Gun for robot
I'm looking for ideas for an inexpensive ($40 max) semi-automatic gun to mount on my robot, powerful enough to knock over empty pop cans at about 6 feet but safe to use indoors. Needs to be able to be triggered by a small relay circuit or something.
Weight is no problem up to about 5 pounds (big robot). I would like it to shoot a grouping of less than 6 inches @ 6 feet. Sighting would be a laser and aiming by turning robot. The whole thing is remotely controlled (wireless via camera displayed on TV.
Except for the gun all is built and working.
Aaron
Aaron
http://www.hasbro.com/nerf/en_us/
About the only other gun I can think of is a repeating paint ball gun. Maybe you can get ammunition that does not include the paint and can reduce the air pressure to suit you. You might have to find something used to fit your budget.
Jim
I've used something like it (toy models come and go) with a standard RC servo for the trigger pull. It works fine. You may need to play around on the linkage to maximize the mechanical advantage. It's all basic levers.
I also tried various disc and foam pellet shooters from the dollar store. Junk. Spend a few bucks for something decent. The cheap toys aren't very aerodynamic, so things fly out everywhere.
http://forums.parallax.com/showthread.php/139293-S2-Marauder-12-shot-Semi-automatic-...?highlight=Rubber%2C+Band
erco also made one with laser targeting. Will find the post.
EDIT: Found it.
http://forums.parallax.com/showthread.php/149626-The-Terminator?p=1200798&viewfull=1
I modified ours a bit to make it easier to use with either an external power supply or with a 3-cell LiPo pack. I heard the guns can burn through D-Cells pretty fast and I didn't want to spend my money on disposable batteries.
I'm pretty sure these have been used with robot projects but I don't recall any off the top of my head.
I did find this robot with a Nerf gun.
My students became crazy with joy when they saw the video of S2 marauder!
I would like to use it on my school projects.
Does palallax sell this product? I remeber I had seen it somewhere, but I can't find it now
