Propeller 1-2-3 FPGA PCB on Pick-n-Place — Parallax Forums
Ken GraceyKen Gracey Posts: 7,419
edited 2015-04-05 18:32 in Propeller 1
The Propeller 1-2-3 FPGA PCB is now on the Pick-n-Place SMT line. This four-layer board uses 75+ feeder locations and places components on both sides of the PCB.
Will keep everybody posted on the initial results.
    edited 2015-01-05 10:39
    Cool! I guess they will appear in the Parallax store soon. :-)
    edited 2015-01-05 10:40
    Ken,
    Is this the first BGA that you have done?
    edited 2015-01-05 10:43
    Hey Jim -
    No, we've placed these before on prior FPGA boards. The solder stencil process and reflow profile are the most complex aspects of dealing with BGAs. They're potentially troublesome like QFNs, but we'll succeed.
    edited 2015-01-05 10:52
    Of course, I should have looked closely at the previous product.
    http://www.parallax.com/product/60050
    Much success!
    edited 2015-01-05 11:06
    Publison wrote: »
    Much success!
    Actually, that board is built by Terasic in Taiwan. I'm having trouble inserting images into this message (we're meeting at lunch about our forum repair/upgrade), but do a Google for "Parallax Cyclone FPGA" or "Parallax FPGA Altera QuickStart" and you'll find our prior FPGA assemblies.
    You see, enough time goes by and we forget how complicated it is to build these boards, and we find ourselves right back at the P&P doing it again :)
    edited 2015-01-05 11:37
    Ken Gracey wrote: »
    So I'm guessin' it was the one I found on the 2009 CD:
    500 x 523 - 54K
  • TubularTubular Posts: 4,768
    edited 2015-01-05 13:07
    Very exciting news.
    I like the name, hopefully P3 is an easier process as a result of having this
  • jmgjmg Posts: 15,199
    edited 2015-01-05 15:14
    Ken Gracey wrote: »
    What range of FPGAs will this support ?
    First choice I see is the A7, but does the PCB design also support fitting of smaller FPGAs ?
    edited 2015-01-05 16:13
    Fantastic!
    Looking forward to their availability.
    edited 2015-01-05 16:41
    Ken Gracey wrote: »
    Thanks Ken
    (just inserted photos inline for easier view)
    edited 2015-01-05 17:13
    Thanks Ken
    With our newly-broken forums I'm unable to figure out the steps to do this. Can you tell me how to do this?
  • JonnyMacJonnyMac Posts: 9,566
    edited 2015-01-05 17:19
    You need to open the image, then copy the URL. Put that between [ img ] tags.
    Testing:
    edited 2015-01-05 19:20
    Or just right click on the download in the preview screen, and click "copy link address." Then paste that between [noparse]and[/noparse] tags.
  • T ChapT Chap Posts: 4,260
    edited 2015-01-05 19:34
    What is the setup time for a board on that machine? When you say troublesome, do you mean the QFN's require rework?
    edited 2015-01-05 21:12
    T Chap wrote: »
    Hey T Chap!
    The setup time on the P&P for this particular board is about two full days of loading parts on feeders. This includes time required to cycle count the parts and check inventory prior. The programming of the P&P for this board is at least three days, so we're into this five days before we actually press the green button.
    QFNs require precise placement on the PCB and require more attention to reflow oven temperature profiles.
    edited 2015-01-06 00:51
    Ken Gracey wrote: »
    That sounds a lot of time ?
    Better PCB design packages should be able to create an almost machine ready placement file, referenced to any point you choose.
    The only unknown from the PCB design CAD info, is the relative Decal to Tape rotation fix-up, usually one of 4 90' choices.
    That can be managed with a Part attribute, so as you learn the Decal to Tape rotation for each SMD part, it can not need manual entry next time.
    (likewise for Z info, if that is needed too)
    edited 2015-01-06 21:55
    Many pcb houses don't use flat pcb stock so, unless you preflatten your pcbs, ,,, .... qfn is teh suxor.
    You can see this if you take a stack of pcbs and restack them, but flip every other pcb.
    I found qfns were problems with too little solder paste, those legs suck up lots of solder.
    Rarely did I have bridges, but often I had a floating leg due to a lack of paste combined with pcb flex.
    I can spot a solder bridge with my bare eyes on this pitch.
    But if it had a loose leg there was virtually no way to notice, save for the missing ski slope solder.
    Even ones that had no slope were welded, so it wasn't a good indicator, but the entire pcb would fail a JEDEC/IPC inspection due to a lack of paste.
    Coarse teh bozz didn't see it that way. (apparently solder paste is expensive)
    Parallax, you've come full circle.
    This pcb is dated 2003.
    1024 x 576 - 470K
    cyc1.jpg 469.8K
    edited 2015-01-07 00:26
    Ken, as always, I am at your disposal should the need arise.
    edited 2015-01-07 05:29
    hopefully the price will be lower than $600.00 At least low enough to get it past the controller. The one with the diamond that is........
    edited 2015-01-07 08:27
    @Frank: Start mooching little bits of money now. Then the "big ask" is much smaller. Just tuck it away...
    I've already started skipping coffees. Got $50 already. By the time Parallax gets this done, I'll be a big chunk of the way there.
    Since I got the DE2 on academic, I'm stuck with it. What I'll probably do is find a student somewhere, who I can trust not to sell it and keep the agreement with the nice vendor, who let me in cheap.
    edited 2015-04-05 16:18
    Is this available yet? I see Brian down in OZ did a benchmark with it.
    edited 2015-04-05 16:21
    Publison wrote: »
    I thought that at first too but I wonder if he just set the Altera tool to target the same FPGA chip that Parallax is using to get those numbers.
    edited 2015-04-05 16:30
    David Betz wrote: »
    Maybe he got a one-off from the January run? They looked like they where going to run a few through Pick-Place and reflow.
  • evanhevanh Posts: 17,033
    edited 2015-04-05 16:39
    Publison wrote: »
    Hehe, maybe. I don't so, though. He just did a sizing exercise, as David suggests there's no requirement to even load a chip up for that.
    Correct. I don't have one, but I am waiting for their release like you guys. :)
