Issue drawing BMP Pics to LCD unless they take up screen
I am using the sainsmart 1.8" LCD to view bmp images stored on an SD Card. Below is the code. The issue is that it works perfect when the BMP file is the same size as the screen, but does not work when the image is smaller than the screen. Here are a few photos of it working, and not working. I have already tried multiple images, so I know it is not the file. The images are the same except on is 128 * 160(the whole screen), and one is 90 x 120. I did not include the SD Classes because I know they work, essentially the BMP file is read in blocks of 512-bytes. The BMP files are a 24 bit depth, but converted to a 565(rgb) layout for the screens 16bit depth. Any help would be appreciated. Thanks!
Main Object:
Utilities:
SPILCD:
[code]{{
SPI Management Functions
Abstract:
This class is built to be a universal SPI Driver with C3 Channel select capability.
CON
'Clocking settings
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
VAR
long data[8]
ASM DATA:
data[0] := Data pin
data[1] := Clock pin
data[2] := Data location/data
data[3] := data type to write (no command(idle)=0, char=1, 8bit=2, 16bitrewrite=3, SetFont = 4)
data[4] := color/writes to perform for 16 bit mode
data[5] := bcolor
data[6] := x
data[7] := y
byte cogon
byte cog
OBJ
Utilities : "Utilities"
PUB InitSPI(spidata, spiclock) : okay
'Set Asm data
data[0] := spidata 'Data pin
data[1] := spiclock'Clock pin
data[3] := 0 'Data not present
okay := cogon := (cog := cognew(@entry,@data)) > 0
PUB WriteSPISlow(strOutBuffer) | NumBytes
NumBytes := 8
' now read the bits out
repeat 8
' drop clock
OUTA[data[1]] := 0
' place next bit on OUT (shift to right starting at MSB - 1(to get the first(msb) bit then next, and so on) then bitwise AND with 01 to get only last bit)
OUTA[data[0]] := ((strOutBuffer >> (NumBytes-- - 1)) & $01)
' raise clock
OUTA[data[1]] := 1
PUB WriteSPICLR(writes, wrdOut)
Purpose: Write 16 bits to SPI, but repeat sending 16 bit data for writes times
repeat until data[3] == 0 'Wait until cog ready
data[2] := wrdOut 'Write word to write
data[4] := writes 'Write "writes" times
data[3] := 3 'Set data type to 16 bit
PUB WriteSPICHR(x,y,char,color,bcolor)
Purpose: Write charachter to screen
data[2] := char
data[4] := color
data[5] := bcolor
data[6] := x
data[7] := y
data[3] := 1 'Set function to char
PUB SetFont(fontloc)
Purpose: Set font for ASM char writing
data[2] := fontloc
data[3] := 4 'Set function to set font
PUB WriteSPI(bytOut)
Purpose: Write 8 bits to SPI
data[2] := bytOut
data[3] := 2 'Set datatype to 8 bit
PUB stop
if cogon~
cogstop(cog)
DAT
org 0
entry
mov dt, par 'Get data location
rdlong spid, dt 'Get SPI data pin
add dt, #4 'Jump to next long
rdlong spic, dt 'Get SPI clk pin
mov spidmask, #1 'Get Pin Masks
mov spicmask, #1
shl spidmask, spid
shl spicmask, spic
or dira, spidmask 'Set pins to output
or dira, spicmask
add dt, #4 'Goto Data location
mov dtyploc, dt 'Get Data type location
add dtyploc, #4
mov cloc, dtyploc
add cloc, #4
mov bcloc, cloc
add bcloc, #4
mov xloc, bcloc
add xloc, #4
mov yloc, xloc
add yloc, #4
'Set Counter registers
mov ctra, spid 'Set counter A data pin
mov ctrb, spic 'Set clock pin for ctr b
movi ctra,#%0_00100_000
movi ctrb,#%0_00100_000
:loop
rdlong r1, dtyploc 'Get datatype
tjz r1, #:loop
movi phsb,#%000000000 'Set phase reg b
rdlong wrdt, dt 'Get data from location
cmp r1, #1 wz 'Test if char
if_z jmp #:writechar
cmp r1, #2 wz 'Test if 8 bit command
if_z jmp #:writeeight
cmp r1, #3 wz 'Test if 16 bit command
if_z jmp #:writesixtn
jmp #:setfont 'Otherwise, set font command
:writeeight
shl wrdt, #24
mov phsa, wrdt 'Write data into register
movi frqb,#%010000000 'Start counting!
:wreghtloop
shl phsa, #1 'Get next bit
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
mov frqb, #0 'Stop counting
wrlong null, dtyploc 'Clear Datatype
jmp #:loop
:writesixtn
rdlong r2, cloc 'Get times to write data
shl wrdt, #16
:wrsxtnloop
mov phsa, wrdt
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
djnz r2,#:wrsxtnloop 'If more writes start writing again
jmp #:loop
:writechar
rdlong wrdt,dt 'Get Char
rdlong cx, xloc 'Get x
rdlong cy, yloc 'Get y
'Calculate char address
mov r1, wrdt
sub r1, foffset
mov r2, fxsize
shr r2, #3 'Divide by 8
Main Object:
Name: Trevor Handermann
Abstract: SS TFT 1.8" LCD Driver
CON
'Clocking settings
SCREEN_WIDTH = 128
SCREEN_HEIGHT = 160
TEXT_WIDTH = 5
'LCD COMMANDS
COLADDRSET = $2A
ROWADDRSET = $2B
RAMWR = $2C
RAMRD = $2E
WIDTH = 128
HEIGHT = 160
SWRESET = $01
SLEEPIN = $10
SLEEPOUT = $11
FRMCTR1 = $B1
FRMCTR2 = $B2
FRMCTR3 = $B3
DISPON = $29
DISPOFF = $28
INVCTR = $B4 'Display Inversion Control
PWCTR1 = $C0 'Power Control
PWCTR2 = $C1
PWCTR3 = $C2
PWCTR4 = $C3
PWCTR5 = $C4
MADCTL = $36 'Memory Access Control
INVOFF = $20 'Invert display off
INVON = $21
COLMOD = $3A 'Color Mode
NORON = $13 'Normal Display On
GMCTRP1 = $E0
GMCTRN1 = $E1
VMCTR1 = $C5 'Power Control
'BBBBB_GGGGGG_RRRRR
'Colors
WHITE = $FFFF
BLACK = 0
RED = $F800
BLUE = $F800
GREEN = $07E0
PURPLE = $F81F
YELLOW = $07FF
ORANGE = %00000_100000_11111
BROWN = %01000_011000_10001
VAR
byte cs, sda, scl, dc, rst 'Pins
byte fxsize, fysize, foffset, font
long floc
byte buffer[512]
byte rollover[2]
long bmpimgoffset, bmpwidth, bmpheight, bmpdepth
OBJ
SPI : "SPILCD"
term : "Parallax Serial Terminal"
num : "Simple_Numbers"
SD : "SDFAT"
PUB Start | te, tes
term.Start(9600)
Init(4,1,0,2,3)
SetFont(0)
SD.Mount(true,0,0,0,0)
SD.LoadPartitions
SD.LoadPartition(0)
'Term.str(num.dec(te))
SD.LoadDir(-1) 'Load root dir
SPI.SetFont(@SmallFont)
'Fill screen back color
FillScreen(RED)
'Utilities.DelayS(2)
te := DrawBMP(string("GUN.BMP"),0,0)
repeat
PUB Init( cspin, sdapin, sclpin, dcpin, rstpin)
cs := cspin
sda := sdapin
scl := sclpin
dc := dcpin
rst := rstpin
'Init SPI Interface
SPI.InitSPI(sda, scl)
InitR
PUB DrawBMP(pstr,x,y): okay | clusters,index, subind, bufind,r,g,b, col,rollcnt, curloc, r1
Purpose: Draws BMP image with name @pstr at point x,y. File must be in currently loaded directory, and pic must fit within screen
'Get file list
index := SD.GetFileList
okay := 0
r1 := Utilities.GetSubWordIndex(index, pstr,">") 'Get index in directory to load BMP file
if r1 <> -1 'If file exists, then load
clusters := SD.GetFileClusters(r1) 'Load Clusters for file
rollcnt := 0
if clusters > 0
if ReadBMPHeader 'Test if valid BMP File
curloc := 0
bufind := bmpimgoffset
SetAddrWindow(x,y,x + bmpwidth - 1, y + bmpheight - 1)
repeat index from 0 to bmpheight - 1
repeat subind from 0 to bmpwidth - 1
if rollcnt > 0
case rollcnt
1:
b := rollover[0]
g := buffer[0]
r := buffer[1]
bufind := 2
2:
b := rollover[0]
g := rollover[1]
r := buffer[0]
bufind := 1
rollcnt := 0
else
'Read pixel
b := buffer[bufind]
'Term.str(string(" b:"))
'Term.str(num.hex(b, 2))
g := buffer[bufind + 1]
'Term.str(string(" g:"))
'Term.str(num.hex(g, 2))
r := buffer[bufind + 2]
'Term.str(string(" r:"))
'Term.str(num.hex(r, 2))
'Term.str(string(" / "))
'Increment buffer
bufind += 3
'Convert 888 to 565 pixel depth
col := ((r & $F8) << 8) | ((g & $FC) << 3) | ((b & $F8) >> 3)
'Term.str(string(" col:"))
'Term.str(num.dec(col))
'repeat
'Push color to LCD
PushColor(col)
if bufind > 509
if bufind <> 512
rollcnt := 512 - bufind
'Get rollover bytes
repeat col from bufind to 511
rollover[col - bufind] := buffer[col]
else
bufind := 0
'Read next block into buffer
SD.ReadFile(++curloc,@buffer)
else
okay := 213
else
okay := 212
else
okay := 211
PRI ReadBMPHeader : okay | tmp
'Read first portion of file
SD.ReadFile(0,@buffer)
okay := false
'Verify header
if buffer[0] == $42 and buffer[1] == $4d
'Header ok
bmpimgoffset := ReverseLongBuffer(10)
'Verify width and height
bmpwidth := ReverseLongBuffer(18)
bmpheight := ReverseLongBuffer(22)
if bmpwidth =< SCREEN_WIDTH and bmpheight =< SCREEN_HEIGHT
'Verify header
if buffer[26] == 1 and buffer[27] == 0
'Header ok
bmpdepth := ReverseWordBuffer(28)
'Verify Compression
if ReverseLongBuffer(30)== 0
'Correct compression
okay := true
PRI ReverseLongBuffer(location) : value | index
value := 0
repeat index from 0 to 3
value |= (buffer[location+index] << (index * 8))
PRI ReverseWordBuffer(location) : value | index
value := 0
repeat index from 0 to 1
PUB WriteCommand(command)
OUTA[dc]~
OUTA[cs]~
SPI.WriteSPI(command)
OUTA[cs]~~
PRI WriteData(data)
OUTA[dc]~~
OUTA[cs]~
SPI.WriteSPI(data)
OUTA[cs]~~
PUB SetAddrWindow(x0, y0, x1, y1)
WriteCommand(COLADDRSET) 'Set Column
WriteData(0)
WriteData(x0) 'Set XSTART
WriteData(0)
WriteData(x1) 'Set XEND
WriteCommand(ROWADDRSET) 'Set Row
WriteData(0)
WriteData(y0) 'Set XSTART
WriteData(0)
WriteData(y1) 'Set XEND
WriteCommand(RAMWR) 'Write to RAM
PUB PushColor(color)
OUTA[dc]~~
OUTA[cs]~
SPI.WriteSPICLR(1, color)
OUTA[cs]~~
PUB SetXY(x,y)
SetAddrWindow(x,y,x + 1, y + 1)
PUB DrawPixel(x,y,color)
if x < WIDTH and Y < HEIGHT and x => 0 and y => 0
SetAddrWindow(x,y,x+1,y+1) 'Set window to 1 pixel
PushColor(color) 'Push the color to the pixel
PUB FillScreen(color) | x, y
SetAddrWindow(0,0,WIDTH - 1, HEIGHT -1) 'Set window to whole screen
OUTA[dc]~~
OUTA[cs]~
SPI.WriteSPICLR(20_480, color)
OUTA[cs]~~
PUB DrawString(x,y,pstrString,color, bcolor) | length, chr, index, space, wordlength, xbegin
length := strsize(pstrString)
repeat index from 0 to length - 1
if index <> 0
x += fxsize
chr := byte[pstrString + index]
DrawChar(x,y,chr,color,bcolor)
if chr == 32
space := Utilities.IndexOf(index + 1, 32, pstrString) 'Get index of next space
if space == -1
space := length - 1
wordlength := space - (index + 1) 'Get length of next word
if (wordlength * fxsize) + x => WIDTH
y += fysize
x := 0
if (x + (2 * fxsize)) > WIDTH 'If end of screen
y += fysize
x := 0
PUB DrawVerticalLine(x,y,length,color)
DrawHVLine(x,y,length,color,1)
PUB DrawHorizontalLine(x,y,length,color)
DrawHVLine(x,y,length,color,0)
PRI DrawHVLine(x,y,length,color,rotflag)
Note: 1 = Verticle, 0 = horizontal
if rotflag == 1
SetAddrWindow(x,y,x,y+length)
else
SetAddrWindow(x,y,x+length,y+1)
OUTA[dc]~~
OUTA[cs]~
SPI.WriteSPICLR(length, color)
OUTA[cs]~~
PUB DrawCircle(x0,y0,r,color) | x,y,ddfx,ddfy,f
f := 1 - r
ddfx := 1
ddfy := -2 * r
x := 0
y := r
DrawPixel(x0,y0+r,color)
DrawPixel(x0,y0-r,color)
DrawPixel(x0+r,y0,color)
DrawPixel(x0-r,y0,color)
repeat while x < y
if f=> 0
y--
ddfy += 2
f += ddfy
x++
ddfx += 2
f += ddfx
DrawPixel(x0 + x, y0 + y, color)
DrawPixel(x0 - x, y0 + y, color)
DrawPixel(x0 + x, y0 - y, color)
DrawPixel(x0 - x, y0 - y, color)
DrawPixel(x0 + y, y0 + x, color)
DrawPixel(x0 - y, y0 + x, color)
DrawPixel(x0 + y, y0 - x, color)
DrawPixel(x0 - y, y0 - x, color)
PUB FillCircle(x0,y0,r,color) | f, ddfx, ddfy, x,y
f := 1 - r
ddfx := 1
ddfy := -2 * r
x := 0
y := r
DrawVerticalLine(x0,y0-r,2*r+1,color)
repeat while x < y
if f => 0
y--
ddfy += 2
f += ddfy
x++
ddfx += 2
f += ddfx
DrawVerticalLine(x0+x, y0-y, 2*y+1, color)
DrawVerticalLine(x0-x, y0-y, 2*y+1, color)
DrawVerticalLine(x0+y, y0-x, 2*x+1, color)
DrawVerticalLine(x0-y, y0-x, 2*x+1, color)
PUB DrawRect(x,y,w,h,color)
DrawHorizontalLine(x, y, w, color)
DrawHorizontalLine(x, y+h-1, w, color)
DrawVerticalLine(x, y, h, color)
DrawVerticalLine(x+w-1, y, h, color)
PUB FillRect(x,y,w,h,color)
SetAddrWindow(x, y, x+w-1, y+h-1)
OUTA[dc]~~
OUTA[cs]~
SPI.WriteSPICLR(w*h,color)
OUTA[cs]~~
PUB DrawChar(x,y,char,color,bcolor) | index, in1, chr, line, in2,temp
'50 longs per digit
SetAddrWindow(x,y,x+fxsize-1,y+fysize-1)
temp := ((char - foffset) * ((fxsize /8) * fysize))
repeat index from 0 to ((fxsize/8) * fysize) - 1
chr := byte[floc][temp]
repeat in1 from 0 to 7
if (chr & (1<<(7-in1))) <> 0
PushColor(color)
else
PushColor(bcolor)
temp++
PUB DrawCharNew(x,y,char,color,bcolor) | index, in1, chr, line, in2,temp
'50 longs per digit
OUTA[dc]~~
OUTA[cs]~
SPI.WriteSPICHR(x, y,char,color,bcolor)
OUTA[cs]~~
PUB DrawLine(x0,y0,x1,y1, color) | steep, dx, dy, err, ystep
steep := ||y1-y0 > ||x1-x0
if steep
Swap(x0,y0)
Swap(x1,y1)
if x0 > x1
Swap(x0,x1)
Swap(y0,y1)
dx := x1 - x0
dy := ||y1-y0
err := dx / 2
if y0 < y1
ystep := 1
else
ystep := -1
repeat while x0 =< x1
if steep
DrawPixel(y0,x0,color)
else
DrawPixel(x0,y0,color)
err -= dy
if err < 0
y0 += ystep
err += dx
x0++
PRI Swap(a,b) | t
t := a
a := b
b := t
PRI InitR
'Set Pin Dirs
DIRA[dc]~~
DIRA[cs]~~
DIRA[rst]~~
DIRA[sda]~~
DIRA[scl]~~
OUTA[cs]~
'Reset hardware
OUTA[rst]~~
Utilities.DelayMS(500)
OUTA[rst]~
OUTA[rst]~~
'Reset Software
WriteCommand(SWRESET)
Utilities.DelayMS(150)
'Disable Sleep Mode
WriteCommand(SLEEPOUT)
'Frame rate control normal
WriteCommand(FRMCTR1)
WriteData(1)
WriteData($2C)
WriteData($2D)
'Frame rate control idle
WriteCommand(FRMCTR2)
WriteData(1)
WriteData($2C)
WriteData($2D)
'Frame rate control partial
WriteCommand(FRMCTR3)
WriteData(1)
WriteData($2C)
WriteData($2D)
WriteData(1)
WriteData($2C)
WriteData($2D)
WriteCommand(INVCTR)
WriteData($07) 'No Inversion
'Power Control Settings
WriteCommand(PWCTR1)
WriteData($A2)
WriteData($02) ' -4.6V
WriteData($84) ' AUTO mode
WriteCommand(PWCTR2) ' power control
WriteData($C5) ' VGH25 = 2.4C VGSEL = -10 VGH = 3 * AVDD
WriteCommand(PWCTR3) ' power control
WriteData($0A) ' Opamp current small
WriteData($00) ' Boost frequency
WriteCommand(PWCTR4) ' power control
WriteData($8A) ' BCLK/2, Opamp current small & Medium low
WriteData($2A)
WriteCommand(PWCTR5) ' power control
WriteData($8A)
WriteData($EE)
WriteCommand(VMCTR1) ' power control
WriteData($0E)
WriteCommand(INVOFF) ' don't invert display
WriteCommand(MADCTL) ' memory access control (directions)
WriteData($40) ' row address/col address, bottom to top refresh
WriteCommand(COLMOD) ' set color mode
WriteData($05) ' 16-bit color
WriteCommand(COLADDRSET) ' column addr set
WriteData($00)
WriteData($00) ' XSTART = 0
WriteData($00)
WriteData($7F) ' XEND = 127
WriteCommand(ROWADDRSET) ' row addr set
WriteData($00)
WriteData($00)
WriteData($9F) ' XEND = 159
WriteCommand(GMCTRP1)
WriteData($0f)
WriteData($1a)
WriteData($0f)
WriteData($18)
WriteData($2f)
WriteData($28)
WriteData($20)
WriteData($22)
WriteData($1f)
WriteData($1b)
WriteData($23)
WriteData($37)
WriteData($00)
WriteData($07)
WriteData($02)
WriteData($10)
WriteCommand(GMCTRN1)
WriteData($0f)
WriteData($1b)
WriteData($0f)
WriteData($17)
WriteData($33)
WriteData($2c)
WriteData($29)
WriteData($2e)
WriteData($30)
WriteData($30)
WriteData($39)
WriteData($3f)
WriteData($00)
WriteData($07)
WriteData($03)
WriteData($10)
WriteCommand(DISPON)
Utilities.DelayMS(100)
WriteCommand(NORON) ' normal display on
Utilities.DelayMS(10)
PUB SetFont(f)
font := f
CASE font
0:
floc := @SmallFont
1:
floc := @BigFont
2:
floc := @SevenSegNumFont
fxsize := byte[floc++]
fysize := byte[floc++]
foffset := byte[floc++]
floc++
DAT
SmallFont
byte $08, $0C, $20, $5F
byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00 ' <Space>
byte $00, $00, $20, $20, $20, $20, $20, $20, $00, $20, $00, $00 ' !
byte $00, $28, $50, $50, $00, $00, $00, $00, $00, $00, $00, $00 ' "
byte $00, $00, $28, $28, $FC, $28, $50, $FC, $50, $50, $00, $00 ' #
byte $00, $20, $78, $A8, $A0, $60, $30, $28, $A8, $F0, $20, $00 ' $
byte $00, $00, $48, $A8, $B0, $50, $28, $34, $54, $48, $00, $00 ' %
byte $00, $00, $20, $50, $50, $78, $A8, $A8, $90, $6C, $00, $00 ' &
byte $00, $40, $40, $80, $00, $00, $00, $00, $00, $00, $00, $00 ' '
byte $00, $04, $08, $10, $10, $10, $10, $10, $10, $08, $04, $00 ' (
byte $00, $40, $20, $10, $10, $10, $10, $10, $10, $20, $40, $00 ' )
byte $00, $00, $00, $20, $A8, $70, $70, $A8, $20, $00, $00, $00 ' *
byte $00, $00, $20, $20, $20, $F8, $20, $20, $20, $00, $00, $00 ' +
byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $40, $40, $80 ' ,
byte $00, $00, $00, $00, $00, $F8, $00, $00, $00, $00, $00, $00 ' -
byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $40, $00, $00 ' .
byte $00, $08, $10, $10, $10, $20, $20, $40, $40, $40, $80, $00 ' /
byte $00, $00, $70, $88, $88, $88, $88, $88, $88, $70, $00, $00 ' 0
byte $00, $00, $20, $60, $20, $20, $20, $20, $20, $70, $00, $00 ' 1
byte $00, $00, $70, $88, $88, $10, $20, $40, $80, $F8, $00, $00 ' 2
byte $00, $00, $70, $88, $08, $30, $08, $08, $88, $70, $00, $00 ' 3
byte $00, $00, $10, $30, $50, $50, $90, $78, $10, $18, $00, $00 ' 4
byte $00, $00, $F8, $80, $80, $F0, $08, $08, $88, $70, $00, $00 ' 5
byte $00, $00, $70, $90, $80, $F0, $88, $88, $88, $70, $00, $00 ' 6
byte $00, $00, $F8, $90, $10, $20, $20, $20, $20, $20, $00, $00 ' 7
byte $00, $00, $70, $88, $88, $70, $88, $88, $88, $70, $00, $00 ' 8
byte $00, $00, $70, $88, $88, $88, $78, $08, $48, $70, $00, $00 ' 9
byte $00, $00, $00, $00, $20, $00, $00, $00, $00, $20, $00, $00 ' :
byte $00, $00, $00, $00, $00, $20, $00, $00, $00, $20, $20, $00 ' ;
byte $00, $04, $08, $10, $20, $40, $20, $10, $08, $04, $00, $00 ' <
byte $00, $00, $00, $00, $F8, $00, $00, $F8, $00, $00, $00, $00 ' =
byte $00, $40, $20, $10, $08, $04, $08, $10, $20, $40, $00, $00 ' >
byte $00, $00, $70, $88, $88, $10, $20, $20, $00, $20, $00, $00 ' ?
byte $00, $00, $70, $88, $98, $A8, $A8, $B8, $80, $78, $00, $00 ' @
byte $00, $00, $20, $20, $30, $50, $50, $78, $48, $CC, $00, $00 ' A
byte $00, $00, $F0, $48, $48, $70, $48, $48, $48, $F0, $00, $00 ' B
byte $00, $00, $78, $88, $80, $80, $80, $80, $88, $70, $00, $00 ' C
byte $00, $00, $F0, $48, $48, $48, $48, $48, $48, $F0, $00, $00 ' D
byte $00, $00, $F8, $48, $50, $70, $50, $40, $48, $F8, $00, $00 ' E
byte $00, $00, $F8, $48, $50, $70, $50, $40, $40, $E0, $00, $00 ' F
byte $00, $00, $38, $48, $80, $80, $9C, $88, $48, $30, $00, $00 ' G
byte $00, $00, $CC, $48, $48, $78, $48, $48, $48, $CC, $00, $00 ' H
byte $00, $00, $F8, $20, $20, $20, $20, $20, $20, $F8, $00, $00 ' I
byte $00, $00, $7C, $10, $10, $10, $10, $10, $10, $90, $E0, $00 ' J
byte $00, $00, $EC, $48, $50, $60, $50, $50, $48, $EC, $00, $00 ' K
byte $00, $00, $E0, $40, $40, $40, $40, $40, $44, $FC, $00, $00 ' L
byte $00, $00, $D8, $D8, $D8, $D8, $A8, $A8, $A8, $A8, $00, $00 ' M
byte $00, $00, $DC, $48, $68, $68, $58, $58, $48, $E8, $00, $00 ' N
byte $00, $00, $70, $88, $88, $88, $88, $88, $88, $70, $00, $00 ' O
byte $00, $00, $F0, $48, $48, $70, $40, $40, $40, $E0, $00, $00 ' P
byte $00, $00, $70, $88, $88, $88, $88, $E8, $98, $70, $18, $00 ' Q
byte $00, $00, $F0, $48, $48, $70, $50, $48, $48, $EC, $00, $00 ' R
byte $00, $00, $78, $88, $80, $60, $10, $08, $88, $F0, $00, $00 ' S
byte $00, $00, $F8, $A8, $20, $20, $20, $20, $20, $70, $00, $00 ' T
byte $00, $00, $CC, $48, $48, $48, $48, $48, $48, $30, $00, $00 ' U
byte $00, $00, $CC, $48, $48, $50, $50, $30, $20, $20, $00, $00 ' V
byte $00, $00, $A8, $A8, $A8, $70, $50, $50, $50, $50, $00, $00 ' W
byte $00, $00, $D8, $50, $50, $20, $20, $50, $50, $D8, $00, $00 ' X
byte $00, $00, $D8, $50, $50, $20, $20, $20, $20, $70, $00, $00 ' Y
byte $00, $00, $F8, $90, $10, $20, $20, $40, $48, $F8, $00, $00 ' Z
byte $00, $38, $20, $20, $20, $20, $20, $20, $20, $20, $38, $00 ' [
byte $00, $40, $40, $40, $20, $20, $10, $10, $10, $08, $00, $00 ' <Backslash>
byte $00, $70, $10, $10, $10, $10, $10, $10, $10, $10, $70, $00 ' ]
byte $00, $20, $50, $00, $00, $00, $00, $00, $00, $00, $00, $00 ' ^
byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $FC ' _
byte $00, $20, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00 ' '
byte $00, $00, $00, $00, $00, $30, $48, $38, $48, $3C, $00, $00 ' a
byte $00, $00, $C0, $40, $40, $70, $48, $48, $48, $70, $00, $00 ' b
byte $00, $00, $00, $00, $00, $38, $48, $40, $40, $38, $00, $00 ' c
byte $00, $00, $18, $08, $08, $38, $48, $48, $48, $3C, $00, $00 ' d
byte $00, $00, $00, $00, $00, $30, $48, $78, $40, $38, $00, $00 ' e
byte $00, $00, $1C, $20, $20, $78, $20, $20, $20, $78, $00, $00 ' f
byte $00, $00, $00, $00, $00, $3C, $48, $30, $40, $78, $44, $38 ' g
byte $00, $00, $C0, $40, $40, $70, $48, $48, $48, $EC, $00, $00 ' h
byte $00, $00, $20, $00, $00, $60, $20, $20, $20, $70, $00, $00 ' i
byte $00, $00, $10, $00, $00, $30, $10, $10, $10, $10, $10, $E0 ' j
byte $00, $00, $C0, $40, $40, $5C, $50, $70, $48, $EC, $00, $00 ' k
byte $00, $00, $E0, $20, $20, $20, $20, $20, $20, $F8, $00, $00 ' l
byte $00, $00, $00, $00, $00, $F0, $A8, $A8, $A8, $A8, $00, $00 ' m
byte $00, $00, $00, $00, $00, $F0, $48, $48, $48, $EC, $00, $00 ' n
byte $00, $00, $00, $00, $00, $30, $48, $48, $48, $30, $00, $00 ' o
byte $00, $00, $00, $00, $00, $F0, $48, $48, $48, $70, $40, $E0 ' p
byte $00, $00, $00, $00, $00, $38, $48, $48, $48, $38, $08, $1C ' q
byte $00, $00, $00, $00, $00, $D8, $60, $40, $40, $E0, $00, $00 ' r
byte $00, $00, $00, $00, $00, $78, $40, $30, $08, $78, $00, $00 ' s
byte $00, $00, $00, $20, $20, $70, $20, $20, $20, $18, $00, $00 ' t
byte $00, $00, $00, $00, $00, $D8, $48, $48, $48, $3C, $00, $00 ' u
byte $00, $00, $00, $00, $00, $EC, $48, $50, $30, $20, $00, $00 ' v
byte $00, $00, $00, $00, $00, $A8, $A8, $70, $50, $50, $00, $00 ' w
byte $00, $00, $00, $00, $00, $D8, $50, $20, $50, $D8, $00, $00 ' x
byte $00, $00, $00, $00, $00, $EC, $48, $50, $30, $20, $20, $C0 ' y
byte $00, $00, $00, $00, $00, $78, $10, $20, $20, $78, $00, $00 ' z
byte $00, $18, $10, $10, $10, $20, $10, $10, $10, $10, $18, $00 ' {
byte $10, $10, $10, $10, $10, $10, $10, $10, $10, $10, $10, $10 ' |
byte $00, $60, $20, $20, $20, $10, $20, $20, $20, $20, $60, $00 ' }
byte $40, $A4, $18, $00, $00, $00, $00, $00, $00, $00, $00, $00 ' ~
BigFont
byte $10, $10, $20, $5F
byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00 ' <Space>
byte $00, $00, $00, $00, $07, $00, $0F, $80, $0F, $80, $0F, $80, $0F, $80, $0F, $80, $07, $00, $07, $00, $00, $00, $00, $00, $07, $00, $07, $00, $07, $00, $00, $00 ' !
byte $00, $00, $0E, $38, $0E, $38, $0E, $38, $0E, $38, $06, $30, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00 ' "
byte $00, $00, $0C, $30, $0C, $30, $0C, $30, $7F, $FE, $7F, $FE, $0C, $30, $0C, $30, $0C, $30, $0C, $30, $7F, $FE, $7F, $FE, $0C, $30, $0C, $30, $0C, $30, $00, $00 ' #
byte $00, $00, $02, $40, $02, $40, $0F, $F8, $1F, $F8, $1A, $40, $1A, $40, $1F, $F0, $0F, $F8, $02, $58, $02, $58, $1F, $F8, $1F, $F0, $02, $40, $02, $40, $00, $00 ' $
byte $00, $00, $00, $00, $00, $00, $0E, $10, $0E, $30, $0E, $70, $00, $E0, $01, $C0, $03, $80, $07, $00, $0E, $70, $0C, $70, $08, $70, $00, $00, $00, $00, $00, $00 ' %
byte $00, $00, $00, $00, $0F, $00, $19, $80, $19, $80, $19, $80, $0F, $00, $0F, $08, $0F, $98, $19, $F8, $18, $F0, $18, $E0, $19, $F0, $0F, $98, $00, $00, $00, $00 ' &
byte $00, $00, $00, $00, $07, $00, $07, $00, $07, $00, $0E, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00 ' '
byte $00, $00, $00, $00, $00, $F0, $01, $C0, $03, $80, $07, $00, $0E, $00, $0E, $00, $0E, $00, $0E, $00, $07, $00, $03, $80, $01, $C0, $00, $F0, $00, $00, $00, $00 ' (
byte $00, $00, $00, $00, $0F, $00, $03, $80, $01, $C0, $00, $E0, $00, $70, $00, $70, $00, $70, $00, $70, $00, $E0, $01, $C0, $03, $80, $0F, $00, $00, $00, $00, $00 ' )
byte $00, $00, $00, $00, $01, $80, $11, $88, $09, $90, $07, $E0, $07, $E0, $3F, $FC, $3F, $FC, $07, $E0, $07, $E0, $09, $90, $11, $88, $01, $80, $00, $00, $00, $00 ' *
byte $00, $00, $00, $00, $00, $00, $00, $00, $01, $80, $01, $80, $01, $80, $0F, $F0, $0F, $F0, $01, $80, $01, $80, $01, $80, $00, $00, $00, $00, $00, $00, $00, $00 ' +
byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $07, $00, $07, $00, $07, $00, $0E, $00, $00, $00 ' ,
byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $1F, $F8, $1F, $F8, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00 ' -
byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $07, $00, $07, $00, $07, $00, $00, $00, $00, $00 ' ,
byte $00, $00, $00, $00, $00, $02, $00, $06, $00, $0E, $00, $1C, $00, $38, $00, $70, $00, $E0, $01, $C0, $03, $80, $07, $00, $0E, $00, $1C, $00, $00, $00, $00, $00 ' /
byte $00, $00, $00, $00, $0F, $F0, $1C, $38, $1C, $78, $1C, $F8, $1C, $F8, $1D, $B8, $1D, $B8, $1F, $38, $1F, $38, $1E, $38, $1C, $38, $0F, $F0, $00, $00, $00, $00 ' 0
byte $00, $00, $00, $00, $01, $80, $01, $80, $03, $80, $1F, $80, $1F, $80, $03, $80, $03, $80, $03, $80, $03, $80, $03, $80, $03, $80, $1F, $F0, $00, $00, $00, $00 ' 1
byte $00, $00, $00, $00, $0F, $E0, $1C, $70, $1C, $38, $00, $38, $00, $70, $00, $E0, $01, $C0, $03, $80, $07, $00, $0E, $38, $1C, $38, $1F, $F8, $00, $00, $00, $00 ' 2
byte $00, $00, $00, $00, $0F, $E0, $1C, $70, $1C, $38, $00, $38, $00, $70, $03, $C0, $03, $C0, $00, $70, $00, $38, $1C, $38, $1C, $70, $0F, $E0, $00, $00, $00, $00 ' 3
byte $00, $00, $00, $00, $00, $E0, $01, $E0, $03, $E0, $06, $E0, $0C, $E0, $18, $E0, $1F, $F8, $1F, $F8, $00, $E0, $00, $E0, $00, $E0, $03, $F8, $00, $00, $00, $00 ' 4
byte $00, $00, $00, $00, $1F, $F8, $1C, $00, $1C, $00, $1C, $00, $1C, $00, $1F, $E0, $1F, $F0, $00, $78, $00, $38, $1C, $38, $1C, $70, $0F, $E0, $00, $00, $00, $00 ' 5
byte $00, $00, $00, $00, $03, $E0, $07, $00, $0E, $00, $1C, $00, $1C, $00, $1F, $F0, $1F, $F8, $1C, $38, $1C, $38, $1C, $38, $1C, $38, $0F, $F0, $00, $00, $00, $00 ' 6
byte $00, $00, $00, $00, $1F, $FC, $1C, $1C, $1C, $1C, $1C, $1C, $00, $1C, $00, $38, $00, $70, $00, $E0, $01, $C0, $03, $80, $03, $80, $03, $80, $00, $00, $00, $00 ' 7
byte $00, $00, $00, $00, $0F, $F0, $1C, $38, $1C, $38, $1C, $38, $1F, $38, $07, $E0, $07, $E0, $1C, $F8, $1C, $38, $1C, $38, $1C, $38, $0F, $F0, $00, $00, $00, $00 ' 8
byte $00, $00, $00, $00, $0F, $F0, $1C, $38, $1C, $38, $1C, $38, $1C, $38, $1F, $F8, $0F, $F8, $00, $38, $00, $38, $00, $70, $00, $E0, $07, $C0, $00, $00, $00, $00 ' 9
byte $00, $00, $00, $00, $00, $00, $00, $00, $03, $80, $03, $80, $03, $80, $00, $00, $00, $00, $03, $80, $03, $80, $03, $80, $00, $00, $00, $00, $00, $00, $00, $00 ' :
byte $00, $00, $00, $00, $00, $00, $00, $00, $03, $80, $03, $80, $03, $80, $00, $00, $00, $00, $03, $80, $03, $80, $03, $80, $07, $00, $00, $00, $00, $00, $00, $00 ' ;
byte $00, $00, $00, $70, $00, $E0, $01, $C0, $03, $80, $07, $00, $0E, $00, $1C, $00, $1C, $00, $0E, $00, $07, $00, $03, $80, $01, $C0, $00, $E0, $00, $70, $00, $00 ' <
byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $3F, $FC, $3F, $FC, $00, $00, $00, $00, $3F, $FC, $3F, $FC, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00 ' =
byte $00, $00, $1C, $00, $0E, $00, $07, $00, $03, $80, $01, $C0, $00, $E0, $00, $70, $00, $70, $00, $E0, $01, $C0, $03, $80, $07, $00, $0E, $00, $1C, $00, $00, $00 ' >
byte $00, $00, $03, $C0, $0F, $F0, $1E, $78, $18, $38, $00, $38, $00, $70, $00, $E0, $01, $C0, $01, $C0, $00, $00, $00, $00, $01, $C0, $01, $C0, $01, $C0, $00, $00 ' ?
byte $00, $00, $0F, $F8, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $FC, $1C, $FC, $1C, $FC, $1C, $FC, $1C, $00, $1C, $00, $1C, $00, $1F, $F0, $07, $F8, $00, $00 ' @
byte $00, $00, $00, $00, $03, $C0, $07, $E0, $0E, $70, $1C, $38, $1C, $38, $1C, $38, $1C, $38, $1F, $F8, $1C, $38, $1C, $38, $1C, $38, $1C, $38, $00, $00, $00, $00 ' A
byte $00, $00, $00, $00, $1F, $F0, $0E, $38, $0E, $38, $0E, $38, $0E, $38, $0F, $F0, $0F, $F0, $0E, $38, $0E, $38, $0E, $38, $0E, $38, $1F, $F0, $00, $00, $00, $00 ' B
byte $00, $00, $00, $00, $07, $F0, $0E, $38, $1C, $38, $1C, $00, $1C, $00, $1C, $00, $1C, $00, $1C, $00, $1C, $00, $1C, $38, $0E, $38, $07, $F0, $00, $00, $00, $00 ' C
byte $00, $00, $00, $00, $1F, $E0, $0E, $70, $0E, $38, $0E, $38, $0E, $38, $0E, $38, $0E, $38, $0E, $38, $0E, $38, $0E, $38, $0E, $70, $1F, $E0, $00, $00, $00, $00 ' D
byte $00, $00, $00, $00, $1F, $F8, $0E, $18, $0E, $08, $0E, $00, $0E, $30, $0F, $F0, $0F, $F0, $0E, $30, $0E, $00, $0E, $08, $0E, $18, $1F, $F8, $00, $00, $00, $00 ' E
byte $00, $00, $00, $00, $1F, $F8, $0E, $18, $0E, $08, $0E, $00, $0E, $30, $0F, $F0, $0F, $F0, $0E, $30, $0E, $00, $0E, $00, $0E, $00, $1F, $00, $00, $00, $00, $00 ' F
byte $00, $00, $00, $00, $07, $F0, $0E, $38, $1C, $38, $1C, $38, $1C, $00, $1C, $00, $1C, $00, $1C, $F8, $1C, $38, $1C, $38, $0E, $38, $07, $F8, $00, $00, $00, $00 ' G
byte $00, $00, $00, $00, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1F, $F0, $1F, $F0, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $00, $00, $00, $00 ' H
byte $00, $00, $00, $00, $0F, $E0, $03, $80, $03, $80, $03, $80, $03, $80, $03, $80, $03, $80, $03, $80, $03, $80, $03, $80, $03, $80, $0F, $E0, $00, $00, $00, $00 ' I
byte $00, $00, $00, $00, $01, $FC, $00, $70, $00, $70, $00, $70, $00, $70, $00, $70, $00, $70, $38, $70, $38, $70, $38, $70, $38, $70, $0F, $E0, $00, $00, $00, $00 ' J
byte $00, $00, $00, $00, $1E, $38, $0E, $38, $0E, $70, $0E, $E0, $0F, $C0, $0F, $80, $0F, $80, $0F, $C0, $0E, $E0, $0E, $70, $0E, $38, $1E, $38, $00, $00, $00, $00 ' K
byte $00, $00, $00, $00, $1F, $00, $0E, $00, $0E, $00, $0E, $00, $0E, $00, $0E, $00, $0E, $00, $0E, $00, $0E, $08, $0E, $18, $0E, $38, $1F, $F8, $00, $00, $00, $00 ' L
byte $00, $00, $00, $00, $1C, $1C, $1E, $3C, $1F, $7C, $1F, $FC, $1F, $FC, $1D, $DC, $1C, $9C, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $00, $00, $00, $00 ' M
byte $00, $00, $00, $00, $1C, $1C, $1C, $1C, $1E, $1C, $1F, $1C, $1F, $9C, $1D, $DC, $1C, $FC, $1C, $7C, $1C, $3C, $1C, $1C, $1C, $1C, $1C, $1C, $00, $00, $00, $00 ' N
byte $00, $00, $00, $00, $03, $E0, $07, $F0, $0E, $38, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $0E, $38, $07, $F0, $03, $E0, $00, $00, $00, $00 ' O
byte $00, $00, $00, $00, $1F, $F0, $0E, $38, $0E, $38, $0E, $38, $0E, $38, $0F, $F0, $0F, $F0, $0E, $00, $0E, $00, $0E, $00, $0E, $00, $1F, $00, $00, $00, $00, $00 ' P
byte $00, $00, $00, $00, $03, $E0, $0F, $78, $0E, $38, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $7C, $1C, $FC, $0F, $F8, $0F, $F8, $00, $38, $00, $FC, $00, $00 ' Q
byte $00, $00, $00, $00, $1F, $F0, $0E, $38, $0E, $38, $0E, $38, $0E, $38, $0F, $F0, $0F, $F0, $0E, $70, $0E, $38, $0E, $38, $0E, $38, $1E, $38, $00, $00, $00, $00 ' R
byte $00, $00, $00, $00, $0F, $F0, $1C, $38, $1C, $38, $1C, $38, $1C, $00, $0F, $E0, $07, $F0, $00, $38, $1C, $38, $1C, $38, $1C, $38, $0F, $F0, $00, $00, $00, $00 ' S
byte $00, $00, $00, $00, $1F, $FC, $19, $CC, $11, $C4, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $07, $F0, $00, $00, $00, $00 ' T
byte $00, $00, $00, $00, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $0F, $E0, $00, $00, $00, $00 ' U
byte $00, $00, $00, $00, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $0E, $E0, $07, $C0, $03, $80, $00, $00, $00, $00 ' V
byte $00, $00, $00, $00, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $9C, $1C, $9C, $1C, $9C, $0F, $F8, $0F, $F8, $07, $70, $07, $70, $00, $00, $00, $00 ' W
byte $00, $00, $00, $00, $1C, $70, $1C, $70, $1C, $70, $0E, $E0, $07, $C0, $03, $80, $03, $80, $07, $C0, $0E, $E0, $1C, $70, $1C, $70, $1C, $70, $00, $00, $00, $00 ' X
byte $00, $00, $00, $00, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $0E, $E0, $07, $C0, $03, $80, $03, $80, $03, $80, $03, $80, $0F, $E0, $00, $00, $00, $00 ' Y
byte $00, $00, $00, $00, $1F, $F8, $1C, $38, $18, $38, $10, $70, $00, $E0, $01, $C0, $03, $80, $07, $00, $0E, $08, $1C, $18, $1C, $38, $1F, $F8, $00, $00, $00, $00 ' Z
byte $00, $00, $00, $00, $07, $F0, $07, $00, $07, $00, $07, $00, $07, $00, $07, $00, $07, $00, $07, $00, $07, $00, $07, $00, $07, $00, $07, $F0, $00, $00, $00, $00 ' [
byte $00, $00, $00, $00, $10, $00, $18, $00, $1C, $00, $0E, $00, $07, $00, $03, $80, $01, $C0, $00, $E0, $00, $70, $00, $38, $00, $1C, $00, $07, $00, $00, $00, $00 ' <Backslash>
byte $00, $00, $00, $00, $07, $F0, $00, $70, $00, $70, $00, $70, $00, $70, $00, $70, $00, $70, $00, $70, $00, $70, $00, $70, $00, $70, $07, $F0, $00, $00, $00, $00 ' ]
byte $00, $00, $01, $80, $03, $C0, $07, $E0, $0E, $70, $1C, $38, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00 ' ^
byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $7F, $FF, $7F, $FF ' _
byte $00, $00, $00, $00, $1C, $00, $1C, $00, $07, $00, $07, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00 ' '
byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $0F, $E0, $00, $70, $00, $70, $0F, $F0, $1C, $70, $1C, $70, $1C, $70, $0F, $D8, $00, $00, $00, $00 ' a
byte $00, $00, $00, $00, $1E, $00, $0E, $00, $0E, $00, $0E, $00, $0F, $F0, $0E, $38, $0E, $38, $0E, $38, $0E, $38, $0E, $38, $0E, $38, $1B, $F0, $00, $00, $00, $00 ' b
byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $0F, $E0, $1C, $70, $1C, $70, $1C, $00, $1C, $00, $1C, $70, $1C, $70, $0F, $E0, $00, $00, $00, $00 ' c
byte $00, $00, $00, $00, $00, $F8, $00, $70, $00, $70, $00, $70, $0F, $F0, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $0F, $D8, $00, $00, $00, $00 ' d
byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $0F, $E0, $1C, $70, $1C, $70, $1F, $F0, $1C, $00, $1C, $70, $1C, $70, $0F, $E0, $00, $00, $00, $00 ' e
byte $00, $00, $00, $00, $03, $E0, $07, $70, $07, $70, $07, $00, $07, $00, $1F, $E0, $1F, $E0, $07, $00, $07, $00, $07, $00, $07, $00, $1F, $C0, $00, $00, $00, $00 ' f
byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $0F, $D8, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $0F, $F0, $07, $F0, $00, $70, $1C, $70, $0F, $E0 ' g
byte $00, $00, $00, $00, $1E, $00, $0E, $00, $0E, $00, $0E, $00, $0E, $F0, $0F, $38, $0F, $38, $0E, $38, $0E, $38, $0E, $38, $0E, $38, $1E, $38, $00, $00, $00, $00 ' h
byte $00, $00, $00, $00, $01, $C0, $01, $C0, $01, $C0, $00, $00, $0F, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $0F, $F8, $00, $00, $00, $00 ' i
byte $00, $00, $00, $00, $00, $70, $00, $70, $00, $70, $00, $00, $03, $F0, $00, $70, $00, $70, $00, $70, $00, $70, $00, $70, $00, $70, $1C, $70, $0C, $F0, $07, $E0 ' j
byte $00, $00, $00, $00, $1E, $00, $0E, $00, $0E, $00, $0E, $00, $0E, $38, $0E, $70, $0E, $E0, $0F, $C0, $0E, $E0, $0E, $70, $0E, $38, $1E, $38, $00, $00, $00, $00 ' k
byte $00, $00, $00, $00, $0F, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $0F, $F8, $00, $00, $00, $00 ' l
byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $1F, $F8, $1C, $9C, $1C, $9C, $1C, $9C, $1C, $9C, $1C, $9C, $1C, $9C, $1C, $9C, $00, $00, $00, $00 ' m
byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $1F, $E0, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $00, $00, $00, $00 ' n
byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $0F, $E0, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $0F, $E0, $00, $00, $00, $00 ' o
byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $1B, $F0, $0E, $38, $0E, $38, $0E, $38, $0E, $38, $0E, $38, $0F, $F0, $0E, $00, $0E, $00, $1F, $00 ' p
byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $1F, $B0, $38, $E0, $38, $E0, $38, $E0, $38, $E0, $38, $E0, $1F, $E0, $00, $E0, $00, $E0, $01, $F0 ' q
byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $1E, $F0, $0F, $F8, $0F, $38, $0E, $00, $0E, $00, $0E, $00, $0E, $00, $1F, $00, $00, $00, $00, $00 ' r
byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $0F, $E0, $1C, $30, $1C, $30, $0F, $80, $03, $E0, $18, $70, $18, $70, $0F, $E0, $00, $00, $00, $00 ' s
byte $00, $00, $00, $00, $00, $00, $01, $00, $03, $00, $07, $00, $1F, $F0, $07, $00, $07, $00, $07, $00, $07, $00, $07, $70, $07, $70, $03, $E0, $00, $00, $00, $00 ' t
byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $0F, $D8, $00, $00, $00, $00 ' u
byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $0E, $E0, $07, $C0, $03, $80, $00, $00, $00, $00 ' v
byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $9C, $1C, $9C, $0F, $F8, $07, $70, $07, $70, $00, $00, $00, $00 ' w
byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $1C, $E0, $1C, $E0, $0F, $C0, $07, $80, $07, $80, $0F, $C0, $1C, $E0, $1C, $E0, $00, $00, $00, $00 ' x
byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $0E, $38, $0E, $38, $0E, $38, $0E, $38, $0E, $38, $07, $F0, $03, $E0, $00, $E0, $01, $C0, $1F, $80 ' y
byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $1F, $E0, $18, $E0, $11, $C0, $03, $80, $07, $00, $0E, $20, $1C, $60, $1F, $E0, $00, $00, $00, $00 ' z
byte $00, $00, $00, $00, $01, $F8, $03, $80, $03, $80, $03, $80, $07, $00, $1C, $00, $1C, $00, $07, $00, $03, $80, $03, $80, $03, $80, $01, $F8, $00, $00, $00, $00 ' {
byte $00, $00, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $00, $00 ' |
byte $00, $00, $00, $00, $1F, $80, $01, $C0, $01, $C0, $01, $C0, $00, $E0, $00, $38, $00, $38, $00, $E0, $01, $C0, $01, $C0, $01, $C0, $1F, $80, $00, $00, $00, $00 ' }
byte $00, $00, $00, $00, $1F, $1C, $3B, $9C, $39, $DC, $38, $F8, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00 ' ~
SevenSegNumFont
byte $20, $32, $30, $0A
byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $FF, $FE, $00, $01, $FF, $FF, $00, $03, $FF, $FF, $80, $01, $FF, $FF, $60, $0C, $FF, $FE, $F0, $1E, $00, $01, $F8, $3F
byte $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00
byte $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3E, $00, $00, $78, $38, $00, $00, $18, $20, $00, $00, $08, $00, $00, $00
byte $00, $20, $00, $00, $00, $38, $00, $00, $18, $3E, $00, $00, $78, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8
byte $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F
byte $00, $01, $F8, $1E, $00, $00, $F0, $0C, $FF, $FE, $60, $01, $FF, $FF, $00, $03, $FF, $FF, $80, $01, $FF, $FF, $00, $00, $FF, $FE, $00, $00, $00, $00, $00, $00, $00, $00, $00 ' 0
byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $60, $00, $00, $00, $F0, $00, $00, $01, $F8, $00
byte $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00
byte $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $00, $78, $00, $00, $00, $18, $00, $00, $00, $08, $00, $00, $00
byte $00, $00, $00, $00, $00, $00, $00, $00, $18, $00, $00, $00, $78, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8
byte $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00
byte $00, $01, $F8, $00, $00, $00, $F0, $00, $00, $00, $60, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00 ' 1
byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $FF, $FE, $00, $01, $FF, $FF, $00, $03, $FF, $FF, $80, $01, $FF, $FF, $60, $00, $FF, $FE, $F0, $00, $00, $01, $F8, $00
byte $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $00, $78, $01, $FF, $FE, $18, $03, $FF, $FF, $88, $0F, $FF, $FF
byte $E0, $27, $FF, $FF, $C0, $39, $FF, $FF, $00, $3E, $00, $00, $00, $3F, $00, $00, $00, $3F, $00, $00, $00, $3F, $00, $00, $00, $3F, $00, $00, $00, $3F, $00, $00, $00
byte $3F, $00, $00, $00, $3F, $00, $00, $00, $3F, $00, $00, $00, $3F, $00, $00, $00, $3F, $00, $00, $00, $3F, $00, $00, $00, $3F, $00, $00, $00, $3F, $00, $00, $00, $3F
byte $00, $00, $00, $1E, $00, $00, $00, $0C, $FF, $FE, $00, $01, $FF, $FF, $00, $03, $FF, $FF, $80, $01, $FF, $FF, $00, $00, $FF, $FE, $00, $00, $00, $00, $00, $00, $00, $00, $00 ' 2
byte $E0, $07, $FF, $FF, $C0, $01, $FF, $FF, $18, $00, $00, $00, $78, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8
byte $00, $01, $F8, $00, $00, $00, $F0, $00, $FF, $FE, $60, $01, $FF, $FF, $00, $03, $FF, $FF, $80, $01, $FF, $FF, $00, $00, $FF, $FE, $00, $00, $00, $00, $00, $00, $00, $00, $00 ' 3
byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $60, $0C, $00, $00, $F0, $1E, $00, $01, $F8, $3F
byte $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3E, $00, $00, $78, $39, $FF, $FE, $18, $23, $FF, $FF, $88, $0F, $FF, $FF
byte $00, $01, $F8, $00, $00, $00, $F0, $00, $00, $00, $60, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00 ' 4
byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $FF, $FE, $00, $01, $FF, $FF, $00, $03, $FF, $FF, $80, $01, $FF, $FF, $00, $0C, $FF, $FE, $00, $1E, $00, $00, $00, $3F
byte $00, $00, $00, $3F, $00, $00, $00, $3F, $00, $00, $00, $3F, $00, $00, $00, $3F, $00, $00, $00, $3F, $00, $00, $00, $3F, $00, $00, $00, $3F, $00, $00, $00, $3F, $00
byte $00, $00, $3F, $00, $00, $00, $3F, $00, $00, $00, $3F, $00, $00, $00, $3F, $00, $00, $00, $3E, $00, $00, $00, $39, $FF, $FE, $00, $23, $FF, $FF, $80, $0F, $FF, $FF
byte $00, $01, $F8, $00, $00, $00, $F0, $00, $FF, $FE, $60, $01, $FF, $FF, $00, $03, $FF, $FF, $80, $01, $FF, $FF, $00, $00, $FF, $FE, $00, $00, $00, $00, $00, $00, $00, $00, $00 ' 5
byte $E0, $27, $FF, $FF, $C0, $39, $FF, $FF, $18, $3E, $00, $00, $78, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8
byte $00, $01, $F8, $1E, $00, $00, $F0, $0C, $FF, $FE, $60, $01, $FF, $FF, $00, $03, $FF, $FF, $80, $01, $FF, $FF, $00, $00, $FF, $FE, $00, $00, $00, $00, $00, $00, $00, $00, $00 ' 6
byte $00, $01, $F8, $00, $00, $00, $F0, $00, $00, $00, $60, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00 ' 7
byte $00, $01, $F8, $1E, $00, $00, $F0, $0C, $FF, $FE, $60, $01, $FF, $FF, $00, $03, $FF, $FF, $80, $01, $FF, $FF, $00, $00, $FF, $FE, $00, $00, $00, $00, $00, $00, $00, $00, $00 ' 8
byte $00, $01, $F8, $00, $00, $00, $F0, $00, $FF, $FE, $60, $01, $FF, $FF, $00, $03, $FF, $FF, $80, $01, $FF, $FF, $00, $00, $FF, $FE, $00, $00, $00, $00, $00, $00, $00, $00, $00 ' 9
Utilities:
Abstract: Utilities
CON
FRQSAMPLES = 64 'Samples in periods for freqin
MINFREQ = 250 'Minimum frequency before considering frequency 0(must be greater than 1),
'the larger it is the longer the wait time if the frequency is lower than MINFREQ
'MINFREQ must be larger than FRQSAMPLES!!
VAR
long clkspus
'Frequency Variables
long tstflag
long frqpin
long bf[2]
byte cog
byte cogon
OBJ
PUB DelayS(intSeconds)
waitcnt(cnt + (clkfreq*intSeconds))
PUB DelayMS( time )
waitcnt (cnt + (time*(clkfreq/1000)))
PUB DelayUS( time ) 'Assumes 80MHz for accuracy's sake(5 is the minimum!!!)
if time < 5
return
waitcnt (time * 80 + cnt)
PUB IndexOf(begin,chrChar, pstrString) : intLocation | intIndex
Purpose: Returns the first index of chrChar in the string pstrString, returns -1 if it does not exist
intLocation := -1
repeat intIndex from begin to strsize(pstrString)
if byte[pstrString][intIndex] == chrChar
intLocation := intIndex
quit
PUB GetSubWordIndex(pstrString, pstrSubString,chrDelimiter) : del | index,subind, intlength, intsublength, sub1, sub2, match
Purpose: F
intsublength := strsize(pstrSubString)
intlength := strsize(pstrString)
sub1 := 0
match := false
del := 0
repeat index from 0 to intlength - 1
if byte[pstrString][index] == chrDelimiter
sub2 := index
if (sub2 - sub1) == intsublength 'If length is correct
match := true
'Compare String
repeat subind from sub1 to sub2 - 1
if byte[pstrString][subind] <> byte[pstrSubString][subind - sub1]
match := false
quit
ifnot match
sub1 := sub2 + 1
del++
else
quit
ifnot match
del := -1
PUB GetSubWord(intIndex ,pstrSubString, pstrString, delimiter) | intSpaceIndex, intLoopIndex, intSubIndex, intLength
Purpose: Get Word seperated by delimiter at index intIndex
'Note: Assumes single space between words.
intSpaceIndex := 1
intSubIndex := 0
intLength := strsize(pstrString)
repeat intLoopIndex from 0 to intLength
'Space?
if byte[pstrString + intLoopIndex] <> delimiter
''No
if intSpaceIndex == intIndex
byte[pstrSubString + intSubIndex] := byte[pstrString + intLoopIndex]
intSubIndex++
else
'Yes, is a space
intSpaceIndex++
PUB ClearString(pstrString) | intLength, intLoopIndex
repeat intLoopIndex FROM 0 TO intLength
byte[pstrString][intLoopIndex] := 0
PUB TotalTrimString(pstrString) | intLength, intLoopIndex, intSubIndex, Flag
'Trim start and end and make all spaces one space if multiple spaces
Flag := 0
'Trim start
'if not a space
if byte[pstrString + intLoopIndex] <> 32
'if not the first charachter
if intLoopIndex > 0
'Trim Spaces
StringRemove(pstrString,0,intLoopIndex)
'Renew length
quit
'Trim end
repeat intLoopIndex from intLength - 1 to 0
'If not a space
'if not the last charachter.
if intLoopIndex < (intLength - 1)
'Trim Spaces
StringRemove(pstrString, intLoopIndex + 1,intLength - intLoopIndex - 1)
'renew length
quit
intLoopIndex := 0
if intLength <> 0
'Trim Duplicate Spaces
repeat
if byte[pstrString + intLoopIndex] == 32
if Flag == 1
'Duplicate space, set flag
intSubIndex := intLoopIndex
Flag := 2
elseif Flag <> 2
Flag := 1
elseif Flag == 2
StringRemove(pstrString,intSubIndex,intLoopIndex-intSubIndex)
intLoopIndex := intSubIndex
Flag := 0
else
Flag := 0
if intLoopIndex == (intLength - 1)
quit
intLoopIndex++
PUB CompareString(pstrone, pstrtwo,length) : eq | index
eq := true
if byte[pstrone][index] <> byte[pstrtwo][index]
eq := false
quit
PUB StringRemove(pstrString, intBeginIndex, intRemoveLength) | intLength, intLoopIndex, intSubIndex
'Removelength more than length?
if ((intRemoveLength + intBeginIndex) =< intLength)
'No
repeat intLoopIndex from 0 to intLength - intRemoveLength - 1
if intLoopIndex > intBeginIndex - 1
byte[pstrString + intLoopIndex] := byte[pstrString + intLoopIndex + intRemoveLength]
else
next
'Clear rest of string
repeat intLoopIndex from intSubIndex to intLength
byte[pstrString + intLoopIndex] := 0
elseif intRemoveLength > intBeginIndex
PUB StringAppend(pstrString,pstrAppend) | intIndex, intLength, intALength
intALength := strsize(pstrAppend)
intIndex := intLength
repeat intALength
byte [pstrString][intIndex++] := byte[pstrAppend][intIndex-intLength]
PUB ClearBArray(bptr, count) | i
repeat i from 0 to count - 1
byte[bptr][i] := 0
PUB ClearWArray(bptr, count) | i
word[bptr][i] := 0
PUB ClearLArray(bptr, count) | i
long[bptr][i] := 0
PUB toHex(value) | val
if val < 256
val := value / 16
val <<= 4
val |= value // 16
return val
else
return 0
PUB toDec(value) | val, tmp
'Get first hex digit
tmp := value
val := tmp >> 4
'get second hex digit
tmp -= val * 16
val *= 16
val += tmp
return val
PUB ValidAsciiInteger(intIn) : Valid
Valid := false
'Valid ascii number?
if intIn < 58 and intIn > 47
'Yes
Valid := true
PUB ValidAsciiPrint(In) : Valid
Valid := false
'Valid ascii?
if In => 32 and In =< 126 'Valid ascii printablevalue
'Yes
Valid := true
PUB GetPulse(state, pin) : time
returns pulse length in us
waitpeq(state << pin, |< pin, 0)
time := cnt
waitpne(state << pin, |< pin, 0)
time := cnt - time
time := time / (clkfreq/1_000_000)
PUB RCTime(state, pin) : time
Returns time pin is in state in microseconds
;Returns 0 if pin is not in state
if INA[pin] == state
time := cnt
time := cnt - time 'Get count
time := time / (clkfreq / 1_000_000) 'Get time in microseconds
else
time := 0
PUB FreqInStart
Start a cog for frequency in testing
tstflag := 0 'Start cog in waiting state
cogon := (cog := cognew(@start, @tstflag)) > 0
PUB FreqIn(tstpin) | value, sum , counter, waittime
Get input frequency on pin
repeat
if tstflag == 0
'Set pin to input
DIRA[tstpin]~
counter := 0
waittime := 1000/(MINFREQ / FRQSAMPLES) 'Get Milliseconds to wait
frqpin := |< tstpin 'Set pin mask for asm use
tstflag := 1 'Tell cog to test
repeat until tstflag == 0 or counter == waittime
counter++
DelayMS(1)
if counter == waittime 'If timed out, return 0 as frequency
return 0
'Test if system clock was reset(would cause invalid frequency reading), and read again if so
if bf[0] > bf[1]
next
sum := bf[1] - bf[0] 'Get clocks for all samples
'Get average
value := sum / FRQSAMPLES
'Get freq from average clocks
value := clkfreq / value
quit
else
next
return value
PUB FreqInStop
Stop the frequency in cog
if cogon~ 'If cog is on, post clear cogon to zero
cogstop(cog) 'Stop Cog
PUB FreqOut(pin, freq, time) | count, t
Output freq out of pin for time(Sec), amount of time
'Get clocks from freq
t := clkfreq / freq
'Get count of times
count := freq * time
'Set pin to output
DIRA[pin]~~
repeat count
!OUTA[pin]
waitcnt(cnt + t)
DAT
org 0
start
mov ptr, par 'Get Pointer
mov r1, #0
wrlong r1, ptr 'Clear flag
:waitloop rdlong r1, ptr 'Read flag, and test if still 0
tjz r1, #:waitloop
mov bfr, ptr
add bfr, #4 'Get pointer to pin
rdlong frpin, bfr
add bfr, #4 'Get buffer pointer
mov ctr, #FRQSAMPLES
mov r1, cnt
wrlong r1, bfr
:frqloop waitpne zero,frpin
waitpeq zero, frpin
'Get counter
'Write counter to buffer
'Goto next location
djnz ctr, #:frqloop
add bfr, #4
mov r1, cnt
wrlong r1, bfr
jmp #start
frpin LONG 0
zero LONG 0
r1 res 1
ctr res 1
bfr res 1
ptr res 1
fit 496
SPILCD:
[code]{{
Abstract:
CON
'Clocking settings
VAR
long data[8]
ASM DATA:
data[0] := Data pin
data[5] := bcolor
data[6] := x
data[7] := y
byte cogon
byte cog
OBJ
'Set Asm data
NumBytes := 8
repeat 8
' drop clock
OUTA[data[1]] := 0
' raise clock
OUTA[data[1]] := 1
data[2] := char
data[4] := color
data[5] := bcolor
data[6] := x
data[7] := y
data[2] := fontloc
data[2] := bytOut
PUB stop
if cogon~
cogstop(cog)
DAT
org 0
entry
mov spicmask, #1
shl spidmask, spid
shl spicmask, spic
or dira, spicmask
add dtyploc, #4
mov cloc, dtyploc
add cloc, #4
mov bcloc, cloc
add bcloc, #4
mov xloc, bcloc
add xloc, #4
mov yloc, xloc
add yloc, #4
:loop
tjz r1, #:loop
:writeeight
shl wrdt, #24
:wreghtloop
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
jmp #:loop
:writesixtn
shl wrdt, #16
:wrsxtnloop
mov phsa, wrdt
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
jmp #:loop
:writechar
mov r1, wrdt
sub r1, foffset
mov r2, fxsize
Do all LCD's use this form of mapping? How did you know this one did? Also, does that mean that anytime I set the xy coordinates that the x coordinates must be a factor of 4, or only with images? Does it do this with verticle as well?
I have no Idea how you knew that of the top of your head.........:thumb:
If it's not generated from code, perhaps it's some kind of "bleeding" of the pixels at the pixel boundary between different colors. Wonder if the black bar would happen at the bottom of the rectangle (based on the orientation in the photo) if you inverted the colors of the rectangle and background. Well, an inversion might not exhibit the line as the line might be from the specific order of the RGB sub-pixels. Looking closely, you can see how the red pixels are slightly shifted from the green. My apologies if this is caused by code (haven't looked at that). BTW, I guess that's a portrait style screen rather than a landscape one, even though the pic shows the screen in a horizontal (landscape) orientation.
You can easily display bmps that are not multiple of four, you just need extra code to handle that case. It hasn't nothing to do with the LCD.
