C code to work with WS2812 NeoPixel LEDs - Page 5 — Parallax Forums
1235»
  • NWCCTVNWCCTV Posts: 3,629
    edited 2015-01-25 16:02
    Here you go.
    edited 2015-01-25 16:12
    NWCCTV wrote: »
    Here you go.
    Thanks. I see the problem. You're not using the ws2812 code that was in the #114 zip file. You're using the code that Parallax posted on their WS2812 product page. That code has a different API from the code that I posted. You'll have to read their documentation to understand how to use this API and modify the code that I posted in #114 accordingly. In this case, it looks like they added additional parameters to the ws2812_init function. I think what they did is remove the code I had for supporting multiple strings of LEDs per COG and replaced it with code that only handles one string at a time.
    edited 2015-01-25 16:13
    At this point my concern is more about getting some different patterns going for Green and Blue. Not real worried about the error message,
    edited 2015-01-25 16:40
    NWCCTV wrote: »
    I'm afraid I'm not good at coming up with interesting patterns. Sorry! Maybe JonnyMac will suggest something. He does this sort of thing for a living!
    edited 2015-01-25 16:46
    Thanks. I was actually just thinking of using JM's driver but I need to modify it to use only Green and Blue. The code in his ws2812 demo would be the perfect pattern. I have tried modifying it but it is not working..
  • JonnyMacJonnyMac Posts: 9,547
    edited 2015-01-26 18:35
    My name is being tossed around like a volleyball -- is there something I can do to help?
    edited 2015-01-26 18:43
    JonnyMac wrote: »
    It's tough being a wizard! :-)
  • Keith YoungKeith Young Posts: 569
    edited 2015-06-02 20:26
    I am not getting dimming to work. I am using the code from Parallax's WS2812 product page https://www.parallax.com/downloads/ws2812b-rgb-led-module-propeller-c-code. Do I need a different library? I'm trying to use _wheel_dim, however the only way to set the colors seems to be _set.
    ws2812_set(driver, LED_PIN, ws2812_wheel_dim(pos,dim), LED_COUNT);
    Hope to have all my stuff in C in time for Mini Maker Faire Ann Arbor this Saturday so I don't have to do so much shuffling. These events get pretty busy.
    Thanks!
    edited 2015-06-03 03:57
    Not sure what you're expecting here. ws2812_wheel_dim() is a passive function, i.e. it just returns an RGB colour value. Said value goes into the colour array (your job) which is then passed to ws2812_set().
    edited 2015-06-03 06:34
    Yep, that's what I'm trying and it won't change the brightness. So I don't know if there are other commands in other libraries like _setx or something where brightness will work.
    So there are some possibilities. A) I'm doing it wrong B) _wheel_dim isn't doing brightness correct C) _set can't set brightness D) ?
    ws2812_set(driver, LED_PIN, ws2812_wheel_dim(pos,dim), LED_COUNT); //This is what I'm doing with pos and dim as integers between 0 and 255.
    edited 2015-06-03 06:49
    I vote A. ws2812_set() expects a colour array as the 3rd argument but you're passing a colour value instead. If you look at ws2812_Demo.c's alternate() function, inside the loop you see the colour array being initialised. This is where you'd apply your dim function, e.g.
    ledColors[0] = ws2812_wheel_dim(pos,dim);
    And I just realised that you posted the call in a previous post. Apologies for not picking up on it earlier.
    edited 2015-06-04 19:53
    That did it. Thanks kuroneko!
