5MHz MEMS Oscillator tiny 2.5x2mm
tonyp12
If you're really trying to save space, Mems also have other positive traits.
I guess you have to make some changes to the _clkmode if you used a oscillator(?).
100: $1.19
http://www.mouser.com/ProductDetail/Micrel/DSC1001DI1-0050000/?qs=sGAEpiMZZMt8zWNA7msRCnIKWTzKWgkiweaYxICiuHDvaNQzpGxQow%3d%3d
Abracon also have one:
100: $1.206
http://www.digikey.com/product-detail/en/ASDMB-5.000MHZ-LC-T/535-12144-ND/4199721
Side note: SiTime is coming out with a 1 Hz to 32 kHz Oscillator
The 256Hz is available soon, the 1Hz would be cool as a true 1sec counter.
http://www.mouser.com/ProductDetail/SiTime/SIT1534AI-H4-DCC-00256/?qs=sGAEpiMZZMtjsFrk8KnjP2Y3H7IntjsnqBAYLqLXfP8%3d
100: $1.19
100: $1.206
Not cheap, but it has impressive low Icc for a Oscillator module, so maybe they chase those who will pay first ?
SiTime also have SiT5000 family, a MEMS (VC)TCXO that has down to ±1.5 PPM and a Voltage trim pin - but so far only 10MHz+
On the RTC front, I see Holtek have now released data on their TCXO
http://www.holtek.com.tw/english/docum/Functional_Module/1585.htm
Not as small as the options above.
