Raspberry Pi 2 released. PropellerIDE faster on ARM. - Page 5 — Parallax Forums
1235»
  • LeonLeon Posts: 7,620
    edited 2015-02-06 09:14
    Good news! I had to go out to buy something so I called in at the PO, on the off-chance, and they had received the five RPi 2s.
    edited 2015-02-06 09:33
    @ Leon
    re: so I called in at the PO\
    Don't they have online tracking?
    Even Canada post has online tracking LOL . I received a book last week and was able to track it online. It showed me the delivery date and even send me a email when it was delivered to my community mail box. 15 minutes later I picked it up . :)
  • dgatelydgately Posts: 1,643
    edited 2015-02-06 09:46
    Well, $50 US is not really a discount... The RPi 2 sells for $35 US at MCM Electronics, though backordered with a 10 day expectation for getting them into MCM's warehouse. I assume Newark/Element 14 will sell for $35 US as well. Elector's retail of $58 US seems quite high.
    dgately
    edited 2015-02-06 09:53
    @ Leon
    Yes, but I was told by RS they were out of stock yesterday, and the on-line tracking didn't work although they were being shipped. It did work today, though. The card they left said to wait a day.
    edited 2015-02-06 14:53
    @ Elector's retail of $58 US seems quite high.
    Yes, your right. I did not realize how high it was until you pointed it out and I saw that it did not include shipping and handling.
    edited 2015-02-11 08:24
    In case you guys are interested, I've published my (rather large) Raspberry Pi 2 Model B review:
    http://www.mikronauts.com/raspberry-pi/raspberry-pi-2-model-b-review/
    There are a lot of benchmarks comparing Pi 2 B, Pi B+, Odroid C1, Banana Pro, MIPS Creator CI20
    edited 2015-02-11 08:36
    Bill,
    Thank you for your excellent reviews on everything Pi! I've enjoyed reading each of them and appreciate the amount of thoughtful work and analysis that you've put into them.
    Bravo!!
  • Kerry SKerry S Posts: 163
    edited 2015-02-11 10:11
    Great reviews Bill.
    I really liked how you compared it to the ODroid C1 as I am also looking at that for my setup.
    Thanks for taking the time to do these!
  • jmgjmg Posts: 15,200
    edited 2015-02-11 11:51
    Cool, - no Baud rate tests I could see ? ;)
    A useful test I use on PCs for stress-testing USB & Serial ports, is to send a large file of 0x55 ("U") and a Frequency Counter on the DATA lines gives the sustained average throughput.
    Tested in both Loop-back, and open ended modes.
    At low baud rates, freq is Data/2 on Std 8 Bit UART, and at higher rates extra stop bits can creep in from the system delays, lowering the Frequency below Data/2.
    Gapless SPI will also hit Data/2, but some SPI ports need 1 Baud clk turnaround, and some need 1-2 SysClk turnaround, and the better ones can do gapless SPI.
    Baud Granularity is also easily found on this test setup - ask for slightly incrementing Baud values, and see when the Frequency actually changes. This will give a Virtual Baud Clock value ( eg on most FTDI parts, the VBC is 12MHz )
    edited 2015-02-11 14:07
    Very nice work Bill . All I have are the original versions and I was happy to see the two dual USB host jacks :)
    Start up time looks good too."" Raspberry Pi 2 B ADATA 22.9"" (not that I'm impatient LOL)
    edited 2015-02-11 14:21
    Rick & Kerry: Thank you & you are most welcome!
    jmg: thanks. Nope, no serial, spi or i2c tests. Might try some later, to see how far I can push the Pi/RoboPi data rate :)
    Bob: Than you! Yep, the Pi 2 is surprisingly snappy. I am pretty sure they shaved/tuned the boot sequence, and stripped the binaries, as the C1 *should* be faster for boot/launch times, but is not.
    edited 2015-02-11 15:23
    I got a box today with three RasPi 2's in it. One is going to be set up as a workstation. I've always run them headless, so this should be interesting. I do wish they had SATA. A RasPi 2 with a 128gb SSD would be a sweet workstation. I guess that's a job for my Banana Pro.
    I have one tool I need to get to my virtual desktop at work that needs an x86 OS. If it wasn't for that, I could totally run my world on these little guys.
    edited 2015-02-13 22:15
    You might want to start a separate benchmarks thread.
    I also found this, for older RaspPi I think
    http://www.raspberrypi.org/forums/viewtopic.php?f=44&t=43442
    that seems to indicate a HW based Virtual SPI clock of 250MHz and Baud = VSC/(2*N)
    Practical speeds could be in the region of 25MHz / 31.25MHz / 41.666MHz / 62.5MHz
    and also this for UARTS ?
    http://www.raspberrypi.org/forums/viewtopic.php?f=44&t=17559
    Mentions 100MHz as a pin ceiling, & someone else said
    "I've just seen a clean rectangle wave out of the TX pin at 4 megabaud, that is 2 MHz when sending "UUUUUUUUUU...."
    and another comment there of
    After reading around, I did some testing to see what the maximum achievable baud rate is. Using the latest stable raspbian build (3.6.11+) and editing init_uart_clock in /boot/config.txt, I was able to get up to 4Mbaud read speeds. However, past that point it seems that the linux OS stops support, as bits/termios.h has __MAX_BAUD at 4Mbaud (http://repo-genesis3.cbi.utsa.edu/cross ... .html#:172).
    I would think that going up to 15.6Mbaud would be feasable, considering that
    baud_rate=250MHz/(8*(1+baud_reg)),
    That 250MHz CLK is not a good fit for higher speeds, as FTDI use a virtual Baud CLK of 12MHz or 24MHz, whilst the 2 formula given on RaspPi give 15.625Mhz or maybe 31.25MHz, meaning that 4MBd mentioned will be
    3.906250MBd, which is a 2.34% offset from what FTDI will deliver.
    Maybe the System PLLs can be tweaked to give better Baud rate alignment ?
    All those numbers will likely move on the 4 Core model.
    but I'm at a loss as to what to do to get past the 4Mbaud limit.
    Sounds like 4MBd (sustained) has been achieved, and up to 15.625MBd mayU be possible
