Why C is better than BASIC, can anyone provide live example? - Page 9 — Parallax Forums
16791112
  • 4x5n4x5n Posts: 746
    edited 2015-04-05 04:50
    Genetix wrote: »
    BASIC is a lot easier for a non-programmer to read. (Excluding that MS stuff!)
    C is a much more powerful language but for what the average person will do BASIC gets the job done.
    C is also a lot more abstract and it lacks many of the convenience and safety features that BASIC has such as error checking and garbage collection.
    Careful where you stick that C pointer or you might crash your system.
    Loopy, I found Spin to very similar with PBASIC though there are some differences. I learned PASCAL after having learned BASIC and it made learning C a lot easier.
    I disagree that basic is automatically easier to read than C. For someone that has learned even very basic (sorry for the pun) syntax of both languages is it really easier to read:
    10 print "howdy world
    Than:
    int main(){
    puts ("howdy world");
    Once you get past trivial programs all the need gotos needed to make basic works makes it nearly unreadable.
    edited 2015-04-05 05:00
    CuriousOne,
    As you are curious:
    1. Why it has : in front of =
    Because in mathematics "=" means "Exactly the same amount or value". It's a statement of equality. It is not an assignment. For example "a + b = c" does not assign c to a + b. How could it?
    Better to use some other symbol for assignment to avoid confusion. Which many languages do. Of course C does it backwards, where "=" is the assignment and "==" is the test for equality.
    Anyone who has ever done the slightest maths in school will be happy with this idea.
    2. Why some lines end with ;, while others - not
    Good question. Every language has it's weirdness. ALGOL is "free form" you don't have to put every statement on a new line. So you need some kind of separator. No worse than comas, semicolons, colons, and full stops in English.
    3. "for p := 1 step 1 until n do" - what this line does, it is not possible to understand from human knowing of english
    language, while basic is much closer to "real" language in such constructions.
    How can you say so? How compare and contrast:
    BASIC:
    FOR p = 3 TO 9 STEP 3
    ALGOL:
    for p := 3 step 3 until 9 do
    Almost identical. Both equally readable or otherwise as some kind of "real" English. Where do you think BASIC got the idea from?
    I might suggest that given a high school understanding of "=" the BASIC version is unintelligible. One has to be told what it does in both BASIC and ALGOL.
    edited 2015-04-05 07:05
    I am unware of any English usage which would have that "do" hanging off the end, "until" seems clunky and arbitrary compared to the more direct "to," and putting the step first kind of works except that it is an adjective showing up where we really expect a verb. It might make more sense if you speak German where always at the end the verb you put.
  • David BetzDavid Betz Posts: 14,526
    edited 2015-04-05 07:12
    localroger wrote: »
    Well, there is no verb at all in the Basic version.
    edited 2015-04-05 07:21
    If look closer on my example, you can see that I'm asking about
    not
    To say in different way, why algol needs :=, when basic uses only =
    edited 2015-04-05 07:25
    And for the readability, here's COBOL code example
    MOVE WS-REL-ADDR TO WS-RELATIVE-KEY.
            READ IN-MASTER.
            EVALUATE WS-FILE-STATUS
               WHEN '00'
                  PERFORM 300-SUCCESSFUL-READ
               WHEN '23'
                  PERFORM 400-RECORD-SLOT-IS-EMPTY
               WHEN '92'
                  DISPLAY 'FILE NOT OPEN'
               WHEN OTHER
                  DISPLAY 'UNEXPECTED FILE ERROR: ' WS-FILE-STATUS
            END-EVALUATE.
    Clean, human readable code.
    edited 2015-04-05 07:28
    CuriousOne wrote: »
            READ IN-MASTER.
               WHEN '00'
               WHEN '23'
               WHEN '92'
               WHEN OTHER
            END-EVALUATE.
    Excellent. I admit that COBOL is better than C as is BASIC. Why don't you immediately start work on a COBOL compiler for the Propeller? There is already PropBasic if you want to use BASIC.
    edited 2015-04-05 07:29
    localroger,
    How do you do?
    That "do" is not "hanging off the end", it's part of a larger structure. The for loop:
    can be though of as saying:
    For integer values of p starting from 3, in increments of 3, up until and including 9 this is what I want you to do:
    something with p,
    something else with p.
    Honestly it's such a stylized version of English like symbols it does not make much difference.
    edited 2015-04-05 07:39
    CuriousOne,
    I thought I explained that above already.
    In maths "=" is an expression of equivalence, it is not an assignment. Both BASIC can C are wrong to use "=" to mean assignment. As any high school maths student might agree. Many other languages do the correct thing and use a different symbols for assignment, Pascal, Ada, Spin, Algol...
    ":" is used in English to introduce a list. I believe that is what it is doing there in ALGOL. When it's not forming part of an assignment operator.
    What the problem with the "not"?
    edited 2015-04-05 07:47
    CuriousOne,
    COBOL...Clean, human readable code.
    Looks like gibberish to me. What does it mean "WS-FILE-STATUS"? Is that like, WS minus FILE minus STATUS?
    COBOL looks nice until you try to write some interesting algorithms with it, say a binary tree search. That is a very short, simple and clear thing in most languages. I would love to see your example of it in COBOL.
    There is a reason they say there are billions of lines of code in existence, if they had used a more reasonably concise language it would probably only be a hundred thousand or so :)
    edited 2015-04-05 08:16
    This was just a fragment of code. If you're REALLY interested, here's complete link:
    http://web.cse.ohio-state.edu/~sgomori/314/algs.html#tblseek
    edited 2015-04-05 08:29
    Been there, seen that. There are no interesting little algorithms like binary tree search there.
    Anyway let's forget all these primitive, archaic, simple minded languages like BASIC and C. Why doesn't the Propeller have a language designed around the concepts of parallel execution, isolated processes, process communication and so on.
    Like, oh I don't know...like Occam, or maybe Erlang.
    Erlang is brilliant. Erlang is:
    General-purpose.
    Concurrent / Parallel.
    Garbage collected.
    Mostly a functional style language, with immutable data.
    Dynamically typed.
    It supports distributed, fault-tolerant, soft-real-time, non-stop applications.
    It supports hot swapping, so that code can be changed without stopping a system.
    It supports threads without any libraries.
    It supports message passing, no locks required.
    An Erlang program for running a master process on on Prop, one local sub-process and one remote sub-process might look like this
    (The % are comment markers):
    [color=green]% Start a COG on this Propeller and run the function someObject:start(param1, param2)[/color]
    ServerProcess = spawn(someObject, start, [param1, param2]),
    [color=green]% Start a COG on a remotely connected Propeller and run the function someObject:start(param1, param2)[/color]
    RemoteProcess = spawn(RemoteProp, someObject, start, [param1, param2]),
    [color=green]% Send a message to that running COG process (asynchronously). The message consists of a tuple[/color]
    [color=green]% with the atom "pause" and the number "10".[/color]
    ServerProcess ! {pause, 10},
    [color=green]% Receive messages sent to this process[/color]
    receive
            a_message -> do_something;
            {data, DataContent} -> handle(DataContent);
            {hello, Text} -> io:format("Got hello message: ~s", [Text]);
            {goodbye, Text} -> io:format("Got goodbye message: ~s", [Text])
    end.
    edited 2015-04-05 08:42
    After 13 pages of discussion, maybe we should rephrase the original question so the idea is an easier to understand:
    Which is better, yellow or blue?
    Answer this question, and you will have you answer to C or Basic.
  • SLincoSLinco Posts: 4
    Ken Gracey wrote: »
    You'll be happy to know that we are working towards PropBASIC support in PropellerIDE. I've been too busy to talk much about this, but it's coming together with a small team of people (Bean, Brett, Jeff) due to requests from our customers.
    EXCELLENT news :-)
    edited 2015-04-05 08:52
    You might be interested in this article about Propeller: http://www.microsofttranslator.com/BV.aspx?ref=IE8Activity&a=http%3A%2F%2Fhabrahabr.ru%2Fpost%2F159847%2F
    A fresh look often notices previously unseen things....
    edited 2015-04-05 08:56
    Clearly blue is better!!
    edited 2015-04-05 09:04
    It common for folks that are looking from a single core general purpose processor to find the prop lacking. The prop is not designed as a general purpose CPU. The prop is designed for embedded applications, where very short time window is more inmportant than large memory size. The prop doesn't run linux nicely, while the Raspberyy Puidoes,; but the Raspberry Pi does not do real time stuff well at all, while the prop is really really good for this. This is why we use the prop for drivers, for our sensors and actuators, and use the linux box for large comms, long term storage, crunching, fancy graphical use interface etc.
    If the article was written from the prespective of embedded microcontroller, then there might be more points of interest.
    edited 2015-04-05 09:17
    Ok, back to topic.
    So there's no practical examples, right?
    Like say, - "flash 16 leds with birghtness according to sin(X)" or whatsoever.
    edited 2015-04-05 09:23
    These forums have been full of discussion of C and BASIC for years. There must have been a ton of examples passing by.
    For C you can take a look at the Parallax learning materials here: http://learn.parallax.com/propeller-c-tutorials
    There are probably documents and examples for the various BASICS available for the Propeller. I have no idea. Other probably have links. A quick google site search would probably turn them up.
    edited 2015-04-05 11:31
    Firstly, kudos to everyone for ignoring unworthy and vituperative attacks. What a great way of dealing with them!
    Secondly, to misquote prof_braino: If this thread dealt with C vs BASIC from the perspective of embedded microcontrollers, then there might be more points of interest.
    Doubtlessly others disagree, but Windows and even Linux are so big and take so long to boot (from the POV of embedded control) that it almost seems irrelevant to discuss C and BASIC in the context of them. I mean how many of us want to wait even 20 seconds for our new widget to boot up every time we flip the switch?
    Thirdly,
    Pffft! That's nothing.
    Here is some small for you: http://www.muppetlabs.com/~breadbox/...ny/teensy.html
    Wow, I love this article!! <Instant bookmark.>
    edited 2015-04-05 11:46
    +10 for vituperative
    Which led me to contemelious (which the iPhone spell checker just gives up on!)
    Which is delicious in its definition as 'insolently abusive' - you can almost feel that!
    If you are comfortable in BASIC the that's the right choice, if you find an example in Spin or PASM, that's the right choice, if c floats you boat (doubles your pleasure? Doesn't leave you void? Gills your brackets?) then it' the best choice.
    And finally, yellow and vanilla, of course!!
  • SavageCircuitsSavageCircuits Posts: 272
    edited 2015-04-06 10:26
    Ironically there's a similar thread on my own forums: http://www.savagecircuits.com/showthread.php?729-Why-C-is-better-than-BASIC
  • GenetixGenetix Posts: 1,774
    edited 2015-04-06 11:15
    CuriousOne, if you think ALGOL is ugly then try APL.
    4x5n, I have never heard of the gets function. Which library is that in?
    edited 2015-04-06 11:35
    gets reads a string from the standard input. puts writes a string to the standard output. They're in the stdio library.
  • tonyp12tonyp12 Posts: 1,951
    edited 2015-04-06 12:00
    That in C Pointers can be used to do what Assembler programmers do with indirect register addressing.
    char *dpnt = buffer; char *spnt = mystr1;
    while(*dpnt++ = *spnt++);                          // zero terminated string copy
    compiles to (and I could not do it any better if I did the assembler programming by hand):
     00C0A0    403F 0200          mov.w   #0x200,R15  ;pointer to buffer
     00C0A4    403E 0214          mov.w   #0x214,R14  ;pointer to mystr1
     00C0A8    4E7D               mov.b   @R14+,R13
     00C0AA    4DCF 0000          mov.b   R13,0x0(R15)
     00C0AE    531F               inc.w   R15
     00C0B0    934D               tst.b   R13
     00C0B2    23FA               jne     0xC0A8
    edited 2015-04-06 14:27
    I really cringe when people say that C is some kind of "high level assembler".
    Well, it kind of, sort of is but:
    Basically C is an abstraction over what all common computers are:
    It assumes they all have memory addressed by some number.
    It assumes they can somehow do the expected operations of +, -, *, / etc
    It assumes they can all support decision making, "if this do that" etc. That can cause transfer of control.
    That's it. It does that in a very succinct and efficient way. Brilliant! For this reason it has been ported to pretty much every machine that exists. And is what we build operating systems out of.
    Other languages start from a different point of view. From the high level looking down. Perhaps messing with formulas is what you want to do, OK create FORTRAN. Perhaps messing with lists is what you want to do, OK create LISP. Perhaps making programming easy is what you want to do, OK create BASIC, or Python or Javascript etc. And so on.
    Where am I going with this train of thought? I'm not sure, But higher level languages are higher level abstractions, and as Joe Armstrong says "It's better if you know what your abstractions are abstracting"
    edited 2015-04-06 15:55
    Heater. wrote: »
    Great quote, sir!
    edited 2015-04-06 16:22
    Heater. wrote: »
    The reason I refer to C as being a high level assembler is simple. The primary reason is to point out that C isn't truly a high level language but in fact a low level language. It is an abstraction to make it independent (for the most part) of the assembly/machine language of a given cpu or mpu and is capable of operations and functions not directly contained within the assembly/machine language of a given cpu or mpu. Which is why I refer to it as a high level assembly.
    edited 2015-04-06 16:37
    4x5n wrote: »
    The two big things are garbage collection and buffer overruns. Any language which does not have GC and does not catch buffer overruns and array boundary violations is not a high level language, full stop. In fact, if you glaze over those two particular differences, BASIC and C become pretty isomorphic and something like BCX becomes truly representative.
    Now there are good reasons why C doesn't do those things, all of which come down to performance both at compile and run time. You cannot write a high performance operating system or multi-threaded server in a garbage collected language, and there is a significant cost to checking all thouse array boundaries that aren't violated 99.9% of the time.
    But when you don't need that performance, there are significant costs to having to manually reserve and release memory, and memory leaks become an insidious and hard to catch bug. Bugs from buffer overruns are even more insidious and potentially catastrophic. (Don't even get me started on the bugs that can creep into pointer arithmetic, which can be almost impossible for a non-expert to isolate.) These are problems you just don't have in BASIC. You also just don't have them in Javascript. Those are expensive but important conveniences for doing rapid development of non performance critical applications.
    IMO no application that isn't performance critical should ever be done in a language like C which does not trap these assembly-language type catastrophic errors. Catching errors like that is the kind of grunt work computers are FOR.
    Now the situation is a little different in microcontroller land where that expense is far more critical, you'll find syntactic BASICs which are far more like C under the hood. (Spin, which like BASIC is a language designed for teaching, is streamlined the same way for similar reasons.) But in general, when you talk about generic BASIC you're talking about a garbage collected bound-checking language unless it is operating on truly limited hardware. And in general, when you talk about C you're talking about a language that will let you blow your foot off with a howitzer even if you're writing a tic tac toe game on a 2 GHz 8-core PC.
