Hardware Heads: How do you clear the counters PLL dividers ?
Bean
I thought that setting PHSA to zero would clear the PLL dividers, but it doesn't seem to do that.
Does setting the counter mode clear them ? Or are they free-running and are not cleared by any operation ?
I'm trying to sync the counter outputs from two different cogs where the hardware counters are using the PLL modes.
Bean
Bean
Bean
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 FRQ = $0800_0000 VAR long freq PUB start freq := FRQ cognew(@pll0, @freq) cognew(@pll1, @freq) DAT org 0 pll0 mov dira,#1 mov ctra,ctra0 rdlong frqa,par :forever jmp #:forever ctra0 long %00010000 << 23 | 0 '_______________________________ org 0 pll1 mov dira,#6 mov ctra,ctra1 rdlong frqa,par mov ctrb,ctrb1 mov time,cnt add time,dt mov frqb,#1 :lock_lp waitcnt time,dt mov acc,phsb wz mov phsb,#0 if_z jmp #:locked shl acc,#4 add frqa,acc sub frqa,acc jmp #:lock_lp :locked mov outa,#4 :forever1 jmp #:forever1 ctra1 long %00010000 << 23 | 1 ctrb1 long %10110 << 26 | 0 << 9 | 1 dt long $10000 time res 1 acc res 1The output on P1 locks to the output on P0. Once locked, P2 raises.
