Hardware Heads: How do you clear the counters PLL dividers ? — Parallax Forums
BeanBean Posts: 8,129
edited 2015-01-13 14:06 in Propeller 1
I thought that setting PHSA to zero would clear the PLL dividers, but it doesn't seem to do that.
Does setting the counter mode clear them ? Or are they free-running and are not cleared by any operation ?
I'm trying to sync the counter outputs from two different cogs where the hardware counters are using the PLL modes.
Bean
    edited 2015-01-13 11:25
    I don't know of any way to clear the PLL counters explicitly. It's probably easiest just to adjust the frequency of one until the edges coincide. Are both output frequencies the same, or is one a multiple of the other?
    edited 2015-01-13 11:28
    The counter output syncs to the rising edge of the NCO feeding the PLL. This means you can easily sync the PLL output (across cogs) for dividers 1..16. I haven't seen a workable solution for dividers 32..128 yet (e.g. /128 can lock to any of the 8 rising NCO edges one of its cycles covers).
  • BeanBean Posts: 8,129
    edited 2015-01-13 11:36
    Thanks, Kuroneko. That makes sense with what I am seeing.
    Bean
    Here's a program that works with the higher divide ratios:
    CON
      _clkmode = xtal1 + pll16x
      _xinfreq = 5_000_000
      FRQ      = $0800_0000
    VAR
      long  freq
    PUB start
      freq := FRQ
      cognew(@pll0, @freq)
      cognew(@pll1, @freq)
    DAT
                  org       0
    pll0          mov       dira,#1
                  mov       ctra,ctra0
                  rdlong    frqa,par
    :forever      jmp       #:forever
    ctra0         long      %00010000 << 23 | 0
    '_______________________________
                  org       0
    pll1          mov       dira,#6
                  mov       ctra,ctra1
                  rdlong    frqa,par
                  mov       ctrb,ctrb1
                  mov       time,cnt
                  add       time,dt
                  mov       frqb,#1
    :lock_lp      waitcnt   time,dt
                  mov       acc,phsb wz
                  mov       phsb,#0
            if_z  jmp       #:locked
                  shl       acc,#4
                  add       frqa,acc
                  sub       frqa,acc
                  jmp       #:lock_lp
    :locked       mov       outa,#4
    :forever1     jmp       #:forever1
    ctra1         long      %00010000 << 23 | 1
    ctrb1         long      %10110 << 26 | 0 << 9 | 1
    dt            long      $10000
    time          res       1
    acc           res       1
    The output on P1 locks to the output on P0. Once locked, P2 raises.
