Still camera recommendation
My robotics class needs a recommendation for a digital still camera with the following specs:
We have to be able to identify sea stars at a depth of 2 meters from the sea surface in natural light from a slow-moving craft and classify the extent of their wasting disease.
Any and all ideas are welcome!
Thanks!
1. High resolution: 10M pixels or more.
2. Inexpensive underwater housing: to 1 meter only, though.
3. IR shutter release.
4. Normal (not wide-angle) lens. (IOW not a GoPro.)
5. Good sensitivity in low light.
6. Photos saved to SD or micro-SD card.
7. Economical. (We're really strapped for cash.)
Thanks!
You would have to add external circuitry to the camera's USB port and script CHDK to snap the shutter. The camera doesn't have an IR remote built in.
Edit: I just noticed the underwater housing part, that is another $250. Sounds like a waterproof camera may be cheaper. There are a lot of inexpensive waterproof cameras but I'm not sure about the IR port.
GoPros do have a "narrow" view option. I think a GoPro Hero 3 or 4 would meet all but #3 and #7 unless the stars were real small.
If this is meant to be attached to the boat and pictures snapped at regular intervals, then I think that you may be better off taking HD video than individual snapshots.
Can you mount the camera to a pole and lower it a meter or so into the water? If so then a GoPro should work great.
Thanks for the input. I tried an inexpensive Chinese underwater camera. It wasn't bad, watertightness was superb, and it had an IR shutter release; but it had a wide-angle lens, and the image quality suffered. $250 just for a housing would break the bank, I'm afraid.
Rich,
Thanks for the suggestions.
I have a GoPro Hero 3 with a submersible housing. The still image quality is really poor, IMO. I was not aware that it has a "narrow" option, but I suspect this is not due to a mechanical zoom, but the result of confining the image to the center pixels and mathematically enlarging them. I've also noticed that the image sensor has a plethora of dead pixels (both black and white), futher compromising the image quality.
Regarding video, as opposed to still images: yes: video looks great as video. But when you freeze frame, you notice how much your eyes and brain have filled in details that do not really exist in the individual images. That's the reason that quality still images seem more appealing at first blush.
BTW, the IR shutter-release spec is to enable the camera to be housed separately from the other electronics without needing a thru-hull cable fitting. The idea is to trigger it with a powerful, down-facing, coded IR beam that relies on backscatter to reach the front of the camera.
I had a similar task, so I boiught used Sony NEX5 on keh.com (w/o lens) for $133, and then bought some aftermarket lens and adapter on ebay for $20. Since I have CNC, making custom polycarbonate case was not that hard.
The narrow option is for video, it does not enlarge the pixels but uses only the center pixels of the 4K sensor. Likewise the 7MP still option does the same while the 11MP uses the entire sensor.
You should be able to make your own housing pretty easily using PVC pipe and acrylic. I made one years ago that worked as deep as 230 ft.
Maybe I should give the GoPro another chance. 'Next nice day, I'll take it out in the kayak and snap some shots of the bottom.
http://www.amazon.com/Pelican-Micro-Snorkelers-Kayakers-clear/dp/B001CNNEXE
Amanda
Not sure I agree with that. When we were using aerial video to peer into eagles' nests looking for eggs it was about impossible to tell if or how many eggs there were using still images, but watching the video playback made the difference. Sort of like trying to see what's on the other side of a wood fence by looking through the gaps. Stand still and you can't see anything, move side to side and the brain can stitch together an accurate image.
I have an SX-150 and have built my own shutter release for use with the CHDK. Acutally buying one will cost $30 USD or more and may not be what you desire. A DIY is less than $5 USD.
I've always had good results with BH, if there is (still) a large camera store in Seattle, they could probably help too. REAL camera stores are getting hard to find. :0 (
I got an SX-150 that uses AA NiMH cells and it is quite delightful. The reviews did complain of the zoom failing to move, but it appears that the problem was simply due to not using NiMH batteries. It works horribly with alkaline AA cells. This also happened to be the last to support a NTSC interface... newer cameras are all a high density TV video interface, HDMI.
I love Canon for supporting so much hacking.... very affordable and open to creativity.
