activating a touch display with a circuit
I would like to activate the touch display of an instrument remotely (meters range).
I would only need to press a single bottom, in a well defined position.
I would like to stick with some tape an activation circuit, to be used in place of my finger.
I'm considering the possibility to use a servo and a touch pen, but mounting the servo would be tricky and probably make it not reliable.
Any suggestion is welcome.
Massimo
Massimo
https://www.youtube.com/watch?v=Y2Sfjt4nmF8
Naturally, you should use a touch sensor to trigger this.
https://www.youtube.com/watch?v=qYxNeyRnkxw
I was thinking about a remote control in place of a touch sensor, but this is the idea.
I was hoping to be able to trigger the touch using a fixed circuit sticked on the screen, able to simulate the body capacitance with no moving parts, because I have not a nice place for the servo, but at the moment servo and pen combination looks the best solution.
Massimo
