SOLVED- putDec problem
This does not work the way I thought it would. I keep getting 4095 to the terminal, regardless of the value assigned to nDec. What is wrong?
EDIT: Problem solved
#include "simpletools.h" int main(void) { int nDec; nDec = 203; putDec(nDec); return 0; }
-Mike
Come on Bruce.
The problem was that I was using the Parallax Serial Terminal, instead of the "Run with Terminal" option that is part of SimpleIDE.
-Mike
