SOLVED- putDec problem — Parallax Forums
idbruceidbruce Posts: 6,197
edited 2015-02-15 09:31 in Propeller 1
This does not work the way I thought it would. I keep getting 4095 to the terminal, regardless of the value assigned to nDec. What is wrong?
EDIT: Problem solved
#include "simpletools.h"
int main(void)
  int nDec;
  nDec = 203;
  putDec(nDec);
  return 0;
  • pmrobertpmrobert Posts: 678
    edited 2015-02-15 08:58
    Bruce, how did you solve it? Does the current posted code contain the problem or the fix? Enquiring minds (mine!) want to know, please.
    -Mike
    edited 2015-02-15 09:06
    Grrr...it's so annoying when people don't post the solutions to their problems when they find them.
    Come on Bruce.
  • idbruceidbruce Posts: 6,197
    edited 2015-02-15 09:20
    The problem was that I was using the Parallax Serial Terminal, instead of the "Run with Terminal" option that is part of SimpleIDE.
    Thanks, Bruce - this will be added to my "list of weird things that aren't immediately obvious".
    -Mike
