What wattage of laser is needed
NWCCTV
I have been thinking of making my own CNC Laser table. What wattage of laser would be required to cut through up to 1/3 inch sheet plastic and are there special licenses required for this?
The only licensing might be how you deal with any out gassing from the laser process.
For more details/info, go to this link for the Epilog Manuals:
https://www.epiloglaser.com/tech-support/laser-manuals.htm
Open the 4th link for the Legend EXT Manual and read section 13. It has very good tips on power and speed settings as well as several pages of recommended settings for various materials on their lasers ranging from 30 watts up to 75 watts.
Anyway, what type of plastic are you wanting to cut, Andy? You know that some, like PVC, emit noxious and corrosive fumes when burned. Make a habit of cutting this stuff and your laser will be gone within the week.
I'm guessing the "license" you're talking about is FDA laser labeling and laws? You can read about that here:
http://www.fda.gov/Radiation-EmittingProducts/RadiationEmittingProductsandProcedures/HomeBusinessandEntertainment/LaserProductsandInstruments/default.htm
In addition, most states have their own safety requirements, though usually related to the practice of lasers on humans -- eye surgery, tattoo removal, physical therapy, and so on.
No licenses required - at least if there are any, then I have been in violation for quite some time.
If you are serious about building one I have an unused 80W Reci tube, power supply, main board and LCD control panel...
@Gordon, I was not planning on cutting PVC or anything else that could be hazardous. I will be implementing an air and filter system before even firing it up. Possibly a water type filter system such as those used in some paint booths.
I know you mean the other Andy, but in regards to plastics that I cut: Delrin and other acetals, ABS, thin lexan or polyethylene, Acrylic, and Styrene, but never PVC.
No licensing required.
Well, I don't know... I could use some security camera related stuff so maybe we could work out a trade of some sort.
Safety first here! Commercial laser cutters diverge and parallelize the laser beam for steering, then converge it to a point at the last instant with a convex lens. This is important, because an undiverged beam, reflected off of a metallic surface, can cause extensive biological damage. A converged beam, OTOH, will rediverge beyond the focal point to a less damaging intensity. You should also install an IR-blocking lid with safety interlocks to turn off the laser beam when the lid is open.
