Trouble with multiple instances of FatEngine
Hi guys, I'm sure this has been answered before but my google foo just isn't working.
I'm trying to log up to 4 serial inputs to independent files. So I have fullduplexSerial4port + 4 instances of FatEngine. Launch a cog to read each serial stream and write to a file. I think everything is right, up to closing the file... Now when I do a capture, I end up with a corrupted SD card?
*edit*
It actually looks like I'm having problems with the name array now!
CON Stuff
_clkmode = xtal1 + pll16x
_clkfreq = 80_000_000
' pins and stuff
_RXn1 = 0
_TXn1 = 1
_BAUDn1 = 115_200
_TRn1 = 15
_n1 = 0
_RXn2 = 2
_TXn2 = 3
_BAUDn2 = 115_200
_TRn2 = 14
_n2 = 1
_RXbase = 4
_TXbase = 5
_BAUDbase = 115_200
_base = 2
_button = 13
_numOfPorts = 3
_stackSize = 250
obj
fat[3] : "SD-MMC_FATEngine.spin"
pins : "pins.spin"
ser : "FullDuplexSerial4portPlus_0v3"
VAR
long stack[_numOfPorts * _stackSize], runFlag[_numOfPorts]
byte cog[_numOfPorts]
DAT
fileNptrs long @filename1, @filename2, @filename3, @filename4
filename1 byte "Log000s1.csv", 0
filename2 byte "Log000s2.csv", 0
filename3 byte "Log000s3.csv", 0
filename4 byte "Log000s4.csv", 0
PUB Run
pins.updateTicks
dira[27..26] := %11
outa[27..26] := %10
ser.init
ser.AddPort(_n1,_RXn1,_TXn1,ser#PINNOTUSED,ser#PINNOTUSED,ser#DEFAULTTHRESHOLD,ser#NOMODE,_BAUDn1)
ser.AddPort(_n2,_RXn2,_TXn2,ser#PINNOTUSED,ser#PINNOTUSED,ser#DEFAULTTHRESHOLD,ser#NOMODE,_BAUDn2)
ser.AddPort(_base,_RXbase,_TXbase,ser#PINNOTUSED,ser#PINNOTUSED,ser#DEFAULTTHRESHOLD,ser#NOMODE,_BAUDbase)
' one more port if we want
ser.start
outa[27..26] := %01
repeat while ina[_button]
outa[27..26] := %11
fat.FATEngineStart(pins#_DOPin, pins#_CLKPin, pins#_DIPin, pins#_CSPin, -1, -1, -1, -1, -1)
outa[26] := 1
dira[27] := 0
Start
repeat until ina[_button]
pins.pause1ms(1000)
Stop
outa[26] := 0
repeat
waitcnt(cnt)
PUB Start | n
repeat n from 0 to (_numOfPorts - 1)
runFlag[n] := true
cog[n] := cognew(Ser2SD(n),@stack[n * _stackSize]) + 1
PUB Stop | n
repeat n from 0 to (_numOfPorts -1)
if cog[n] ' if driver is running
runflag[n] := false
pins.pause1ms(5000)
fat.unmountPartition
pins.pause1ms(1000)
fat.FATEngineStop
PUB Ser2SD(port) | b[128], n, c
fat[port].mountPartition(0)
fat[port].newFile(fileNptrs[port])
fat[port].openFile(fileNptrs[port], "W")
n := 0
repeat while runFlag[port]
if (c := ser.rxcheck(port)) <> -1
b.byte[n ++] := c
if c == 13 or n == 512
fat[port].writeData(@b, n)
n := 0
dira[27] := 1
outa[27] := 1
pins.pause1ms(100)
dira[27] := 0
fat[port].writeData(@b, n )
fat[port].closeFile
cogstop(cogid)
*edit*
Sure enough! That fixed it.
obj fat[_numOfPorts] : "SD-MMC_FATEngine.spin" pins : "pins.spin" ser : "FullDuplexSerial4portPlus_0v3" VAR long stack[_numOfPorts * _stackSize], runFlag[_numOfPorts] byte cog[_numOfPorts] DAT fileNptrs long @filename1, @filename2, @filename3, @filename4 filename1 byte "Log000s1.csv", 0 filename2 byte "Log000s2.csv", 0 filename3 byte "Log000s3.csv", 0 filename4 byte "Log000s4.csv", 0 PUB Run pins.updateTicks dira[27..26] := %11 outa[27..26] := %10 ser.init case _numOfPorts 3 : ser.AddPort(_base,_RXbase,_TXbase,ser#PINNOTUSED,ser#PINNOTUSED,ser#DEFAULTTHRESHOLD,ser#NOMODE,_BAUDbase) ser.AddPort(_n1,_RXn1,_TXn1,ser#PINNOTUSED,ser#PINNOTUSED,ser#DEFAULTTHRESHOLD,ser#NOMODE,_BAUDn1) ser.AddPort(_n2,_RXn2,_TXn2,ser#PINNOTUSED,ser#PINNOTUSED,ser#DEFAULTTHRESHOLD,ser#NOMODE,_BAUDn2) ' one more port if we want 2 : ser.AddPort(_base,_RXbase,_TXbase,ser#PINNOTUSED,ser#PINNOTUSED,ser#DEFAULTTHRESHOLD,ser#NOMODE,_BAUDbase) ser.AddPort(_n1,_RXn1,_TXn1,ser#PINNOTUSED,ser#PINNOTUSED,ser#DEFAULTTHRESHOLD,ser#NOMODE,_BAUDn1) 1: ser.AddPort(_base,_RXbase,_TXbase,ser#PINNOTUSED,ser#PINNOTUSED,ser#DEFAULTTHRESHOLD,ser#NOMODE,_BAUDbase) ser.start outa[27..26] := %01 repeat while ina[_button] outa[27..26] := %11 Start repeat until ina[_button] pins.pause1ms(1000) repeat while ina[_button] Stop repeat waitcnt(cnt) PUB Start | n fat.FATEngineStart(pins#_DOPin, pins#_CLKPin, pins#_DIPin, pins#_CSPin, -1, -1, -1, -1, -1) outa[26] := 1 dira[27] := 0 repeat n from 0 to (_numOfPorts - 1) runFlag[n] := true cog[n] := cognew(Ser2SD(n),@stack[n * _stackSize]) + 1 PUB Stop | n repeat n from 0 to (_numOfPorts -1) if cog[n] ' if driver is running runflag[n] := false pins.pause1ms(5000) 'pins.pause1ms(1000) fat.FATEngineStop outa[26] := 0 PUB Ser2SD(port) | b[128], n, c fat[port].mountPartition(0) fat[port].newFile(@@fileNptrs[port]) fat[port].openFile(@@fileNptrs[port], "W") n := 0 repeat while runFlag[port] if (c := ser.rxcheck(port)) <> -1 b.byte[n ++] := c if c == 13 or n == 512 fat[port].writeData(@b, n) n := 0 dira[27] := 1 outa[27] := 1 pins.pause1ms(100) dira[27] := 0 fat[port].writeData(@b, n ) fat[port].closeFile fat[port].unmountPartition cogstop(cogid)This works, but I don't like the idea of using static names. What I'd like to do is have a name prototype, say "log"xxx"p"x".csv" and have the filename increment. I think the key is listEntry(entryPathName) but haven't quite wrapped my head around it.
