HP Stream 7 & No Propeller found
Wildatheart
I managed to pick 2 Stream 7s at the local Office Max yesterday for $79. The Parallax USB driver V2.10.00 installed successfully on the Stream tablet, however when activating Identify Hardware No Propeller is found on COM x.
My Sony convertible connected to the same Parallax Professional Development Board with the same cable works just fine. Both the Sony and the Stream are running Windows 8.1 and the only difference in the cable is that a USB micro male to USB A female adapter is added to connect to the Stream.
Neither TX or RX lights when Identify Hardware is pressed. Reinstalling the Parallax driver made no difference. Any idea what I should be doing differently?
FWIW, I've connected a few different flash drives, a couple USB-RS232 adapters and even a Sierra Wireless / AT&T modem and an external hard drive to my tablet without significant issue... using the OTG cable.
Also, some tablets have Bluetooth hardware, and possibly COM port redirects to virtual printers and such, so those may claim COM ports and prevent auto-detection in a program to fail. I ran across this issue with my tablet and a USB/RS232 adapter getting assigned a port number beyond what the program was programmed to detect, so had to manually re-assign the port, and everything was fine afterwards.
I tested with the Radio Shack LCD project which also involved powering the Prop ASC from the Stream on batteries. That worked fine too.
How I wish phones and tabs would bring out those UARTs for us to use.
http://www.sharkscove.org/wp-content/uploads/2014/08/Sharks-Cove-Developer-Guide.pdf
that the Atom has UART on chip ready to be brought out to a header. I guess Windows discovers this hardware and installs the driver, which is a Windowsy kind of thing to do, even if it's not brought out to the outside world.
Edison has an Atom 32 bit Dual-Core with UARTs and other stuff. My Quickstart works in the OTG port after fumbling around with yacto embedded linux. Building a BoardOfEdison-Bot (BOEBOT) today ....
I never expected to see a PC (tablet) cost less than its' keyboard. Paid 79 bucks for the tablet and a whopping 99 bucks for the 'lil Microsoft Bluetooth keyboard. Something doesn't seem right about that. But it sure makes a nice portable package that connects with Parallax boards.
Thanks for the advice.
OTG and Parallax dev board....
