Hydra Sources CD?
Has anyone still got a Hydra Sources CD they wouldn't mind sharing? I only need the Hydra sources folder which is mostly spin code and a few graphics, etc.
As I understand it, the code is now open source so licensing isn't an issue, and the code can be shared.
Thank you in advance,
Jeff
Jeff
The link is to my Dropbox. There might still be a link on Parallax's site somewhere.
Edit: I don't think the folder is available from Parallax anymore. I followed the second link in the Similar Threads section but found the folder missing.
Make sure you also have the Hydra Manual. It has great information. I'll try to find a link.
Edit again: Here's the Hydra Manual (warning, large pdf).
I've removed the Hydra Sources Folder from my Dropbox. See link in post #3 for alternate location.
http://www.xgamestation.com/view_product.php?id=33
http://www.ic0nstrux.com/c3-synapse?filter_name=C3#.VH9IwTHF_To
which he graciously supplied.
Thanks for the link.
I'm removing the large file from my Dropbox. I'll move it back if anyone has trouble with Andre's site.
I had poluted my copy with far too many changes over the years and needed a fresh backup.
