Motor Mount & Wheel Kit - Wheels Loose
I am building a robot using the Motor Mount & Wheel Kit. I find that after the robot has driven around for a while the screw attaching the wheel to the motor shaft has loosened up for each motor. I have tried inserting a split ring washer onto each screw but this has not made much of a difference. Ay suggestions for stopping the screws coming out?
I lost one of my original 1/4" bolts to hold the wheel in place (it's on my lab floor somewhere). I used a nylon bolt as a replacement and it seems to hold its position better than the metal bolt. It doesn't look as nice as the original bolt though.
Very good. I like this idea. No mess to deal with.
Do you have the drive pins engaged into the slot on the wheel hub? If you cinch them down tightly, they should not allow the bolts to spin at all (to work their way out).
-MattG
