What to use for spinning "radar".
NWCCTV
I want to put something similar to a radar on my Wild Thumper. The idea is to have a servo spin either a ping sensor or a PIR sensor mounted to a slip ring/servo. I am wondering which would be better and also should I use just one or would 3 in a triangle work out better. The idea is to fly my quad over the Wild Thumper and have the sensors detect it and then have my Laser Range Finder "lock in" on it and shoot it with mini missiles!!!! Quite a long shot I know but it has been an idea that has been brewing in my head for a while now and I am just getting around to the planning stage. My ADD does not let me finish one full project without starting several more!!!
I guess a scanning servo mount would enough and quite simple - or a stepper motor.
making one for a POV project, but if I had the money I think I would just buy one.
https://www.sparkfun.com/products/13064
Slip rings like the Sparkfun product are fine but if these are standard IR or ultrasonic sensors you're talking about, a second sensor might be cheaper.
If you go the 360 degree spin route, a stepper motor with an index signal (so you always know where "home" is), or a gear motor with an absolute encoder would be required, so you know which way the thing is pointing.
A pir sensor would be triggered continuously if it was rotating so I am guessing that you were referring to a reflective ir sensor.
I've been trying to use PING and IR to track a copter and it doesn't work well at all. The area that you need to scan is massive considering the size and sweep of a single beam and the size of the copter. Using an array of sensors would alleviate a lot of scanning.
What this country needs is a good 5-cent blimp target. Big & slow, easy to detect, track and hit.
On a copter (indoors or at night) you could have it emitting a 38 khz IR signal, which would make it easy to detect & track. Not sure if an emitted ultrasonic signal would get messed up by wind & propwash.
A beacon on the copter would help tremendously. Probably easy enough to use a wii camera, of course not ideal on a bright day outside
Also if you need some rockets to shoot check this out -
Marty
As for sharing pins, if you're going to use a CR turret with a slip ring, you'd only need or want one Ping, yes? I'd think you'd either use multiple Pings on a non-360 servo (separate signal pins), or a single Ping on a CR servo (one signal pin). In the end, though, it's one Ping, one pin. While one pin could fire two Pings, how do you detect the echos you get back, and know which is which?
I wasn't clear you were not using a continuous turret, because you then asked about using just one signal pin, as might be the restriction if you had a slip ring.
I seem to recall Parallax publishes the beam pattern of the Ping, which would answer the question regarding height. You will also need to consider the use of ultrasonic sensors outdoors, and the effects of wind, especially at the max echo distance of approximately 12 feet.
