Propeller IO Expansion - What Is The Best Solution? — Parallax Forums
idbruceidbruce Posts: 6,197
edited 2015-02-22 16:27 in Propeller 1
I know there are a lot of solutions out there, but I want to hear some opinions. I also know that there are a variety of things to consider, such as pin usage, speed, ease of use, external components required, communication, additional IOs gained, etc...
State your case :) Convince your peers :)
    edited 2015-02-20 07:51
    Oh, oh, I know that one, that's easy, the first thing to consider as an I/O expander for the Propeller is .... another Propeller!
    Expand your processing power at the same time you expand your I/O.
    But really, what manner of I/O do you mean?
    edited 2015-02-20 08:14
    idbruce wrote: »
    Funny thing that heater mentioned to use another Prop because that's what I did once or twice where I was driving a lot of solenoids and reading contacts amongst other things. Without too much ado it is easy enough to talk to the extra Prop serially on a single line plus the I/O Prop can do a lot of smart I/O and filter inputs, time outputs etc.
    However I normally just use I2C for I/O expansion or if necessary SPI but in the case of the latter I just borrow the SCL and SDA lines from I2C (EEPROM) and use a CS so I am not using up more and more Prop I/O to "expand", because that kind of defeats the purpose when you see multiple I2C and SPI buses in some designs. How to convince you? Because that's what I do :)
    The other solution is like the first except I just use a cheap little micro though I do prefer the easy to use Silabs 8051 parts as they are very fast and simple, combine A/D and D/A, easy to flash via the Prop, plus 8051 assembly is a breeze.
  • idbruceidbruce Posts: 6,197
    edited 2015-02-20 08:22
    I should have been specific.... With the exception of using another Propeller, what is the BEST way to increase IO pins :)
    Well Peter.... :) I am not asking you to convince me, I am asking you to convince the entire forum :) I trust your opinion and knowledge about electronics, but will everyone else agree with your methods and selection. Convince them! :)
    edited 2015-02-20 08:26
    idbruce wrote: »
    It really depends on what you are using the extra I/O for.
    edited 2015-02-20 08:29
    As with most of life, there is no single "best" way to do I/O expansion. For output only, and if you can spare three pins, the 74HC595 is a common choice. If you can't spare the pins, you can hang I/O expanders, like the PCF8575, on the EEPROM's I2C bus. A lot also depends on whether the expansion port has to be 5V-friendly. So, no, there's no "best" solution without considering the context of each individual problem.
    edited 2015-02-20 08:37
    idbruce wrote: »
    To ask us to convince our peers is really asking that we convince you because you are asking, not our peers. However in so doing if there is consensus from most then I guess you will be convinced. Of course all of us could be wrong but at least you'd be convinced :)
    Now that you shout "BEST way" I will have to say that would have to be to use the Prop's internal address/data bus, if you could, well, that would be the BEST. When all you have are I/O pins and only 32 of them you normally would talk to other I/O serially and the methods have been covered, that is, asynch, I2C, and SPI. Of course you could create an 8-bit bus plus other lines for address and control BUT you only have 32 Prop I/O max! These I/O are precious, they are the only ones the cog can access in a single cycle, I wouldn't waste them unless that turned out to be the expedient and practical thing to do. "BEST" also depends upon what you are doing with them but most of the time these only need to be simple on/off or switch sensing.
    EDIT: @Phil - you only need one I/O as the load signal for the 595s as there is no reason why you can't use clock and data from the I2C EEPROM lines.
    edited 2015-02-20 08:43
    Okay, then let's simplify the selection process.
    There is no intended purpose for the additional pins and the only goal is add additional IO pins. Although the 5V thing throws a wrench into the scene....
    Okay so BEST 5V solution and BEST 3.3V solution
    edited 2015-02-20 08:44
    Peter,
    ...easy to flash via the Prop, plus 8051 assembly is a breeze.
    There speaks one who lives and breaths MCU's, assembler languages and Forth.
    For many normal human beings who are beginner or casual MCU programmers having to deal with another HLL or assembly language is a bit to much to ask. Having to be familiar with multiple IDE's and programming hardwares is out of the question.
    Whilst you are working in Spin/PASM how much easier it is just to use all that skill on your expansion hardware as well. If nothing else it's a lot less fiddly details of different systems you have to remember when you get back to your project after a long break.
    After that I'm with the sentiment that cheap, dumb, physically small port expanders and shift registers is a way to go.
    And yep, without a specific I/O requirement statement the can be no "best".
  • TappermanTapperman Posts: 321
    edited 2015-02-20 08:48
    ... I normally just use I2C for I/O expansion or if necessary SPI but in the case of the latter I just borrow the SCL and SDA lines from I2C (EEPROM) and use a CS so I am ...
    Damn it! Every time I think I have an original ... someone has beet me to it.
    ... Tim
    edited 2015-02-20 09:02
    Heater. wrote: »
    Peter,
    I agree that it is much easier development-wise to use a Prop as I/O but that is not always the best hardware solution. Sure, you could share the clock, you could even boot the I/O Prop serially so that you could do away with a crystal and EEPROM, but that is still more complicated than communicating via I2C with one of these tiny little micros that are packed with precision oscillator, analog subsystems, 5V operation options etc, and I only need one extra Prop I/O to control the reset/programming of it.
    BTW, most 8-bit assembly is very simple although I would much prefer 6502 rather than 8051 but in terms of the different architectures I do dislike AVR register based assembly, and PIC is primitive but okay. ARM code and IDEs start to get a bit complicated but I am tempted to write a Forth that fits onto one of these little dollar chips so that I can then load "scripts" into them from the Prop :)
    edited 2015-02-20 09:23
    There are now two great resident FORTHs for the LPC1114. One (as mentioned before) is Fish from Clyde W. Phillips. The new one is Mecrisp from Matthias Koch. Both are great FORTHs and both are great guys. I think it would be outstanding for Peter to add his considerable skills to this same worthwhile pursuit.
    BTW, I always have specific reasons for extending μC I/O and so I always employ specific solutions. Shift registers are generally the best bang for the buck, but they aren't even close to a universal solution. I don't believe in universal solutions.
  • tonyp12tonyp12 Posts: 1,951
    edited 2015-02-20 10:07
    Fixed Input and Output designation?, or selected by software (i2c expanders pretty much the only choice then)
    A DIP version should be available?
    Simplest one is to turn 8 input pins in to output pins using a latch, 74HC573 (74HCT573 for 5V operation)
    Put 1K resistor on the input traces and when you want it to be a output, turn the Props port around and write the value and do a LE pulse and then go back to input.
    Best part is that waitpne etc still works
    So 9 pins turns in to 16 I/O pins.
    edited 2015-02-20 10:44
    Tony
    The answers to those questions, are up to the person responding.
    How does waitpne fit into the scheme?
    edited 2015-02-20 10:53
    A system with parallel to serial inputs would of course not work with Props waitpne/peq
    the cog that uses it as input will need to be the same cog that uses as output preferably, as to know when waitpne or inputs are "real" inputs
    A cog input only, could work if you read port twice and if any LE pins was high at the same time then disregard the value.
    using two 74HC573, will give you 8in and 16out with the use of 10 prop pins, pretty good for most uses and HCT version gives you free translation to 5V if wanted
  • TubularTubular Posts: 4,767
    edited 2015-02-20 12:32
    If you want a peripheral thats close to universal i/o expansion, while we wait for P2, the AD5592R is interesting.
    At first glance the digitals don't sink/source much, but you can also use the pins in DAC mode where they'll happily source/sink 20mA, limited at 25mA, so this means you can interface to any arbitrary voltage chip, eg 2.5v, 1.8v etc.
    You can load the SPI version at least at 20 MHz, and there's a I2C version too (5593R)
    480 x 401 - 46K
  • jmgjmg Posts: 15,194
    edited 2015-02-20 13:17
    idbruce wrote: »
    As well as the Silabs parts Peter mentioned (great if you want ADC & are ok with SMD), there is also AT89LP52, which is ~70c for 32io.
    Comes in DIP/PLCC44/TQFP44 and works 2.5V/3.3V/5V with TTL thresholds.
    That's cheaper than PCF8xx IO expanders on a cents per io pin, and I think the over-priced PCF8xx are due for a shakeup from the growing number of sub 70c small MCUs
    There are still lowly parts like HEF4021 (great for keypad IO) and xC595 (op only), but they are fixed-use.
    If you pop over to Digikey and Search for micro-controllers, cheapest @ 1000 you find they start at 31c (!)
    I think this link does that
    http://www.digikey.com/product-search/en?FV=fff40027%2Cfff800cd&mnonly=0&newproducts=0&ColumnSort=1000011&page=1&stock=0&pbfree=0&rohs=0&quantity=1000&ptm=0&fid=0&pageSize=25
    I'm working on pushing one of those little micros along at 3MBd, for highly flexible slave IO and I think it can hit 4MBd (which is apparently where RaspPi tops out )
    edited 2015-02-20 14:46
    jmg
    I see $1.52 ~ $2.11 for 36
    Is that the specific chip you are using now?
    edited 2015-02-20 15:58
    idbruce wrote: »
    jmg
    I tend to index on 1000+, as the 1+ margins are all over the place at distributors.
    idbruce wrote: »
    I use the LP52 as IO,yes, but it is not the one I try to push to 3MBd/4MBd
    I am looking at a wired-or TTL.232 with a 5 bit address field, to allow 32 slaves and only one echos, using the Quasi-Bidirectional IO, - not sure how that would cope as the area grows. I suspect more serious drivers would be needed to hit 3MBd, but i want to avoid half-duplex of RS485
    edited 2015-02-20 19:57
    This part seems to be hard to get although Digikey have good stocks of the 8 channel part and the price is certainly better than all those standard I2C I/O expanders. However it's only available in QFN and it basically smells like a preprogrammed micro anyway. I'd rather have the analog subsystem on my expander than fancy keypad scanning etc. Besides, the micros are cheaper still, if only there were a way to convince a chip manufacturer to preload some of their micros so that they could be used off the shelf as is but of course since they are flash you can still just load them up as you do normally. Perhaps if a really robust I2C expansion solution were made available then there might be a chip maker interested enough to take this idea up. Imagine Digikey/Mouser having tens of thousands of a particular micro in stock at really good prices, and they come preloaded as an I2C expansion port!
    edited 2015-02-20 20:14
    Besides seeking general opinions, there is something that has been bothering me for quite some time. Although the controller discussed within this thread http://forums.parallax.com/showthread.php/155404-Input-Needed-Combining-Propeller-Proto-Board-Prop-DIP-40-and-ADC-for-3D-Printer has some definite merit, I still do not like the limit switch setup. There are (3) IO pins being utilized for what I call homing switches and then there is another set of switches tied into what I call estop on one pin. Whereas in the Teacup firmware, they are referred to as X_MIN, X_MAX, Y_MIN, Y_MAX, Z_MIN, and Z_MAX, which can be monitored by six pins. The controller outlined in the link above, has provisions for four stepper drivers. If this controller were to be used for something besides 3D printing, it may be desirable to have another 2 switches for another axis. Let's call these switches E_MIN and E_MAX. So total switch count would be 8. As mentioned, there are 3 IOs already being used for three switches, but these three IOs could be used for a 74HC165, which would provide 8 inputs for 8 switches, and everything would be perfect, providing that I could read them before another step is made on any of the four axes, with all of the steppers being driven at the highest possible speed within the constraints of the machine.
    Admittedly, I have a very hard time reading and comprehending the datasheets, so I have no idea if this would work well or not. But let's say there is a cog with a solitary task of repeatedly polling a 165, just how fast could this cog read the 8 bits and store it to a global variable?
    The Teacup firmware drives all the steppers with one timer, however in the future, I would like to explore the possibility of controlling four steppers, with four different timers, to see if there is any performance gain.
    edited 2015-02-20 20:56
    idbruce wrote: »
    If you want to manage Limit switches, where you expect only one at a time to fire, then look at Priority encoders.
    They have aflag for any-valid, and an encoded 3 bits for the highest one valid
    I think many i2c slave devices also have Pin change interrupts, so you set a OK pattern, and get a signal on Not-OK.
    edited 2015-02-20 21:01
    jmg
    Thanks for the input, I will definitely look into that! Although I have never heard of them.
    edited 2015-02-20 21:17
    idbruce wrote: »
    If reading inputs is all this particular chip was doing then I would just have a micro with umpteen inputs that are then filtered perhaps and output continuously at high speed (up to 10Mbits/sec) to a single pin on the Prop. A cog would just read in the stream and update not just 8-bits but perhaps a long at a time. Achieving an update rate of 100k per second is easy and all it takes is a single pin. Of course for switches you only need a more leisurely update rate of 1,000/sec and the baud rates could just be well within 115.2k baud even.
    edited 2015-02-20 21:40
    @Peter Jakacki
    re: However it's only available in QFN
    You could always use a SparkFun 16 Output I/O Expander Breakout - SX1509 if it's for experimenting or a one time thing. It may be expensive for a commercial product though. They should have stock as well.
    SparkFun 16 Output I/O Expander Breakout : https://www.sparkfun.com/products/11502
    edited 2015-02-20 21:56
    Peter
    Considering the application that I specified, do you have any particular micro that you might suggest that would be well suited for the application. Please keep in mind that a very small footprint would be of high priorty, perhaps even a breakout board.
    edited 2015-02-21 01:54
    idbruce wrote: »
    What is "very-small" ?
    3mm x 3mm QFN20 ? or an easier to handle SO16N ?
    edited 2015-02-21 02:28
    I think for the ease of to work with - multiple propeller are the way to go.
    @Beau Schwabes HS serial concept fits right into the Propeller Mailbox schema. OK 2 cogs per Prop and two pins per prop. But you can chain a lot of them. The concept here is a common hub buffer, shared by circling around with fast serial thru all props.
    The size of the buffer and the meaning of the content is up to your software. Think of common hub shared between props. Easy to use. Easy to extend. Just one prop more into the ring.
    One prop could provide clock for all others. I would give each prop a EEPROM and prop plug header.
    2 cogs per prop sounds like overkill, but you gain 6 cogs and 26 pins per prop. Not bad.
    Enjoy!
    edited 2015-02-21 04:27
    jmg
    I meant to be specific, but then I forgot. Looking at the board and some photos, I believe it would have to be a breakout board. I have included one photo and the red rectangle represents my work area.
    708 x 460 - 91K
    edited 2015-02-21 10:43
    idbruce wrote: »
    jmg
    Ah, ok, you want a small breakout board. ( Both 3mm QFN20 and SO16N are much smaller than that space, but not so easy to drop-in-there ).
    Cheapest complete system (both halves) is the SiLabs TOOLSTICK850-B-SK, buy this first, and get the Debug block.
    ( I have no idea why their F850 daughter card has so much waste space... )
    A more compact daughter card is the TOOLSTICK381DC, but that final device does not come in sub $1 packages, so I'd avoid that and try to fit the F850 - for a final PCB revision, you could use a sibling device. (QFN20 / SO16N / QSOP24)
