Propeller controlled Rover 5 bot.
I started a new project/bot. I've always wanted a rover and choose the dagu rover 5 platform. I've built tons of hex's and quad's, but no rovers. I picked this bot up on a cyber Monday deal along with the dagu motor controller. I just got it this sat and started working on it... my progress so far.
I'll be using an ax-12 arm and the arm has a standard servo gripper. I'm combining several bots I've built into one platform. I have lots of working parts just bringing them together.
Pics of my current progress attached, making acrylic decks tomorrow and will update in a day or so.
PK
PK
Something really impressive. Paul doesn't do anything half-Smile. That's MY job!
Can't wait to see what you do with it, Paul!
I did make the board. Its a revised version of http://forums.parallax.com/showthread.php/126747-Propeller-Based-IK-Hexapod-Project. I made that years ago but still use them in my crawler type bots but I'm updating all of them to XBee instead of PS/2 controllers.
I made the Q-RX to compliment with the controllers I use. Some of the board specs: 24 Servo connections via a 4.7K resistor, those same pins have a connection available before the resistors, 2 Bioloid busses, for the AX-xx series servos TTL versions, 3.3V & 5V connections for sensors & power support for add on boards, Xbee, & SDA & SCL connections. I choose no USB on this board because I plan to use them in all my bots and its cheaper to buy the USB to serial then make each board USB. I just got the boards in from Golden Phoenix I still need to test them out. I found one issue, I switched the power and ground on the AX connectors which is a quick fix. Its an easy fix to make in Diptrace and I made a cable in the mean time where I just swap the pins. I picked up all the parts thru Digikey to make the Bioloid cables.
I have new pics posted below. I'll post new pics of the wiring job & vids when I get this bot up and running.
The last pic is with the arm attached. Now I need a couple of days to wire and program the bot. Then make it move.
PK
No trust Paul K.
erco's work space is cluttered with ebay bargains!
I've won a contest or two from Parallax and including those prizes into the bot. I included a GPS from a package a got from Matt. It's the PMB-648SiRFGPSInt Antenna and it worked right away from the code posted on learn portion of the parallax site. I plan to add a gyro & acc. aswell.
Some progress pics.
The last pic has everything wired up, I took off the arm as I need to make leads. longer. Working on that tonight.
Whit I've bought a couple of those buys and Erco should start his own Uncle Erco's(Uncle Henry's). It's from a show on history channel.
