Sticky tape - who makes it?
I need to find out who supplies sticky tapes used commonly in consumer electronics products made in the Far East.
I'm attaching pictures of these tapes shown inside an open tablet and LCD TV.
You can see 2 different kind of those "sticky" tapes. The first one has a distinctly cellophane substrate (shown in BLACK inside the TV chassis holding wires, and of BLUE colour on top of tablet's LiPo battery). These paper thin "cellophane" sticky tapes are commonly used in assembly of just about any electronic gadget to hold wires, and such or building batteries combined of multiple LiPo cells due to their good dielectric properties.
The second sticky tape has kind of fabric substrate (comes in BLK only) and is quite similar to harness type used in automotive, but way better quality and stronger bonding properties to metal surface. You can see it above LiPo battery so it's firmly attached to both plastic case and metal frame.
Both kind of tapes - cellophane and fabric - have excellent glue that makes a strong bond to just about any surface, and without leaving any residue when peeled off.
These tapes are far better than anything available locally but I cannot figure out what brand are they.
So I wonder if anybody knows the name of these products or who's the seller/distributor ?
John
John
http://www.digikey.com/product-search/en/tapes-adhesives/tape/3866785?k=adhesive%20tape
I had a roll of tape #2 in your list, but it was white-yellowish, not black. Brand name was "ken xin da" or "ken xun da", bought it in china years ago, for about $5/roll.
http://www.gorillatough.com/gorilla-tape
I find it has one of the best adhesives on tape. It may be thicker than you want.
As Loopy said, 3M has a gagillion tapes, but some of the industrial products are hard to find if you are not a big company.
I did search aliexpress and even ordered few tapes that looked kind of similar but what I received wasn't even close to what I was after.
Hence my question here...
You might also try Graingers, or a similar industrial supply outlet:
http://www.grainger.com/category/tapes/adhesives-sealants-and-tape/ecatalog/N-856?bc=y
Keep in mind that what a Chinese factory uses for a hold down tape doesn't mean it's a good choice. Some of the tape you posted looks to have a cloth backing, which could absorb moisture. OTOH, it will likely keeps is gummy adhesive qualities under higher heat.
A problem with buying these industrial tapes is industrial quantities. A roll can easily cost $300+, because of the amount you get. For somewhat lower quantity buys, you might also try Uline:
http://www.uline.com/Cls_27/3M-Tapes
Made in China is not all the same...
Made in China for export often has excellent quality control.
Made in China for the general public is 'anything goes'.... this includes all the EBay and Alibaba ticky-tack.
Something that is a component in a high quality control product is usually restricted to use in an export manufacturing zone. Where it comes from and how to get it is rather complicated.
Even here in Taiwan, we have export manufacturing zones that produce products that go all over the world, but are not in the local marketplace.
(The Google "images" of "kapton tape" are interesting)
I have not used it myself, just saw references to it.
So use with your own discretion.
I found the following Google results helpful:
http://reprap.org/wiki/Kapton_Tape
http://en.wikipedia.org/wiki/Kapton
http://kk.org/cooltools/archives/7304
Reprap indicates that there is a Safety Risk (the tape should be tested for fire resistance).
Reprap also indicates that fake Kapton is being sold.
Wikipedia indicates that Kapton insulation ages poorly and
has very poor resistance to mechanical wear.
Search for "1 Mil Kapton Tape (Polyimide) - 1" x 36 yds" on amazon.com.
You will find a variety of widths mostly with good reviews.
Unfortunately, many distributors list tapes neither with much technical information nor with traceable part numbers.
I do agree with the comments about Goop plastic adhesives, E6000 say is indispensable for tacking things down and for strain relief.
Tapes generally don't fair too well over the long term in areas like outdoor cabinets where they are subjected to wide temperature extremes. Aging characteristics. We've all found embrittled tape in old radios.
http://www.mcmaster.com/
Every schoolboy knows that sticky tape grows on trees just like spaghetti. As we see in this documentary video by the BBC: https://www.youtube.com/watch?v=tVo_wkxH9dU
You just have to have the right kind of tree, climate, and soil
Enjoy.
You've made my day as it's exactly what I was looking for !
Love this "distinctly European flavour"
