Plane mounted Laser guns - Darpa
http://gizmodo.com/this-is-what-plane-mounted-laser-guns-could-look-like-1663777440
DARPA is going gaga over the pew-pew. The department just awarded a Northrop Grumman a $20.2 million contract to begin the second phase of its Excalibur Programone which aims to give the same kind of missile-frying laser cannon that's currently patrolling the Persian Gulf to America's Air Force.
You look at the size of the existing laser systems America has fielded in the past few yearslike the HEL-MD and the laser aboard the USS Ponceand they're all enormous. What's more, they require massive amounts of power to operate. So shrinking all these bits down (along with a means of driving them) into a package that can fit under the wing of an aircraft or even a drone (DARPA's looking to eventually put these systems on Predators and Reapers because duh) is no easy feat.
http://www.ebay.com/itm/100pcs-mini-650nm-6mm-3V-5mW-Laser-Dot-Diode-Module-Head-WL-Red-/261455283189?pt=LH_DefaultDomain_0&hash=item3cdff303f5
would it take to build this onto our drones?
We might have to get one or two additional LiPO's I imagine.
If so, DARPA owes me a buck!
I doubt it...
http://gizmodo.com/this-mortar-hunting-war-truck-just-got-a-powerful-new-l-1482647200
The The Army's High Energy Laser Mobile Demonstrator (HEL MD) mentioned above has a 50KW output
For the same price as the DARPA contract, he could deliver 100 prototypes, or one protoype and have change left over for a small party.
If someone would volenteer to help write the grant proposal, I will volenteer to help with planning the party.
You have lost a decimal place. I make that ten million 21 cent laser equivalent power. And 2.1 million dollars.
Sill might be competitive though. If there is enough in stock and the shipping is free.
I make that about 1000 square meters of lasers. We are going to have to put this on the run way of an aircraft carrier not the actual aircraft. Hope we can hide that fact in small print in the grant proposal somewhere where they won't find it.
All we need is erco to find a deal on 3 million LR44 and we are in business.
I make that 17.8 meter radius, nearly 36 meters across. Pretty huge!
Who is going to do all the soldering?
And aligning? These factory second lasers shoot off-axis, as some of us have discovered.
From a safe distance and with appropriate eye protection of course
http://en.wikipedia.org/wiki/Hubble_Space_Telescope
I worked there during the time of grinding. It took two years.
How many sharks would it take to carry a 36 meter disk for the anit-submarine version?
