COGNEW help
TC
Hello all,
I am making a simple 7-segment display driver. I have a running prototype, but now I want to put the display driver code in a new cog, and just update the buffer array. here is my working prototype code...
Here is an attempt I did to make the driver code be in another cog. (I know the stack is large, it is just a first run)
I know it has to be something simple, but I just cant see it. Does anyone have any ideas?
TC
CON
_clkmode = xtal1 + pll16x
_xinfreq = 6_000_000
CON 'PINS
DIG0 = 0
DIG1 = 1
DIG2 = 2
DIG3 = 3
DIG4 = 4
DIG5 = 5
DIG6 = 6
DIG7 = 7
SEG_A = 8
SEG_B = 9
SEG_C = 10
SEG_D = 11
SEG_E = 12
SEG_F = 13
SEG_G = 14
DP = 15
CLR = 16
CLK = 17
VAR
BYTE BUFF[8]
PUB MAIN
DIRA[CLR] := %1
OUTA[CLR] := %1
LOAD_BUFFER(0,2)
LOAD_BUFFER(1,4)
LOAD_BUFFER(2,1)
LOAD_BUFFER(3,9)
LOAD_BUFFER(4,10)
LOAD_BUFFER(5,3)
LOAD_BUFFER(6,8)
LOAD_BUFFER(7,5)
LOAD_DISPLAY
PUB LOAD_BUFFER(DIGIT_NUMBER, VALUE)
BUFF[DIGIT_NUMBER] := VALUE
PUB LOAD_DISPLAY | DIGIT
DIRA[CLK] := %1
OUTA[CLK] := %0
DIRA[DIG0..DP] := %11111111_11111111
REPEAT
REPEAT DIGIT FROM 0 TO 7
OUTA[DIG0..DIG7] := BYTE[@DIG + DIGIT]
OUTA[SEG_A..DP] := BYTE[@CHAR + BUFF[DIGIT]]
OUTA[CLK] := %1
OUTA[CLK] := %0
DAT
CHAR BYTE %11111100 '0
BYTE %01100000 '1
BYTE %11011010 '2
BYTE %11110010 '3
BYTE %01100110 '4
BYTE %10110110 '5
BYTE %10111110 '6
BYTE %11100000 '7
BYTE %11111110 '8
BYTE %11110110 '9
BYTE %00000000 'BLANK
DIG BYTE %10000000
BYTE %01000000
BYTE %00100000
BYTE %00010000
BYTE %00001000
BYTE %00000100
BYTE %00000010
BYTE %00000001
CON
CON 'PINS
DIG0 = 0
DIG1 = 1
DIG2 = 2
DIG3 = 3
DIG4 = 4
DIG5 = 5
DIG6 = 6
DIG7 = 7
SEG_A = 8
SEG_B = 9
SEG_C = 10
SEG_D = 11
SEG_E = 12
SEG_F = 13
SEG_G = 14
DP = 15
CLR = 16
CLK = 17
VAR
BYTE BUFF[8]
BYTE COG_ID
LONG DISPLAY_STACK[100]
PUB MAIN
DIRA[CLR] := %1
OUTA[CLR] := %1
LOAD_BUFFER(0,2)
LOAD_BUFFER(1,4)
LOAD_BUFFER(2,1)
LOAD_BUFFER(3,9)
LOAD_BUFFER(4,10)
LOAD_BUFFER(5,3)
LOAD_BUFFER(6,8)
LOAD_BUFFER(7,5)
'LOAD_DISPLAY
COG_ID := COGNEW(LOAD_DISPLAY(@BUFF, @DIG, @CHAR, DIG0, SEG_A, CLK), DISPLAY_STACK)
PUB EXTRACT (VALUE) | DIGIT, DIVISOR
DIVISOR := 10_000_000
REPEAT DIGIT FROM 7 TO 0
BYTE[BUFF][DIGIT] := VALUE / DIVISOR ' extract digit
VALUE //= DIVISOR ' remove digit from value
DIVISOR /= 10 ' fix divisor for next digit
PUB LOAD_DISPLAY(BUFF_ADDR, DIG_ADDR, CHAR_ADDR, DIG_PIN, SEG_PIN, CLK_PIN) | DIGIT
DIRA[CLK_PIN] := %1
OUTA[CLK_PIN] := %0
DIRA[DIG_PIN..(DIG_PIN + 16)] := %11111111_11111111
REPEAT
OUTA[DIG_PIN..(DIG_PIN + 8)] := BYTE[DIG_ADDR + DIGIT]
OUTA[SEG_PIN..(SEG_PIN + 8)] := BYTE[CHAR_ADDR + BUFF_ADDR[DIGIT]]
OUTA[CLK_PIN] := %1
OUTA[CLK_PIN] := %0
DAT
BYTE %01100000 '1
BYTE %11011010 '2
BYTE %11110010 '3
BYTE %01100110 '4
BYTE %10110110 '5
BYTE %10111110 '6
BYTE %11100000 '7
BYTE %11111110 '8
BYTE %11110110 '9
DIG BYTE %10000000
BYTE %01000000
BYTE %00100000
BYTE %00010000
BYTE %00001000
BYTE %00000100
BYTE %00000010
BYTE %00000001
TC
Egad, man! Do you enter code with caps-lock on? Code is much easier to read with lower/mixed case.
Thank you Phil for the reply.
I added @display_stack, and it still does not work.
Sorry about the caps lock thing. I only use it to try out code. I have been known to put caps in places where they should not be, and I get lost looking for a problem. After I have a working idea. I then take my time to lay out the code better.
I am only trying out the caps-lock thing. It has its ups and downs.
CON 'PINS Dig0 = 0 Dig1 = 1 Dig2 = 2 Dig3 = 3 Dig4 = 4 Dig5 = 5 Dig6 = 6 Dig7 = 7 Seg_A = 8 Seg_B = 9 Seg_C = 10 Seg_D = 11 Seg_E = 12 Seg_F = 13 Seg_G = 14 DP = 15 clr = 16 clk = 17 VAR BYTE buff[8] BYTE cog_ID LONG Display_stack[100] PUB main dira[clr] := %1 outa[clr] := %1 Load_Buffer(0,2) Load_Buffer(1,4) Load_Buffer(2,1) Load_Buffer(3,9) Load_Buffer(4,10) Load_Buffer(5,3) Load_Buffer(6,8) Load_Buffer(7,5) cog_ID := cognew(Load_Display(@buff), @Display_stack) REPEAT PUB Load_Buffer(Digit_Number, value) buff[Digit_Number] := value PUB Load_Display(Buff_Addr) | digit dira[clk] := %1 dira[clk] := %0 dira[Dig0..DP] := %11111111_11111111 REPEAT REPEAT digit FROM 0 TO 7 outa[Dig0..Dig7] := BYTE[@dig + digit] outa[Seg_A..DP] := BYTE[@char + Buff_Addr[digit]] outa[clk] := %1 outa[clk] := %0 DAT char BYTE %11111100 '0 BYTE %01100000 '1 BYTE %11011010 '2 BYTE %11110010 '3 BYTE %01100110 '4 BYTE %10110110 '5 BYTE %10111110 '6 BYTE %11100000 '7 BYTE %11111110 '8 BYTE %11110110 '9 BYTE %00000000 'BLANK dig BYTE %10000000 BYTE %01000000 BYTE %00100000 BYTE %00010000 BYTE %00001000 BYTE %00000100 BYTE %00000010 BYTE %00000001Thanks
TC
That did it. Thank you so much. Now to understand what I was missing.
