Hydra Expansion Card Problem
I used the expansion card that came with the hydra to add an XBee adaptor to the unit. It seems that when the expansion card is inserted, it automatically causes the address of the EEPROM to change using the 3.3 volt loopback. Is there a simple way to disable this feature other than cutting the trace to the connector on the card?
Robert
