Stuck on the Array Variables page of the Simple IDE tutorial
Hi, I am going through the Simple IDE tutorial with my daughter, getting up to speed on programming the Activity Bot in C. Everything has worked perfect up until this point. Sorry this is probably so elementary that I must be missing something very obvious,
but we can't seem to make the last part of the Index Array Variables page work right. The page is here: http://learn.parallax.com/propeller-c-start-simple/index-array-variables and it's the last part down at the bottom, where it says:
"Write a program that multiplies each array element by 100 and then stores the result back to the array element. Then, have a second loop display all the values. If you did it right, that second loop should display 100, 200, 300, 500, 700, 1100, etc."
Is there a C language reference page somewhere that I can access to figure out how to address the data of the array in a second line of code correctly?
Thank you for the help!
I will try your suggestion and see what I get back.
