Hydra Sources CD? — Parallax Forums
Hydra Sources CD?
edited 2014-12-03 11:57 in Propeller 1
Has anyone still got a Hydra Sources CD they wouldn't mind sharing? I only need the Hydra sources folder which is mostly spin code and a few graphics, etc.
As I understand it, the code is now open source so licensing isn't an issue, and the code can be shared.
Thank you in advance,
Jeff
    edited 2014-12-02 20:22
    Here's the Hydra Sources Folder as a zip file.
    The link is to my Dropbox.
    There might still be a link on Parallax's site somewhere.
    Edit: I don't think the folder is available from Parallax anymore. I followed the second link in the Similar Threads section but found the folder missing.
    Make sure you also have the Hydra Manual. It has great information. I'll try to find a link.
    Edit again: Here's the Hydra Manual (warning, large pdf).
    I've removed the Hydra Sources Folder from my Dropbox. See link in post #3 for alternate location.
    edited 2014-12-03 03:27
    The Hydra CD is also available on Andre's site, (at the bottom of the page)
    http://www.xgamestation.com/view_product.php?id=33
    edited 2014-12-03 09:32
    I also asked Andre to include the DVD download for the C3Synapse on his new web site:
    http://www.ic0nstrux.com/c3-synapse?filter_name=C3#.VH9IwTHF_To
    which he graciously supplied.
    edited 2014-12-03 09:59
    Publison wrote: »
    Thanks for the link.
    I'm removing the large file from my Dropbox. I'll move it back if anyone has trouble with Andre's site.
  • blittledblittled Posts: 697
    edited 2014-12-03 10:40
    I made up a DVD with the Hydra, Hydra SD Card Expansion, Hydra Memory Expansion and the Chameleon-PIC files. If you need a copy of that Jeff, PM me and I'll send it to you. I don't think my drop box is big enough to hold it.
    Got that Dropbox link before you moved it! That's what I needed Thank you.. All of you!
    I had poluted my copy with far too many changes over the years and needed a fresh backup.
