldered them in place on the back of the breakout board ... Soldered the other ends together ... left one of the wires long enough to bend it so it goes to the Vcc pin. Takes a few minutes to do and works great if you can't get hold of something similar with built-in resistors.
    Re: Post #5. April is a busy time for me, either visiting family or attending conferences. New York was lovely on April 2nd. Thanks for noticing.
    edited 2015-04-10 22:10
    Mike Green wrote: »
    I'm pretty sure I've used my board from SparkFun without any pull-up resistors at all. Kye mentioned many SD cards have internal pull-ups.
    I'm not a fan of SparkFun's uSD board. There isn't a way to mount the board inside an enclosure while maintaining access to the SD card.
    I like the $1.69 board from ICStation a lot more than the $9.95 SparkFun board.
    edited 2015-04-10 22:21
    It is good to know that you are well and enjoying yourself, instead of going through turmoil and troubles. Last time I asked someone about their reduction in forum participation, they told me some horrible news. I sure hope their situation has improved, but I doubt it.
    Thanks for the tip.... It is always nice to have various options.
    edited 2015-04-12 09:54
    SD cards have an internal pullup resistor on the CS\ chip select line only, but not on the data or clock lines. External pullups on those lines are not necessary for operation of the card. However, it can be useful to add those resistors externally so that the Prop pins will not float when the card is removed.
    The fact that the card has an internal pullup on CS\ can be used to detect whether or not a card is present. Bring CS\ pin low briefly then read it a millisecond or two later. If it is high, the card is present. That won't work of course if you add an external pullup on CS\.
    Thanks for the info Tracy, that is nice to to know.
