Prop activity board power switch issue
My 3-day old prop activity board now powers the servo pins when the power switch is set to the "1" position. In fact, both the "1" and "2" LED's light up when the one position is selected.
I see in the help file that this can be caused by re-positioning the jumpers while the board has power. Since I didn't do that, I wondering what is up. Since this issue is specifically mentioned in the help file, I'm thinking that it's not an isolated issue???
More importantly, I'm wondering how it can be repaired, or I should say how I can repair it. I realize that it doesn't cost all that much, but I'd rather fix it than just replace it since it's so new.
Thanks in advance for thoughts/suggestions,
John
John
I'll contact tech support.
Cheers,
John
