Fourier transform using Atmel Micro controller
Hi,
I am new to atmel micro controllers.I want to do Fourier transform of an ac voltage signal.I will be using one of the following micro controllers-ATMEGA328/ATMEGA644/ATTINY45/AT32UC3C2512C. AVR DRAGON will be used for programming.Let me know how to do frequency transformation in this micro controller.Is there any library available to do these operations?
Thanks & Regards,
BISNI
Thanks & Regards,
BISNI
Maybe you should try the Atmel forums where they use Atmel controllers like the AVRs and ATMegas??
