Quickstart/Wiznet/HID Hack
Just wondering if anyone has ever tried to connect the Quickstart, WizNet and a Human Interface Device together or if it is even possible. I have some experiments that require the use of all 3 together but I do not want to proceed if I will be wasting my time.
P8-9 IR LED and modulator
P10-11 Audio
P12-15 Composite video
P24-25 Mouse
P26 Keyboard data line
Those are the pins used by the Wiznet board. Not sure if any of the HIB circuitry on these shared pins would affect the functionality of the Wiznet but probably. You could modify how you stack the boards so that the HIB pins don't actually connect to the Quickstart. Put the Wiznet on top of the QS and put the HIB underneath. It would require soldering to reorient the header on the HIB.
What all do you require from the HIB? No reason you can't just run wires from the extra header location on the QS to the needed circuits on the HIB. This would also mean you could have those circuits on whatever pins you desire.
This discussion is also presenting another reason why Peters IOT5500/CPU module is valuable. Since that propeller is doing the Wiznet work, you would have plenty of IO on your main Propeller.
