Reflow oven controller kickstarter
I know it an Arduino but it's really nice.
https://www.kickstarter.com/projects/1070729460/zallus-oven-controller
Looks nice for the price. wonder which toaster ovens it has been checked with.
http://www.zallus.com/msp430-reflow-oven/
[FONT=Helvetica, Helvetica, serif]
[/FONT]
I know there have been several Propeller controlled reflow ovens.
Our kitchen oven is controlled by a Propeller chip and I've used a Propeller to control a toaster oven to dry ore samples (as part of a chemical test) but I have yet to make a reflow oven.
I think the main appeal to having a reflow oven Propeller controlled is it will be easier for me to modify the code.
I don't recall who all have Propeller controlled reflow ovens. Maybe they'll remind us?
Edit: Or we could look in the "Similar Threads" section.
Too bad it isn't a propeller chip though.
Still interested to make a prop oven just for the fun of it, but too many other projects unless someone does the prop code.
I am still working on mine. But because of everything going on, I can't work on it like I want.
a sensible soaking temperature.
Place board, set to to soak, wait 2 or 3 minutes (longer if large thermal masses on the board), crank to max and
watch carefully till all the paste has reflowed across the board, turn off. The temperature rise and fall curves
should be reasonable and the reflow temperature is more accurately judged by eye than thermocouple (which
can never be exactly the same as the board temperature anyway).
Its only for production runs that temperature control matters really...
