Anyone used the MLX90316 Hall Effect Position Sensor IC or similar?
http://www.melexis.com/Position--Speed-Sensors/Triaxis%C2%AE-Hall-ICs/MLX90316-566.aspx
I am looking for a solution to do the following for use with a Propeller:
A metal knob (or dielectric material that can be used for touch sensitive IC like Qprox capacitive).
The knob will need infinity rotation, no detents, smooth rotation with ball bearings or similar very smooth feel.
A magnet attached to the end of the shaft that the knob sits on.
A Hall effect position sensor IC ie the MLX90316 or I2C variant preferred.
The goal is to touch the knob, which clears any angular output to 0.
If you touch the knob, the Propeller will tell the GUI that the knob has been "touched" and the GUI will be set to read inc/dec values starting at 0.
If you turn the knob to the RIGHT, you get an output by any measure that can be used to tell a GUI that there is some increment amount.
If you turn the knob to the LEFT, you get an output by any measure that can be used to tell a GUI that there is some decrement amount.
If you remove your finger from the knob, the output goes back to 0(Qpox or other method detects touch removed),
and the Propeller will tell the GUI that the knob has been "released"
One question is, if you reset the Hall Sensor, does the angular value reset to 0. I assume this is true, since the device appears to use "relative" angular change, based on the starting point.
Next, does the IC have a center detent value, so that there is + and - capability for angular change ie 0 to 180, 0 to -180. If not then hopefully there is a way to have the Prop convert the negative angle to a decrement output.
The last thing to handle is, how to get a metal knob to conduct through a shaft and ball bearing. I will test the conductiveness today from the ID to the OD of a sealed ball bearing. There is grease inside the ball bearings, but it is possible that the housing and shield will be conducting.
A quad encoder knob would be ideal except all the ones I have seen have detents, if anyone knows of a type that does not have detents and is continuous rotation, that would be nice to see. The issue with a pot or rotary encoder is how to get a wire attached to the metal knob. The path through a bearing seems doable.
Any thoughts or suggestions appreciated. There could be an easier approach to getting an inc/dec value than, especially since I don't care about angles, only that I can output a inc/dec value proportional to the rotation, and scale the rotation to the resolution of output as needed. For example, I may want to turn 1 degree for +1, or turn 10 degrees for +1, the Prop code will have methods select what the output scale is as needed.
Edit: A standard sealed bearing reads all over the map from 1ohm to meg ohm as you turn it. So this concept of Qprox reading through the bearing to the knob has to be rethought.
I haven't used those particular sensors but after reading a bit about them, I'm pretty sure the sensor doesn't reset its angular value to zero. But this should be very easy to do in software.
I've used these AMS5055 sensors.
I think post #24 of the software thread has the best video of that particular thread.
The image above is from the hardware thread.
My guess is the device gives you a 12-bit angular position value. You'd need to keep track of the change in value to figure out if it's incrementing or decrementing.
Agreed.
It looks like the Melexis sensor requires diametrically magnetized magnets. These are different than the commonly available round magnets.
At power up or after no movements a software counter use current hardware degree the new 0 soft degree.
I like the resolver, I will research that idea. The problem still remains of having a touch sensitive knob that is infinity turns so it does not require reset. I will also test an idea of a non sealed ( exposed ) ball bearing and conductive grease. This may give a consistent resistance through from a fixed shaft through the bearing to the metal knob.
http://www.mcmaster.com/#1219k57/=vcr131
http://www.mcmaster.com/#standard-ball-and-roller-bearings/=vcr33s
