Issue drawing BMP Pics to LCD unless they take up screen — Parallax Forums
handermanntrhandermanntr Posts: 18
edited 2014-11-14 15:08 in Propeller 1
I am using the sainsmart 1.8" LCD to view bmp images stored on an SD Card. Below is the code. The issue is that it works perfect when the BMP file is the same size as the screen, but does not work when the image is smaller than the screen. Here are a few photos of it working, and not working. I have already tried multiple images, so I know it is not the file. The images are the same except on is 128 * 160(the whole screen), and one is 90 x 120. I did not include the SD Classes because I know they work, essentially the BMP file is read in blocks of 512-bytes. The BMP files are a 24 bit depth, but converted to a 565(rgb) layout for the screens 16bit depth. Any help would be appreciated. Thanks!
Main Object:
    Name: Trevor Handermann
    Abstract: SS TFT 1.8" LCD Driver
CON
    'Clocking settings
  _clkmode = xtal1 + pll16x
  _xinfreq = 5_000_000
  SCREEN_WIDTH = 128
  SCREEN_HEIGHT = 160
  TEXT_WIDTH = 5
  'LCD COMMANDS
  COLADDRSET = $2A
  ROWADDRSET = $2B
  RAMWR = $2C
  RAMRD = $2E
  WIDTH = 128
  HEIGHT = 160
  SWRESET = $01
  SLEEPIN = $10
  SLEEPOUT = $11
  FRMCTR1 = $B1
  FRMCTR2 = $B2
  FRMCTR3 = $B3
  DISPON = $29
  DISPOFF = $28
  INVCTR = $B4  'Display Inversion Control
  PWCTR1 = $C0  'Power Control
  PWCTR2 = $C1
  PWCTR3 = $C2
  PWCTR4 = $C3
  PWCTR5 = $C4
  MADCTL = $36  'Memory Access Control
  INVOFF = $20  'Invert display off
  INVON = $21
  COLMOD = $3A    'Color Mode
  NORON = $13     'Normal Display On
  GMCTRP1 = $E0
  GMCTRN1 = $E1
  VMCTR1 = $C5    'Power Control
  'BBBBB_GGGGGG_RRRRR
  'Colors
  WHITE = $FFFF
  BLACK = 0
  RED = $F800
  BLUE = $F800
  GREEN = $07E0
  PURPLE = $F81F
  YELLOW = $07FF
  ORANGE = %00000_100000_11111
  BROWN = %01000_011000_10001
VAR
  byte cs, sda, scl, dc, rst    'Pins
  byte fxsize, fysize, foffset, font
  long floc
  byte buffer[512]
  byte rollover[2]
  long bmpimgoffset, bmpwidth, bmpheight, bmpdepth
OBJ
  Utilities : "Utilities"
  SPI : "SPILCD"
  term : "Parallax Serial Terminal"
  num : "Simple_Numbers"
  SD : "SDFAT"
PUB Start | te, tes
  term.Start(9600)
  Init(4,1,0,2,3)
  SetFont(0)
  SD.Mount(true,0,0,0,0)
  SD.LoadPartitions
  SD.LoadPartition(0)
  'Term.str(num.dec(te))
  SD.LoadDir(-1)                'Load root dir
  SPI.SetFont(@SmallFont)
    'Fill screen back color
  FillScreen(RED)
  'Utilities.DelayS(2)
  te := DrawBMP(string("GUN.BMP"),0,0)
  repeat
PUB Init( cspin, sdapin, sclpin, dcpin, rstpin)
  cs := cspin
  sda := sdapin
  scl := sclpin
  dc := dcpin
  rst := rstpin
  'Init SPI Interface
  SPI.InitSPI(sda, scl)
  InitR
PUB DrawBMP(pstr,x,y): okay | clusters,index, subind, bufind,r,g,b, col,rollcnt, curloc, r1
 Purpose: Draws BMP image with name @pstr at point x,y. File must be in currently loaded directory, and pic must fit within screen
  'Get file list
  index := SD.GetFileList
  okay := 0
  r1 := Utilities.GetSubWordIndex(index, pstr,">") 'Get index in directory to load BMP file
  if r1 <> -1 'If file exists, then load
    clusters := SD.GetFileClusters(r1) 'Load Clusters for file
    rollcnt := 0
    if clusters > 0
      if ReadBMPHeader          'Test if valid BMP File
        curloc := 0
        bufind :=  bmpimgoffset
        SetAddrWindow(x,y,x + bmpwidth - 1, y + bmpheight - 1)
        repeat index from 0 to bmpheight - 1
          repeat subind from 0 to bmpwidth - 1
            if rollcnt > 0
              case rollcnt
                1:
                  b := rollover[0]
                  g := buffer[0]
                  r := buffer[1]
                  bufind := 2
                2:
                  b := rollover[0]
                  g := rollover[1]
                  r := buffer[0]
                  bufind := 1
              rollcnt := 0
            else
              'Read pixel
              b := buffer[bufind]
              'Term.str(string("  b:"))
              'Term.str(num.hex(b, 2))
              g := buffer[bufind + 1]
              'Term.str(string("  g:"))
              'Term.str(num.hex(g, 2))
              r := buffer[bufind + 2]
              'Term.str(string("  r:"))
              'Term.str(num.hex(r, 2))
              'Term.str(string(" / "))
              'Increment buffer
              bufind += 3
            'Convert 888 to 565 pixel depth
            col := ((r & $F8) << 8) | ((g & $FC) << 3) | ((b & $F8) >> 3)
            'Term.str(string(" col:"))
            'Term.str(num.dec(col))
            'repeat
            'Push color to LCD
            PushColor(col)
            if bufind > 509
              if bufind <> 512
                rollcnt := 512 - bufind
                'Get rollover bytes
                repeat col from bufind to 511
                  rollover[col - bufind] := buffer[col]
              else
                bufind := 0
              'Read next block into buffer
              SD.ReadFile(++curloc,@buffer)
      else
        okay := 213
    else
      okay := 212
  else
    okay := 211
PRI ReadBMPHeader : okay | tmp
  'Read first portion of file
  SD.ReadFile(0,@buffer)
  okay := false
  'Verify header
  if buffer[0] == $42 and buffer[1] == $4d
    'Header ok
    bmpimgoffset := ReverseLongBuffer(10)
    'Verify width and height
    bmpwidth := ReverseLongBuffer(18)
    bmpheight := ReverseLongBuffer(22)
    if bmpwidth =< SCREEN_WIDTH and bmpheight =< SCREEN_HEIGHT
      'Verify header
      if buffer[26] == 1 and buffer[27] == 0
        'Header ok
         bmpdepth := ReverseWordBuffer(28)
         'Verify Compression
         if ReverseLongBuffer(30)== 0
          'Correct compression
          okay := true
PRI ReverseLongBuffer(location) : value | index
  value := 0
  repeat index from 0 to 3
    value |= (buffer[location+index] << (index * 8))
PRI ReverseWordBuffer(location) : value | index
  value := 0
  repeat index from 0 to 1
PUB WriteCommand(command)
  OUTA[dc]~
  OUTA[cs]~
  SPI.WriteSPI(command)
  OUTA[cs]~~
PRI WriteData(data)
  OUTA[dc]~~
  OUTA[cs]~
  SPI.WriteSPI(data)
  OUTA[cs]~~
PUB SetAddrWindow(x0, y0, x1, y1)
  WriteCommand(COLADDRSET)      'Set Column
  WriteData(0)
  WriteData(x0)                 'Set XSTART
  WriteData(0)
  WriteData(x1)                 'Set XEND
  WriteCommand(ROWADDRSET)      'Set Row
  WriteData(0)
  WriteData(y0)                 'Set XSTART
  WriteData(0)
  WriteData(y1)                 'Set XEND
  WriteCommand(RAMWR)           'Write to RAM
PUB PushColor(color)
  OUTA[dc]~~
  OUTA[cs]~
  SPI.WriteSPICLR(1, color)
  OUTA[cs]~~
PUB SetXY(x,y)
  SetAddrWindow(x,y,x + 1, y + 1)
PUB DrawPixel(x,y,color)
  if x < WIDTH and Y < HEIGHT and x => 0 and y => 0
    SetAddrWindow(x,y,x+1,y+1)    'Set window to 1 pixel
    PushColor(color)              'Push the color to the pixel
PUB FillScreen(color) | x, y
  SetAddrWindow(0,0,WIDTH - 1, HEIGHT -1)               'Set window to whole screen
  OUTA[dc]~~
  OUTA[cs]~
  SPI.WriteSPICLR(20_480, color)
  OUTA[cs]~~
PUB DrawString(x,y,pstrString,color, bcolor) | length, chr, index, space, wordlength, xbegin
  length := strsize(pstrString)
  repeat index from  0 to length - 1
    if index <> 0
      x += fxsize
    chr := byte[pstrString + index]
    DrawChar(x,y,chr,color,bcolor)
    if chr == 32
      space := Utilities.IndexOf(index + 1, 32, pstrString)                     'Get index of next space
      if space == -1
        space := length - 1
      wordlength := space - (index + 1)                   'Get length of next word
      if (wordlength * fxsize) + x => WIDTH
        y += fysize
        x := 0
    if (x + (2 * fxsize)) > WIDTH           'If end of screen
      y += fysize
      x :=  0
PUB DrawVerticalLine(x,y,length,color)
  DrawHVLine(x,y,length,color,1)
PUB DrawHorizontalLine(x,y,length,color)
  DrawHVLine(x,y,length,color,0)
PRI DrawHVLine(x,y,length,color,rotflag)
 Note: 1 = Verticle, 0 = horizontal
  if rotflag == 1
    SetAddrWindow(x,y,x,y+length)
  else
    SetAddrWindow(x,y,x+length,y+1)
  OUTA[dc]~~
  OUTA[cs]~
  SPI.WriteSPICLR(length, color)
  OUTA[cs]~~
PUB DrawCircle(x0,y0,r,color) | x,y,ddfx,ddfy,f
  f := 1 - r
  ddfx := 1
  ddfy := -2 * r
  x := 0
  y := r
  DrawPixel(x0,y0+r,color)
  DrawPixel(x0,y0-r,color)
  DrawPixel(x0+r,y0,color)
  DrawPixel(x0-r,y0,color)
  repeat while x < y
    if f=> 0
      y--
      ddfy += 2
      f += ddfy
    x++
    ddfx += 2
    f += ddfx
    DrawPixel(x0 + x, y0 + y, color)
    DrawPixel(x0 - x, y0 + y, color)
    DrawPixel(x0 + x, y0 - y, color)
    DrawPixel(x0 - x, y0 - y, color)
    DrawPixel(x0 + y, y0 + x, color)
    DrawPixel(x0 - y, y0 + x, color)
    DrawPixel(x0 + y, y0 - x, color)
    DrawPixel(x0 - y, y0 - x, color)
PUB FillCircle(x0,y0,r,color) | f, ddfx, ddfy, x,y
  f := 1 - r
  ddfx := 1
  ddfy := -2 * r
  x := 0
  y := r
  DrawVerticalLine(x0,y0-r,2*r+1,color)
  repeat while x < y
    if f => 0
      y--
      ddfy += 2
      f += ddfy
    x++
    ddfx += 2
    f += ddfx
    DrawVerticalLine(x0+x, y0-y, 2*y+1, color)
    DrawVerticalLine(x0-x, y0-y, 2*y+1, color)
    DrawVerticalLine(x0+y, y0-x, 2*x+1, color)
    DrawVerticalLine(x0-y, y0-x, 2*x+1, color)
PUB DrawRect(x,y,w,h,color)
  DrawHorizontalLine(x, y, w, color)
  DrawHorizontalLine(x, y+h-1, w, color)
  DrawVerticalLine(x, y, h, color)
  DrawVerticalLine(x+w-1, y, h, color)
PUB FillRect(x,y,w,h,color)
  SetAddrWindow(x, y, x+w-1, y+h-1)
  OUTA[dc]~~
  OUTA[cs]~
  SPI.WriteSPICLR(w*h,color)
  OUTA[cs]~~
PUB DrawChar(x,y,char,color,bcolor) | index, in1, chr, line, in2,temp
   '50 longs per digit
  SetAddrWindow(x,y,x+fxsize-1,y+fysize-1)
  temp := ((char - foffset) * ((fxsize /8) * fysize))
  repeat index from 0 to ((fxsize/8) * fysize) - 1
    chr := byte[floc][temp]
    repeat in1 from 0 to 7
      if (chr & (1<<(7-in1))) <> 0
        PushColor(color)
      else
        PushColor(bcolor)
    temp++
PUB DrawCharNew(x,y,char,color,bcolor) | index, in1, chr, line, in2,temp
   '50 longs per digit
  OUTA[dc]~~
  OUTA[cs]~
  SPI.WriteSPICHR(x, y,char,color,bcolor)
  OUTA[cs]~~
PUB DrawLine(x0,y0,x1,y1, color) | steep, dx, dy, err, ystep
  steep := ||y1-y0 > ||x1-x0
  if steep
    Swap(x0,y0)
    Swap(x1,y1)
  if x0 > x1
    Swap(x0,x1)
    Swap(y0,y1)
  dx := x1 - x0
  dy := ||y1-y0
  err := dx / 2
  if y0 < y1
    ystep := 1
  else
    ystep := -1
  repeat while x0 =< x1
    if steep
      DrawPixel(y0,x0,color)
    else
      DrawPixel(x0,y0,color)
    err -= dy
    if err < 0
      y0 += ystep
      err += dx
    x0++
PRI Swap(a,b) | t
  t := a
  a := b
  b := t
PRI InitR
  'Set Pin Dirs
  DIRA[dc]~~
  DIRA[cs]~~
  DIRA[rst]~~
  DIRA[sda]~~
  DIRA[scl]~~
  OUTA[cs]~
  'Reset hardware
  OUTA[rst]~~
  Utilities.DelayMS(500)
  OUTA[rst]~
  OUTA[rst]~~
  'Reset Software
  WriteCommand(SWRESET)
  Utilities.DelayMS(150)
  'Disable Sleep Mode
  WriteCommand(SLEEPOUT)
  'Frame rate control normal
  WriteCommand(FRMCTR1)
  WriteData(1)
  WriteData($2C)
  WriteData($2D)
  'Frame rate control idle
  WriteCommand(FRMCTR2)
  WriteData(1)
  WriteData($2C)
  WriteData($2D)
  'Frame rate control partial
  WriteCommand(FRMCTR3)
  WriteData(1)
  WriteData($2C)
  WriteData($2D)
  WriteData(1)
  WriteData($2C)
  WriteData($2D)
  WriteCommand(INVCTR)
  WriteData($07)                'No Inversion
  'Power Control Settings
  WriteCommand(PWCTR1)
  WriteData($A2)
  WriteData($02)      ' -4.6V
  WriteData($84)      ' AUTO mode
  WriteCommand(PWCTR2)  ' power control
  WriteData($C5)      ' VGH25 = 2.4C VGSEL = -10 VGH = 3 * AVDD
  WriteCommand(PWCTR3)  ' power control
  WriteData($0A)      ' Opamp current small
  WriteData($00)      ' Boost frequency
  WriteCommand(PWCTR4)  ' power control
  WriteData($8A)      ' BCLK/2, Opamp current small & Medium low
  WriteData($2A)
  WriteCommand(PWCTR5)  ' power control
  WriteData($8A)
  WriteData($EE)
  WriteCommand(VMCTR1)  ' power control
  WriteData($0E)
  WriteCommand(INVOFF)    ' don't invert display
  WriteCommand(MADCTL)  ' memory access control (directions)
  WriteData($40)  ' row address/col address, bottom to top refresh
  WriteCommand(COLMOD)  ' set color mode
  WriteData($05)        ' 16-bit color
  WriteCommand(COLADDRSET)  ' column addr set
  WriteData($00)
  WriteData($00)   ' XSTART = 0
  WriteData($00)
  WriteData($7F)   ' XEND = 127
  WriteCommand(ROWADDRSET)  ' row addr set
  WriteData($00)
  WriteData($00)
  WriteData($9F)    ' XEND = 159
  WriteCommand(GMCTRP1)
  WriteData($0f)
  WriteData($1a)
  WriteData($0f)
  WriteData($18)
  WriteData($2f)
  WriteData($28)
  WriteData($20)
  WriteData($22)
  WriteData($1f)
  WriteData($1b)
  WriteData($23)
  WriteData($37)
  WriteData($00)
  WriteData($07)
  WriteData($02)
  WriteData($10)
  WriteCommand(GMCTRN1)
  WriteData($0f)
  WriteData($1b)
  WriteData($0f)
  WriteData($17)
  WriteData($33)
  WriteData($2c)
  WriteData($29)
  WriteData($2e)
  WriteData($30)
  WriteData($30)
  WriteData($39)
  WriteData($3f)
  WriteData($00)
  WriteData($07)
  WriteData($03)
  WriteData($10)
  WriteCommand(DISPON)
  Utilities.DelayMS(100)
  WriteCommand(NORON)  ' normal display on
  Utilities.DelayMS(10)
PUB SetFont(f)
  font := f
  CASE font
    0:
      floc := @SmallFont
    1:
      floc := @BigFont
    2:
      floc := @SevenSegNumFont
  fxsize := byte[floc++]
  fysize := byte[floc++]
  foffset := byte[floc++]
  floc++
DAT
SmallFont
        byte $08, $0C, $20, $5F
        byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00   ' <Space>
        byte $00, $00, $20, $20, $20, $20, $20, $20, $00, $20, $00, $00   ' !
        byte $00, $28, $50, $50, $00, $00, $00, $00, $00, $00, $00, $00   ' "
        byte $00, $00, $28, $28, $FC, $28, $50, $FC, $50, $50, $00, $00   ' #
        byte $00, $20, $78, $A8, $A0, $60, $30, $28, $A8, $F0, $20, $00   ' $
        byte $00, $00, $48, $A8, $B0, $50, $28, $34, $54, $48, $00, $00   ' %
        byte $00, $00, $20, $50, $50, $78, $A8, $A8, $90, $6C, $00, $00   ' &
        byte $00, $40, $40, $80, $00, $00, $00, $00, $00, $00, $00, $00   ' '
        byte $00, $04, $08, $10, $10, $10, $10, $10, $10, $08, $04, $00   ' (
        byte $00, $40, $20, $10, $10, $10, $10, $10, $10, $20, $40, $00   ' )
        byte $00, $00, $00, $20, $A8, $70, $70, $A8, $20, $00, $00, $00   ' *
        byte $00, $00, $20, $20, $20, $F8, $20, $20, $20, $00, $00, $00   ' +
        byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $40, $40, $80   ' ,
        byte $00, $00, $00, $00, $00, $F8, $00, $00, $00, $00, $00, $00   ' -
        byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $40, $00, $00   ' .
        byte $00, $08, $10, $10, $10, $20, $20, $40, $40, $40, $80, $00   ' /
        byte $00, $00, $70, $88, $88, $88, $88, $88, $88, $70, $00, $00   ' 0
        byte $00, $00, $20, $60, $20, $20, $20, $20, $20, $70, $00, $00   ' 1
        byte $00, $00, $70, $88, $88, $10, $20, $40, $80, $F8, $00, $00   ' 2
        byte $00, $00, $70, $88, $08, $30, $08, $08, $88, $70, $00, $00   ' 3
        byte $00, $00, $10, $30, $50, $50, $90, $78, $10, $18, $00, $00   ' 4
        byte $00, $00, $F8, $80, $80, $F0, $08, $08, $88, $70, $00, $00   ' 5
        byte $00, $00, $70, $90, $80, $F0, $88, $88, $88, $70, $00, $00   ' 6
        byte $00, $00, $F8, $90, $10, $20, $20, $20, $20, $20, $00, $00   ' 7
        byte $00, $00, $70, $88, $88, $70, $88, $88, $88, $70, $00, $00   ' 8
        byte $00, $00, $70, $88, $88, $88, $78, $08, $48, $70, $00, $00   ' 9
        byte $00, $00, $00, $00, $20, $00, $00, $00, $00, $20, $00, $00   ' :
        byte $00, $00, $00, $00, $00, $20, $00, $00, $00, $20, $20, $00   ' ;
        byte $00, $04, $08, $10, $20, $40, $20, $10, $08, $04, $00, $00   ' <
        byte $00, $00, $00, $00, $F8, $00, $00, $F8, $00, $00, $00, $00   ' =
        byte $00, $40, $20, $10, $08, $04, $08, $10, $20, $40, $00, $00   ' >
        byte $00, $00, $70, $88, $88, $10, $20, $20, $00, $20, $00, $00   ' ?
        byte $00, $00, $70, $88, $98, $A8, $A8, $B8, $80, $78, $00, $00   ' @
        byte $00, $00, $20, $20, $30, $50, $50, $78, $48, $CC, $00, $00   ' A
        byte $00, $00, $F0, $48, $48, $70, $48, $48, $48, $F0, $00, $00   ' B
        byte $00, $00, $78, $88, $80, $80, $80, $80, $88, $70, $00, $00   ' C
        byte $00, $00, $F0, $48, $48, $48, $48, $48, $48, $F0, $00, $00   ' D
        byte $00, $00, $F8, $48, $50, $70, $50, $40, $48, $F8, $00, $00   ' E
        byte $00, $00, $F8, $48, $50, $70, $50, $40, $40, $E0, $00, $00   ' F
        byte $00, $00, $38, $48, $80, $80, $9C, $88, $48, $30, $00, $00   ' G
        byte $00, $00, $CC, $48, $48, $78, $48, $48, $48, $CC, $00, $00   ' H
        byte $00, $00, $F8, $20, $20, $20, $20, $20, $20, $F8, $00, $00   ' I
        byte $00, $00, $7C, $10, $10, $10, $10, $10, $10, $90, $E0, $00   ' J
        byte $00, $00, $EC, $48, $50, $60, $50, $50, $48, $EC, $00, $00   ' K
        byte $00, $00, $E0, $40, $40, $40, $40, $40, $44, $FC, $00, $00   ' L
        byte $00, $00, $D8, $D8, $D8, $D8, $A8, $A8, $A8, $A8, $00, $00   ' M
        byte $00, $00, $DC, $48, $68, $68, $58, $58, $48, $E8, $00, $00   ' N
        byte $00, $00, $70, $88, $88, $88, $88, $88, $88, $70, $00, $00   ' O
        byte $00, $00, $F0, $48, $48, $70, $40, $40, $40, $E0, $00, $00   ' P
        byte $00, $00, $70, $88, $88, $88, $88, $E8, $98, $70, $18, $00   ' Q
        byte $00, $00, $F0, $48, $48, $70, $50, $48, $48, $EC, $00, $00   ' R
        byte $00, $00, $78, $88, $80, $60, $10, $08, $88, $F0, $00, $00   ' S
        byte $00, $00, $F8, $A8, $20, $20, $20, $20, $20, $70, $00, $00   ' T
        byte $00, $00, $CC, $48, $48, $48, $48, $48, $48, $30, $00, $00   ' U
        byte $00, $00, $CC, $48, $48, $50, $50, $30, $20, $20, $00, $00   ' V
        byte $00, $00, $A8, $A8, $A8, $70, $50, $50, $50, $50, $00, $00   ' W
        byte $00, $00, $D8, $50, $50, $20, $20, $50, $50, $D8, $00, $00   ' X
        byte $00, $00, $D8, $50, $50, $20, $20, $20, $20, $70, $00, $00   ' Y
        byte $00, $00, $F8, $90, $10, $20, $20, $40, $48, $F8, $00, $00   ' Z
        byte $00, $38, $20, $20, $20, $20, $20, $20, $20, $20, $38, $00   ' [
        byte $00, $40, $40, $40, $20, $20, $10, $10, $10, $08, $00, $00   ' <Backslash>
        byte $00, $70, $10, $10, $10, $10, $10, $10, $10, $10, $70, $00   ' ]
        byte $00, $20, $50, $00, $00, $00, $00, $00, $00, $00, $00, $00   ' ^
        byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $FC   ' _
        byte $00, $20, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00   ' '
        byte $00, $00, $00, $00, $00, $30, $48, $38, $48, $3C, $00, $00   ' a
        byte $00, $00, $C0, $40, $40, $70, $48, $48, $48, $70, $00, $00   ' b
        byte $00, $00, $00, $00, $00, $38, $48, $40, $40, $38, $00, $00   ' c
        byte $00, $00, $18, $08, $08, $38, $48, $48, $48, $3C, $00, $00   ' d
        byte $00, $00, $00, $00, $00, $30, $48, $78, $40, $38, $00, $00   ' e
        byte $00, $00, $1C, $20, $20, $78, $20, $20, $20, $78, $00, $00   ' f
        byte $00, $00, $00, $00, $00, $3C, $48, $30, $40, $78, $44, $38   ' g
        byte $00, $00, $C0, $40, $40, $70, $48, $48, $48, $EC, $00, $00   ' h
        byte $00, $00, $20, $00, $00, $60, $20, $20, $20, $70, $00, $00   ' i
        byte $00, $00, $10, $00, $00, $30, $10, $10, $10, $10, $10, $E0   ' j
        byte $00, $00, $C0, $40, $40, $5C, $50, $70, $48, $EC, $00, $00   ' k
        byte $00, $00, $E0, $20, $20, $20, $20, $20, $20, $F8, $00, $00   ' l
        byte $00, $00, $00, $00, $00, $F0, $A8, $A8, $A8, $A8, $00, $00   ' m
        byte $00, $00, $00, $00, $00, $F0, $48, $48, $48, $EC, $00, $00   ' n
        byte $00, $00, $00, $00, $00, $30, $48, $48, $48, $30, $00, $00   ' o
        byte $00, $00, $00, $00, $00, $F0, $48, $48, $48, $70, $40, $E0   ' p
        byte $00, $00, $00, $00, $00, $38, $48, $48, $48, $38, $08, $1C   ' q
        byte $00, $00, $00, $00, $00, $D8, $60, $40, $40, $E0, $00, $00   ' r
        byte $00, $00, $00, $00, $00, $78, $40, $30, $08, $78, $00, $00   ' s
        byte $00, $00, $00, $20, $20, $70, $20, $20, $20, $18, $00, $00   ' t
        byte $00, $00, $00, $00, $00, $D8, $48, $48, $48, $3C, $00, $00   ' u
        byte $00, $00, $00, $00, $00, $EC, $48, $50, $30, $20, $00, $00   ' v
        byte $00, $00, $00, $00, $00, $A8, $A8, $70, $50, $50, $00, $00   ' w
        byte $00, $00, $00, $00, $00, $D8, $50, $20, $50, $D8, $00, $00   ' x
        byte $00, $00, $00, $00, $00, $EC, $48, $50, $30, $20, $20, $C0   ' y
        byte $00, $00, $00, $00, $00, $78, $10, $20, $20, $78, $00, $00   ' z
        byte $00, $18, $10, $10, $10, $20, $10, $10, $10, $10, $18, $00   ' {
        byte $10, $10, $10, $10, $10, $10, $10, $10, $10, $10, $10, $10   ' |
        byte $00, $60, $20, $20, $20, $10, $20, $20, $20, $20, $60, $00   ' }
        byte $40, $A4, $18, $00, $00, $00, $00, $00, $00, $00, $00, $00  ' ~
BigFont
        byte $10, $10, $20, $5F
        byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00   '  <Space>
        byte $00, $00, $00, $00, $07, $00, $0F, $80, $0F, $80, $0F, $80, $0F, $80, $0F, $80, $07, $00, $07, $00, $00, $00, $00, $00, $07, $00, $07, $00, $07, $00, $00, $00   ' !
        byte $00, $00, $0E, $38, $0E, $38, $0E, $38, $0E, $38, $06, $30, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00   ' "
        byte $00, $00, $0C, $30, $0C, $30, $0C, $30, $7F, $FE, $7F, $FE, $0C, $30, $0C, $30, $0C, $30, $0C, $30, $7F, $FE, $7F, $FE, $0C, $30, $0C, $30, $0C, $30, $00, $00   ' #
        byte $00, $00, $02, $40, $02, $40, $0F, $F8, $1F, $F8, $1A, $40, $1A, $40, $1F, $F0, $0F, $F8, $02, $58, $02, $58, $1F, $F8, $1F, $F0, $02, $40, $02, $40, $00, $00   ' $
        byte $00, $00, $00, $00, $00, $00, $0E, $10, $0E, $30, $0E, $70, $00, $E0, $01, $C0, $03, $80, $07, $00, $0E, $70, $0C, $70, $08, $70, $00, $00, $00, $00, $00, $00   ' %
        byte $00, $00, $00, $00, $0F, $00, $19, $80, $19, $80, $19, $80, $0F, $00, $0F, $08, $0F, $98, $19, $F8, $18, $F0, $18, $E0, $19, $F0, $0F, $98, $00, $00, $00, $00   ' &
        byte $00, $00, $00, $00, $07, $00, $07, $00, $07, $00, $0E, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00   ' '
        byte $00, $00, $00, $00, $00, $F0, $01, $C0, $03, $80, $07, $00, $0E, $00, $0E, $00, $0E, $00, $0E, $00, $07, $00, $03, $80, $01, $C0, $00, $F0, $00, $00, $00, $00   ' (
        byte $00, $00, $00, $00, $0F, $00, $03, $80, $01, $C0, $00, $E0, $00, $70, $00, $70, $00, $70, $00, $70, $00, $E0, $01, $C0, $03, $80, $0F, $00, $00, $00, $00, $00   ' )
        byte $00, $00, $00, $00, $01, $80, $11, $88, $09, $90, $07, $E0, $07, $E0, $3F, $FC, $3F, $FC, $07, $E0, $07, $E0, $09, $90, $11, $88, $01, $80, $00, $00, $00, $00   ' *
        byte $00, $00, $00, $00, $00, $00, $00, $00, $01, $80, $01, $80, $01, $80, $0F, $F0, $0F, $F0, $01, $80, $01, $80, $01, $80, $00, $00, $00, $00, $00, $00, $00, $00   ' +
        byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $07, $00, $07, $00, $07, $00, $0E, $00, $00, $00   ' ,
        byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $1F, $F8, $1F, $F8, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00   ' -
        byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $07, $00, $07, $00, $07, $00, $00, $00, $00, $00   ' ,
        byte $00, $00, $00, $00, $00, $02, $00, $06, $00, $0E, $00, $1C, $00, $38, $00, $70, $00, $E0, $01, $C0, $03, $80, $07, $00, $0E, $00, $1C, $00, $00, $00, $00, $00   ' /
        byte $00, $00, $00, $00, $0F, $F0, $1C, $38, $1C, $78, $1C, $F8, $1C, $F8, $1D, $B8, $1D, $B8, $1F, $38, $1F, $38, $1E, $38, $1C, $38, $0F, $F0, $00, $00, $00, $00   ' 0
        byte $00, $00, $00, $00, $01, $80, $01, $80, $03, $80, $1F, $80, $1F, $80, $03, $80, $03, $80, $03, $80, $03, $80, $03, $80, $03, $80, $1F, $F0, $00, $00, $00, $00   ' 1
        byte $00, $00, $00, $00, $0F, $E0, $1C, $70, $1C, $38, $00, $38, $00, $70, $00, $E0, $01, $C0, $03, $80, $07, $00, $0E, $38, $1C, $38, $1F, $F8, $00, $00, $00, $00   ' 2
        byte $00, $00, $00, $00, $0F, $E0, $1C, $70, $1C, $38, $00, $38, $00, $70, $03, $C0, $03, $C0, $00, $70, $00, $38, $1C, $38, $1C, $70, $0F, $E0, $00, $00, $00, $00   ' 3
        byte $00, $00, $00, $00, $00, $E0, $01, $E0, $03, $E0, $06, $E0, $0C, $E0, $18, $E0, $1F, $F8, $1F, $F8, $00, $E0, $00, $E0, $00, $E0, $03, $F8, $00, $00, $00, $00   ' 4
        byte $00, $00, $00, $00, $1F, $F8, $1C, $00, $1C, $00, $1C, $00, $1C, $00, $1F, $E0, $1F, $F0, $00, $78, $00, $38, $1C, $38, $1C, $70, $0F, $E0, $00, $00, $00, $00   ' 5
        byte $00, $00, $00, $00, $03, $E0, $07, $00, $0E, $00, $1C, $00, $1C, $00, $1F, $F0, $1F, $F8, $1C, $38, $1C, $38, $1C, $38, $1C, $38, $0F, $F0, $00, $00, $00, $00   ' 6
        byte $00, $00, $00, $00, $1F, $FC, $1C, $1C, $1C, $1C, $1C, $1C, $00, $1C, $00, $38, $00, $70, $00, $E0, $01, $C0, $03, $80, $03, $80, $03, $80, $00, $00, $00, $00   ' 7
        byte $00, $00, $00, $00, $0F, $F0, $1C, $38, $1C, $38, $1C, $38, $1F, $38, $07, $E0, $07, $E0, $1C, $F8, $1C, $38, $1C, $38, $1C, $38, $0F, $F0, $00, $00, $00, $00   ' 8
        byte $00, $00, $00, $00, $0F, $F0, $1C, $38, $1C, $38, $1C, $38, $1C, $38, $1F, $F8, $0F, $F8, $00, $38, $00, $38, $00, $70, $00, $E0, $07, $C0, $00, $00, $00, $00   ' 9
        byte $00, $00, $00, $00, $00, $00, $00, $00, $03, $80, $03, $80, $03, $80, $00, $00, $00, $00, $03, $80, $03, $80, $03, $80, $00, $00, $00, $00, $00, $00, $00, $00   ' :
        byte $00, $00, $00, $00, $00, $00, $00, $00, $03, $80, $03, $80, $03, $80, $00, $00, $00, $00, $03, $80, $03, $80, $03, $80, $07, $00, $00, $00, $00, $00, $00, $00   ' ;
        byte $00, $00, $00, $70, $00, $E0, $01, $C0, $03, $80, $07, $00, $0E, $00, $1C, $00, $1C, $00, $0E, $00, $07, $00, $03, $80, $01, $C0, $00, $E0, $00, $70, $00, $00   ' <
        byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $3F, $FC, $3F, $FC, $00, $00, $00, $00, $3F, $FC, $3F, $FC, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00   ' =
        byte $00, $00, $1C, $00, $0E, $00, $07, $00, $03, $80, $01, $C0, $00, $E0, $00, $70, $00, $70, $00, $E0, $01, $C0, $03, $80, $07, $00, $0E, $00, $1C, $00, $00, $00   ' >
        byte $00, $00, $03, $C0, $0F, $F0, $1E, $78, $18, $38, $00, $38, $00, $70, $00, $E0, $01, $C0, $01, $C0, $00, $00, $00, $00, $01, $C0, $01, $C0, $01, $C0, $00, $00   ' ?
        byte $00, $00, $0F, $F8, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $FC, $1C, $FC, $1C, $FC, $1C, $FC, $1C, $00, $1C, $00, $1C, $00, $1F, $F0, $07, $F8, $00, $00   ' @
        byte $00, $00, $00, $00, $03, $C0, $07, $E0, $0E, $70, $1C, $38, $1C, $38, $1C, $38, $1C, $38, $1F, $F8, $1C, $38, $1C, $38, $1C, $38, $1C, $38, $00, $00, $00, $00   ' A
        byte $00, $00, $00, $00, $1F, $F0, $0E, $38, $0E, $38, $0E, $38, $0E, $38, $0F, $F0, $0F, $F0, $0E, $38, $0E, $38, $0E, $38, $0E, $38, $1F, $F0, $00, $00, $00, $00   ' B
        byte $00, $00, $00, $00, $07, $F0, $0E, $38, $1C, $38, $1C, $00, $1C, $00, $1C, $00, $1C, $00, $1C, $00, $1C, $00, $1C, $38, $0E, $38, $07, $F0, $00, $00, $00, $00   ' C
        byte $00, $00, $00, $00, $1F, $E0, $0E, $70, $0E, $38, $0E, $38, $0E, $38, $0E, $38, $0E, $38, $0E, $38, $0E, $38, $0E, $38, $0E, $70, $1F, $E0, $00, $00, $00, $00   ' D
        byte $00, $00, $00, $00, $1F, $F8, $0E, $18, $0E, $08, $0E, $00, $0E, $30, $0F, $F0, $0F, $F0, $0E, $30, $0E, $00, $0E, $08, $0E, $18, $1F, $F8, $00, $00, $00, $00   ' E
        byte $00, $00, $00, $00, $1F, $F8, $0E, $18, $0E, $08, $0E, $00, $0E, $30, $0F, $F0, $0F, $F0, $0E, $30, $0E, $00, $0E, $00, $0E, $00, $1F, $00, $00, $00, $00, $00   ' F
        byte $00, $00, $00, $00, $07, $F0, $0E, $38, $1C, $38, $1C, $38, $1C, $00, $1C, $00, $1C, $00, $1C, $F8, $1C, $38, $1C, $38, $0E, $38, $07, $F8, $00, $00, $00, $00   ' G
        byte $00, $00, $00, $00, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1F, $F0, $1F, $F0, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $00, $00, $00, $00   ' H
        byte $00, $00, $00, $00, $0F, $E0, $03, $80, $03, $80, $03, $80, $03, $80, $03, $80, $03, $80, $03, $80, $03, $80, $03, $80, $03, $80, $0F, $E0, $00, $00, $00, $00   ' I
        byte $00, $00, $00, $00, $01, $FC, $00, $70, $00, $70, $00, $70, $00, $70, $00, $70, $00, $70, $38, $70, $38, $70, $38, $70, $38, $70, $0F, $E0, $00, $00, $00, $00   ' J
        byte $00, $00, $00, $00, $1E, $38, $0E, $38, $0E, $70, $0E, $E0, $0F, $C0, $0F, $80, $0F, $80, $0F, $C0, $0E, $E0, $0E, $70, $0E, $38, $1E, $38, $00, $00, $00, $00   ' K
        byte $00, $00, $00, $00, $1F, $00, $0E, $00, $0E, $00, $0E, $00, $0E, $00, $0E, $00, $0E, $00, $0E, $00, $0E, $08, $0E, $18, $0E, $38, $1F, $F8, $00, $00, $00, $00   ' L
        byte $00, $00, $00, $00, $1C, $1C, $1E, $3C, $1F, $7C, $1F, $FC, $1F, $FC, $1D, $DC, $1C, $9C, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $00, $00, $00, $00   ' M
        byte $00, $00, $00, $00, $1C, $1C, $1C, $1C, $1E, $1C, $1F, $1C, $1F, $9C, $1D, $DC, $1C, $FC, $1C, $7C, $1C, $3C, $1C, $1C, $1C, $1C, $1C, $1C, $00, $00, $00, $00   ' N
        byte $00, $00, $00, $00, $03, $E0, $07, $F0, $0E, $38, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $0E, $38, $07, $F0, $03, $E0, $00, $00, $00, $00   ' O
        byte $00, $00, $00, $00, $1F, $F0, $0E, $38, $0E, $38, $0E, $38, $0E, $38, $0F, $F0, $0F, $F0, $0E, $00, $0E, $00, $0E, $00, $0E, $00, $1F, $00, $00, $00, $00, $00   ' P
        byte $00, $00, $00, $00, $03, $E0, $0F, $78, $0E, $38, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $7C, $1C, $FC, $0F, $F8, $0F, $F8, $00, $38, $00, $FC, $00, $00   ' Q
        byte $00, $00, $00, $00, $1F, $F0, $0E, $38, $0E, $38, $0E, $38, $0E, $38, $0F, $F0, $0F, $F0, $0E, $70, $0E, $38, $0E, $38, $0E, $38, $1E, $38, $00, $00, $00, $00   ' R
        byte $00, $00, $00, $00, $0F, $F0, $1C, $38, $1C, $38, $1C, $38, $1C, $00, $0F, $E0, $07, $F0, $00, $38, $1C, $38, $1C, $38, $1C, $38, $0F, $F0, $00, $00, $00, $00   ' S
        byte $00, $00, $00, $00, $1F, $FC, $19, $CC, $11, $C4, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $07, $F0, $00, $00, $00, $00   ' T
        byte $00, $00, $00, $00, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $0F, $E0, $00, $00, $00, $00   ' U
        byte $00, $00, $00, $00, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $0E, $E0, $07, $C0, $03, $80, $00, $00, $00, $00   ' V
        byte $00, $00, $00, $00, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $9C, $1C, $9C, $1C, $9C, $0F, $F8, $0F, $F8, $07, $70, $07, $70, $00, $00, $00, $00   ' W
        byte $00, $00, $00, $00, $1C, $70, $1C, $70, $1C, $70, $0E, $E0, $07, $C0, $03, $80, $03, $80, $07, $C0, $0E, $E0, $1C, $70, $1C, $70, $1C, $70, $00, $00, $00, $00   ' X
        byte $00, $00, $00, $00, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $0E, $E0, $07, $C0, $03, $80, $03, $80, $03, $80, $03, $80, $0F, $E0, $00, $00, $00, $00   ' Y
        byte $00, $00, $00, $00, $1F, $F8, $1C, $38, $18, $38, $10, $70, $00, $E0, $01, $C0, $03, $80, $07, $00, $0E, $08, $1C, $18, $1C, $38, $1F, $F8, $00, $00, $00, $00   ' Z
        byte $00, $00, $00, $00, $07, $F0, $07, $00, $07, $00, $07, $00, $07, $00, $07, $00, $07, $00, $07, $00, $07, $00, $07, $00, $07, $00, $07, $F0, $00, $00, $00, $00   ' [
        byte $00, $00, $00, $00, $10, $00, $18, $00, $1C, $00, $0E, $00, $07, $00, $03, $80, $01, $C0, $00, $E0, $00, $70, $00, $38, $00, $1C, $00, $07, $00, $00, $00, $00   ' <Backslash>
        byte $00, $00, $00, $00, $07, $F0, $00, $70, $00, $70, $00, $70, $00, $70, $00, $70, $00, $70, $00, $70, $00, $70, $00, $70, $00, $70, $07, $F0, $00, $00, $00, $00   ' ]
        byte $00, $00, $01, $80, $03, $C0, $07, $E0, $0E, $70, $1C, $38, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00   ' ^
        byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $7F, $FF, $7F, $FF   ' _
        byte $00, $00, $00, $00, $1C, $00, $1C, $00, $07, $00, $07, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00   ' '
        byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $0F, $E0, $00, $70, $00, $70, $0F, $F0, $1C, $70, $1C, $70, $1C, $70, $0F, $D8, $00, $00, $00, $00   ' a
        byte $00, $00, $00, $00, $1E, $00, $0E, $00, $0E, $00, $0E, $00, $0F, $F0, $0E, $38, $0E, $38, $0E, $38, $0E, $38, $0E, $38, $0E, $38, $1B, $F0, $00, $00, $00, $00   ' b
        byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $0F, $E0, $1C, $70, $1C, $70, $1C, $00, $1C, $00, $1C, $70, $1C, $70, $0F, $E0, $00, $00, $00, $00   ' c
        byte $00, $00, $00, $00, $00, $F8, $00, $70, $00, $70, $00, $70, $0F, $F0, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $0F, $D8, $00, $00, $00, $00   ' d
        byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $0F, $E0, $1C, $70, $1C, $70, $1F, $F0, $1C, $00, $1C, $70, $1C, $70, $0F, $E0, $00, $00, $00, $00   ' e
        byte $00, $00, $00, $00, $03, $E0, $07, $70, $07, $70, $07, $00, $07, $00, $1F, $E0, $1F, $E0, $07, $00, $07, $00, $07, $00, $07, $00, $1F, $C0, $00, $00, $00, $00   ' f
        byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $0F, $D8, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $0F, $F0, $07, $F0, $00, $70, $1C, $70, $0F, $E0   ' g
        byte $00, $00, $00, $00, $1E, $00, $0E, $00, $0E, $00, $0E, $00, $0E, $F0, $0F, $38, $0F, $38, $0E, $38, $0E, $38, $0E, $38, $0E, $38, $1E, $38, $00, $00, $00, $00   ' h
        byte $00, $00, $00, $00, $01, $C0, $01, $C0, $01, $C0, $00, $00, $0F, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $0F, $F8, $00, $00, $00, $00   ' i
        byte $00, $00, $00, $00, $00, $70, $00, $70, $00, $70, $00, $00, $03, $F0, $00, $70, $00, $70, $00, $70, $00, $70, $00, $70, $00, $70, $1C, $70, $0C, $F0, $07, $E0   ' j
        byte $00, $00, $00, $00, $1E, $00, $0E, $00, $0E, $00, $0E, $00, $0E, $38, $0E, $70, $0E, $E0, $0F, $C0, $0E, $E0, $0E, $70, $0E, $38, $1E, $38, $00, $00, $00, $00   ' k
        byte $00, $00, $00, $00, $0F, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $0F, $F8, $00, $00, $00, $00   ' l
        byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $1F, $F8, $1C, $9C, $1C, $9C, $1C, $9C, $1C, $9C, $1C, $9C, $1C, $9C, $1C, $9C, $00, $00, $00, $00   ' m
        byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $1F, $E0, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $00, $00, $00, $00   ' n
        byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $0F, $E0, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $0F, $E0, $00, $00, $00, $00   ' o
        byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $1B, $F0, $0E, $38, $0E, $38, $0E, $38, $0E, $38, $0E, $38, $0F, $F0, $0E, $00, $0E, $00, $1F, $00   ' p
        byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $1F, $B0, $38, $E0, $38, $E0, $38, $E0, $38, $E0, $38, $E0, $1F, $E0, $00, $E0, $00, $E0, $01, $F0   ' q
        byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $1E, $F0, $0F, $F8, $0F, $38, $0E, $00, $0E, $00, $0E, $00, $0E, $00, $1F, $00, $00, $00, $00, $00   ' r
        byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $0F, $E0, $1C, $30, $1C, $30, $0F, $80, $03, $E0, $18, $70, $18, $70, $0F, $E0, $00, $00, $00, $00   ' s
        byte $00, $00, $00, $00, $00, $00, $01, $00, $03, $00, $07, $00, $1F, $F0, $07, $00, $07, $00, $07, $00, $07, $00, $07, $70, $07, $70, $03, $E0, $00, $00, $00, $00   ' t
        byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $0F, $D8, $00, $00, $00, $00   ' u
        byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $1C, $70, $0E, $E0, $07, $C0, $03, $80, $00, $00, $00, $00   ' v
        byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $1C, $1C, $1C, $1C, $1C, $1C, $1C, $9C, $1C, $9C, $0F, $F8, $07, $70, $07, $70, $00, $00, $00, $00   ' w
        byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $1C, $E0, $1C, $E0, $0F, $C0, $07, $80, $07, $80, $0F, $C0, $1C, $E0, $1C, $E0, $00, $00, $00, $00   ' x
        byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $0E, $38, $0E, $38, $0E, $38, $0E, $38, $0E, $38, $07, $F0, $03, $E0, $00, $E0, $01, $C0, $1F, $80   ' y
        byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $1F, $E0, $18, $E0, $11, $C0, $03, $80, $07, $00, $0E, $20, $1C, $60, $1F, $E0, $00, $00, $00, $00   ' z
        byte $00, $00, $00, $00, $01, $F8, $03, $80, $03, $80, $03, $80, $07, $00, $1C, $00, $1C, $00, $07, $00, $03, $80, $03, $80, $03, $80, $01, $F8, $00, $00, $00, $00   ' {
        byte $00, $00, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $01, $C0, $00, $00   ' |
        byte $00, $00, $00, $00, $1F, $80, $01, $C0, $01, $C0, $01, $C0, $00, $E0, $00, $38, $00, $38, $00, $E0, $01, $C0, $01, $C0, $01, $C0, $1F, $80, $00, $00, $00, $00   ' }
        byte $00, $00, $00, $00, $1F, $1C, $3B, $9C, $39, $DC, $38, $F8, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00   ' ~
SevenSegNumFont
        byte $20, $32, $30, $0A
        byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $FF, $FE, $00, $01, $FF, $FF, $00, $03, $FF, $FF, $80, $01, $FF, $FF, $60, $0C, $FF, $FE, $F0, $1E, $00, $01, $F8, $3F
        byte $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00
        byte $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3E, $00, $00, $78, $38, $00, $00, $18, $20, $00, $00, $08, $00, $00, $00
        byte $00, $20, $00, $00, $00, $38, $00, $00, $18, $3E, $00, $00, $78, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8
        byte $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F
        byte $00, $01, $F8, $1E, $00, $00, $F0, $0C, $FF, $FE, $60, $01, $FF, $FF, $00, $03, $FF, $FF, $80, $01, $FF, $FF, $00, $00, $FF, $FE, $00, $00, $00, $00, $00, $00, $00, $00, $00   ' 0
        byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $60, $00, $00, $00, $F0, $00, $00, $01, $F8, $00
        byte $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00
        byte $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $00, $78, $00, $00, $00, $18, $00, $00, $00, $08, $00, $00, $00
        byte $00, $00, $00, $00, $00, $00, $00, $00, $18, $00, $00, $00, $78, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8
        byte $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00
        byte $00, $01, $F8, $00, $00, $00, $F0, $00, $00, $00, $60, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00   ' 1
        byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $FF, $FE, $00, $01, $FF, $FF, $00, $03, $FF, $FF, $80, $01, $FF, $FF, $60, $00, $FF, $FE, $F0, $00, $00, $01, $F8, $00
        byte $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $00, $78, $01, $FF, $FE, $18, $03, $FF, $FF, $88, $0F, $FF, $FF
        byte $E0, $27, $FF, $FF, $C0, $39, $FF, $FF, $00, $3E, $00, $00, $00, $3F, $00, $00, $00, $3F, $00, $00, $00, $3F, $00, $00, $00, $3F, $00, $00, $00, $3F, $00, $00, $00
        byte $3F, $00, $00, $00, $3F, $00, $00, $00, $3F, $00, $00, $00, $3F, $00, $00, $00, $3F, $00, $00, $00, $3F, $00, $00, $00, $3F, $00, $00, $00, $3F, $00, $00, $00, $3F
        byte $00, $00, $00, $1E, $00, $00, $00, $0C, $FF, $FE, $00, $01, $FF, $FF, $00, $03, $FF, $FF, $80, $01, $FF, $FF, $00, $00, $FF, $FE, $00, $00, $00, $00, $00, $00, $00, $00, $00   ' 2
        byte $E0, $07, $FF, $FF, $C0, $01, $FF, $FF, $18, $00, $00, $00, $78, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8, $00, $00, $01, $F8
        byte $00, $01, $F8, $00, $00, $00, $F0, $00, $FF, $FE, $60, $01, $FF, $FF, $00, $03, $FF, $FF, $80, $01, $FF, $FF, $00, $00, $FF, $FE, $00, $00, $00, $00, $00, $00, $00, $00, $00   ' 3
        byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $60, $0C, $00, $00, $F0, $1E, $00, $01, $F8, $3F
        byte $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3E, $00, $00, $78, $39, $FF, $FE, $18, $23, $FF, $FF, $88, $0F, $FF, $FF
        byte $00, $01, $F8, $00, $00, $00, $F0, $00, $00, $00, $60, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00   ' 4
        byte $00, $00, $00, $00, $00, $00, $00, $00, $00, $FF, $FE, $00, $01, $FF, $FF, $00, $03, $FF, $FF, $80, $01, $FF, $FF, $00, $0C, $FF, $FE, $00, $1E, $00, $00, $00, $3F
        byte $00, $00, $00, $3F, $00, $00, $00, $3F, $00, $00, $00, $3F, $00, $00, $00, $3F, $00, $00, $00, $3F, $00, $00, $00, $3F, $00, $00, $00, $3F, $00, $00, $00, $3F, $00
        byte $00, $00, $3F, $00, $00, $00, $3F, $00, $00, $00, $3F, $00, $00, $00, $3F, $00, $00, $00, $3E, $00, $00, $00, $39, $FF, $FE, $00, $23, $FF, $FF, $80, $0F, $FF, $FF
        byte $00, $01, $F8, $00, $00, $00, $F0, $00, $FF, $FE, $60, $01, $FF, $FF, $00, $03, $FF, $FF, $80, $01, $FF, $FF, $00, $00, $FF, $FE, $00, $00, $00, $00, $00, $00, $00, $00, $00   ' 5
        byte $E0, $27, $FF, $FF, $C0, $39, $FF, $FF, $18, $3E, $00, $00, $78, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8, $3F, $00, $01, $F8
        byte $00, $01, $F8, $1E, $00, $00, $F0, $0C, $FF, $FE, $60, $01, $FF, $FF, $00, $03, $FF, $FF, $80, $01, $FF, $FF, $00, $00, $FF, $FE, $00, $00, $00, $00, $00, $00, $00, $00, $00   ' 6
        byte $00, $01, $F8, $00, $00, $00, $F0, $00, $00, $00, $60, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00   ' 7
        byte $00, $01, $F8, $1E, $00, $00, $F0, $0C, $FF, $FE, $60, $01, $FF, $FF, $00, $03, $FF, $FF, $80, $01, $FF, $FF, $00, $00, $FF, $FE, $00, $00, $00, $00, $00, $00, $00, $00, $00   ' 8
        byte $00, $01, $F8, $00, $00, $00, $F0, $00, $FF, $FE, $60, $01, $FF, $FF, $00, $03, $FF, $FF, $80, $01, $FF, $FF, $00, $00, $FF, $FE, $00, $00, $00, $00, $00, $00, $00, $00, $00   ' 9
Utilities:
    Abstract: Utilities
CON
  FRQSAMPLES = 64 'Samples in periods for freqin
  MINFREQ = 250 'Minimum frequency before considering frequency 0(must be greater than 1),
                'the larger it is the longer the wait time if the frequency is lower than MINFREQ
                'MINFREQ must be larger than FRQSAMPLES!!
VAR
 long clkspus
 'Frequency Variables
 long tstflag
 long frqpin
 long bf[2]
 byte cog
 byte cogon
OBJ
PUB DelayS(intSeconds)
  waitcnt(cnt + (clkfreq*intSeconds))
PUB DelayMS( time )
  waitcnt (cnt + (time*(clkfreq/1000)))
PUB DelayUS( time )  'Assumes 80MHz for accuracy's sake(5 is the minimum!!!)
  if time < 5
    return
  waitcnt (time * 80 + cnt)
PUB IndexOf(begin,chrChar, pstrString) : intLocation | intIndex
 Purpose: Returns the first index of chrChar in the string pstrString, returns -1 if it does not exist
  intLocation := -1
  repeat intIndex from begin to strsize(pstrString)
    if byte[pstrString][intIndex] == chrChar
      intLocation := intIndex
      quit
PUB GetSubWordIndex(pstrString, pstrSubString,chrDelimiter) : del | index,subind, intlength, intsublength, sub1, sub2, match
 Purpose: F
  intsublength := strsize(pstrSubString)
  intlength :=  strsize(pstrString)
  sub1 := 0
  match := false
  del := 0
  repeat index from 0 to intlength - 1
    if byte[pstrString][index] == chrDelimiter
      sub2 := index
      if (sub2 - sub1) == intsublength 'If length is correct
        match := true
        'Compare String
        repeat subind from sub1 to sub2 - 1
          if byte[pstrString][subind] <> byte[pstrSubString][subind - sub1]
            match := false
            quit
      ifnot match
          sub1 := sub2 + 1
          del++
      else
        quit
  ifnot match
    del := -1
PUB GetSubWord(intIndex ,pstrSubString, pstrString, delimiter) | intSpaceIndex, intLoopIndex, intSubIndex, intLength
 Purpose: Get Word seperated by delimiter at index intIndex
  'Note:  Assumes single space between words.
  intSpaceIndex := 1
  intSubIndex := 0
  intLength := strsize(pstrString)
  repeat intLoopIndex from 0 to intLength
    'Space?
    if byte[pstrString + intLoopIndex] <> delimiter
    ''No
      if intSpaceIndex == intIndex
        byte[pstrSubString + intSubIndex] := byte[pstrString + intLoopIndex]
        intSubIndex++
    else
      'Yes, is a space
      intSpaceIndex++
PUB ClearString(pstrString) | intLength, intLoopIndex
  repeat intLoopIndex FROM 0 TO intLength
    byte[pstrString][intLoopIndex] := 0
PUB TotalTrimString(pstrString) | intLength, intLoopIndex, intSubIndex, Flag
  'Trim start and end and make all spaces one space if multiple spaces
  Flag := 0
  'Trim start
    'if not a space
    if byte[pstrString + intLoopIndex] <> 32
      'if not the first charachter
      if intLoopIndex > 0
        'Trim Spaces
        StringRemove(pstrString,0,intLoopIndex)
        'Renew length
      quit
  'Trim end
  repeat intLoopIndex from intLength - 1 to 0
    'If not a space
      'if not the last charachter.
      if intLoopIndex < (intLength - 1)
        'Trim Spaces
        StringRemove(pstrString, intLoopIndex + 1,intLength - intLoopIndex - 1)
        'renew length
      quit
  intLoopIndex := 0
  if intLength <> 0
    'Trim Duplicate Spaces
    repeat
      if byte[pstrString + intLoopIndex] == 32
        if Flag == 1
          'Duplicate space, set flag
          intSubIndex := intLoopIndex
          Flag := 2
        elseif Flag <> 2
          Flag := 1
      elseif Flag == 2
        StringRemove(pstrString,intSubIndex,intLoopIndex-intSubIndex)
        intLoopIndex := intSubIndex
        Flag := 0
      else
        Flag := 0
      if intLoopIndex == (intLength - 1)
        quit
      intLoopIndex++
PUB CompareString(pstrone, pstrtwo,length) : eq | index
  eq := true
    if byte[pstrone][index] <> byte[pstrtwo][index]
      eq := false
      quit
PUB StringRemove(pstrString, intBeginIndex, intRemoveLength) | intLength, intLoopIndex, intSubIndex
  'Removelength more than length?
  if ((intRemoveLength + intBeginIndex) =< intLength)
    'No
    repeat intLoopIndex from 0 to intLength - intRemoveLength - 1
      if intLoopIndex > intBeginIndex - 1
        byte[pstrString + intLoopIndex] := byte[pstrString + intLoopIndex + intRemoveLength]
      else
        next
    'Clear rest of string
    repeat intLoopIndex from intSubIndex to intLength
      byte[pstrString + intLoopIndex] := 0
  elseif intRemoveLength > intBeginIndex
PUB StringAppend(pstrString,pstrAppend) | intIndex, intLength, intALength
  intALength := strsize(pstrAppend)
  intIndex := intLength
  repeat intALength
    byte [pstrString][intIndex++] := byte[pstrAppend][intIndex-intLength]
PUB ClearBArray(bptr, count) | i
  repeat i from 0 to count - 1
    byte[bptr][i] := 0
PUB ClearWArray(bptr, count) | i
    word[bptr][i] := 0
PUB ClearLArray(bptr, count) | i
    long[bptr][i] := 0
PUB toHex(value) | val
  if val < 256
    val := value / 16
    val <<= 4
    val |= value // 16
    return val
  else
    return 0
PUB toDec(value) | val, tmp
  'Get first hex digit
  tmp := value
  val := tmp >> 4
  'get second hex digit
  tmp -= val * 16
  val *= 16
  val += tmp
  return val
PUB ValidAsciiInteger(intIn) : Valid
  Valid := false
  'Valid ascii number?
  if intIn < 58 and intIn > 47
    'Yes
    Valid := true
PUB ValidAsciiPrint(In) : Valid
  Valid := false
  'Valid ascii?
  if In => 32 and In =< 126                          'Valid ascii printablevalue
    'Yes
    Valid := true
PUB GetPulse(state, pin)  : time
 returns pulse length in us
  waitpeq(state << pin, |< pin, 0)
  time := cnt
  waitpne(state << pin, |< pin, 0)
  time := cnt - time
  time := time / (clkfreq/1_000_000)
PUB RCTime(state, pin) : time
 Returns time pin is in state in microseconds
 ;Returns 0 if pin is not in state
  if INA[pin] == state
    time := cnt
    time := cnt - time                                  'Get count
    time := time / (clkfreq / 1_000_000)                'Get time in microseconds
  else
    time := 0
PUB FreqInStart
 Start a cog for frequency in testing
  tstflag := 0 'Start cog in waiting state
  cogon := (cog := cognew(@start, @tstflag)) > 0
PUB FreqIn(tstpin) | value, sum , counter, waittime
 Get input frequency on pin
  repeat
    if tstflag == 0
      'Set pin to input
      DIRA[tstpin]~
      counter := 0
      waittime := 1000/(MINFREQ / FRQSAMPLES)  'Get Milliseconds to wait
      frqpin := |< tstpin            'Set pin mask for asm use
      tstflag := 1                   'Tell cog to test
      repeat until tstflag == 0 or counter == waittime
        counter++
        DelayMS(1)
      if counter == waittime    'If timed out, return 0 as frequency
        return 0
      'Test if system clock was reset(would cause invalid frequency reading), and read again if so
      if bf[0] > bf[1]
        next
      sum := bf[1] - bf[0]      'Get clocks for all samples
      'Get average
      value := sum / FRQSAMPLES
      'Get freq from average clocks
      value := clkfreq / value
      quit
    else
      next
  return value
PUB FreqInStop
  Stop the frequency in cog
  if cogon~                     'If cog is on, post clear cogon to zero
    cogstop(cog)                'Stop Cog
PUB FreqOut(pin, freq, time) | count, t
 Output freq out of pin for time(Sec), amount of time
  'Get clocks from freq
  t := clkfreq / freq
  'Get count of times
  count := freq * time
  'Set pin to output
  DIRA[pin]~~
  repeat count
    !OUTA[pin]
    waitcnt(cnt + t)
DAT
        org 0
start
              mov ptr, par      'Get Pointer
              mov r1, #0
              wrlong r1, ptr    'Clear flag
:waitloop     rdlong r1, ptr    'Read flag, and test if still 0
              tjz r1, #:waitloop
              mov bfr, ptr
              add bfr, #4       'Get pointer to pin
              rdlong frpin, bfr
              add bfr, #4       'Get buffer pointer
              mov ctr, #FRQSAMPLES
              mov r1, cnt
              wrlong r1, bfr
:frqloop      waitpne zero,frpin
              waitpeq zero, frpin
                     'Get counter
                  'Write counter to buffer
                     'Goto next location
              djnz ctr, #:frqloop
              add bfr, #4
              mov r1, cnt
              wrlong r1, bfr
              jmp #start
frpin LONG 0
zero LONG 0
r1 res 1
ctr res 1
bfr res 1
ptr res 1
        fit 496
SPILCD:
[code]{{
SPI Management Functions
Abstract:
This class is built to be a universal SPI Driver with C3 Channel select capability.
CON
'Clocking settings
VAR
long data[8]
ASM DATA:
data[0] := Data pin
data[1] := Clock pin
data[2] := Data location/data
data[3] := data type to write (no command(idle)=0, char=1, 8bit=2, 16bitrewrite=3, SetFont = 4)
data[4] := color/writes to perform for 16 bit mode
data[5] := bcolor
data[6] := x
data[7] := y
byte cogon
byte cog
OBJ
PUB InitSPI(spidata, spiclock) : okay
'Set Asm data
data[0] := spidata 'Data pin
data[1] := spiclock'Clock pin
data[3] := 0 'Data not present
okay := cogon := (cog := cognew(@entry,@data)) > 0
PUB WriteSPISlow(strOutBuffer) | NumBytes
NumBytes := 8
' now read the bits out
repeat 8
' drop clock
OUTA[data[1]] := 0
' place next bit on OUT (shift to right starting at MSB - 1(to get the first(msb) bit then next, and so on) then bitwise AND with 01 to get only last bit)
OUTA[data[0]] := ((strOutBuffer >> (NumBytes-- - 1)) & $01)
' raise clock
OUTA[data[1]] := 1
PUB WriteSPICLR(writes, wrdOut)
Purpose: Write 16 bits to SPI, but repeat sending 16 bit data for writes times
repeat until data[3] == 0 'Wait until cog ready
data[2] := wrdOut 'Write word to write
data[4] := writes 'Write "writes" times
data[3] := 3 'Set data type to 16 bit
PUB WriteSPICHR(x,y,char,color,bcolor)
Purpose: Write charachter to screen
data[2] := char
data[4] := color
data[5] := bcolor
data[6] := x
data[7] := y
data[3] := 1 'Set function to char
PUB SetFont(fontloc)
Purpose: Set font for ASM char writing
data[2] := fontloc
data[3] := 4 'Set function to set font
PUB WriteSPI(bytOut)
Purpose: Write 8 bits to SPI
data[2] := bytOut
data[3] := 2 'Set datatype to 8 bit
PUB stop
if cogon~
cogstop(cog)
DAT
org 0
entry
mov dt, par 'Get data location
rdlong spid, dt 'Get SPI data pin
add dt, #4 'Jump to next long
rdlong spic, dt 'Get SPI clk pin
mov spidmask, #1 'Get Pin Masks
mov spicmask, #1
shl spidmask, spid
shl spicmask, spic
or dira, spidmask 'Set pins to output
or dira, spicmask
add dt, #4 'Goto Data location
mov dtyploc, dt 'Get Data type location
add dtyploc, #4
mov cloc, dtyploc
add cloc, #4
mov bcloc, cloc
add bcloc, #4
mov xloc, bcloc
add xloc, #4
mov yloc, xloc
add yloc, #4
'Set Counter registers
mov ctra, spid 'Set counter A data pin
mov ctrb, spic 'Set clock pin for ctr b
movi ctra,#%0_00100_000
movi ctrb,#%0_00100_000
:loop
rdlong r1, dtyploc 'Get datatype
tjz r1, #:loop
movi phsb,#%000000000 'Set phase reg b
rdlong wrdt, dt 'Get data from location
cmp r1, #1 wz 'Test if char
if_z jmp #:writechar
cmp r1, #2 wz 'Test if 8 bit command
if_z jmp #:writeeight
cmp r1, #3 wz 'Test if 16 bit command
if_z jmp #:writesixtn
jmp #:setfont 'Otherwise, set font command
:writeeight
shl wrdt, #24
mov phsa, wrdt 'Write data into register
movi frqb,#%010000000 'Start counting!
:wreghtloop
shl phsa, #1 'Get next bit
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
mov frqb, #0 'Stop counting
wrlong null, dtyploc 'Clear Datatype
jmp #:loop
:writesixtn
rdlong r2, cloc 'Get times to write data
shl wrdt, #16
:wrsxtnloop
mov phsa, wrdt
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
shl phsa, #1
djnz r2,#:wrsxtnloop 'If more writes start writing again
jmp #:loop
:writechar
rdlong wrdt,dt 'Get Char
rdlong cx, xloc 'Get x
rdlong cy, yloc 'Get y
'Calculate char address
mov r1, wrdt
sub r1, foffset
mov r2, fxsize
shr r2, #3 'Divide by 8
1024 x 768 - 48K
1024 x 768 - 64K
  • RaymanRayman Posts: 16,448
    edited 2014-11-13 16:06
    I seem to recall that bump format pads each line if horizontal is not multiple of four
  • handermanntrhandermanntr Posts: 18
    edited 2014-11-13 16:28
    Wow, 5 stars!!
    Do all LCD's use this form of mapping? How did you know this one did? Also, does that mean that anytime I set the xy coordinates that the x coordinates must be a factor of 4, or only with images? Does it do this with verticle as well?
    I have no Idea how you knew that of the top of your head.........:thumb:
  • MahonroyMahonroy Posts: 175
    edited 2014-11-13 18:42
    The 1.5" uOLED display by 4D systems is exactly the same way... the image height does not matter, but the width has to be a multiple of 4 or the image gets jumbled up.
    edited 2014-11-13 19:22
    Ok, while I'm working on this, does anyone know what causes a black line to appear on the right side of any rectangles, or anything of that kind. Code is the same as above. This is using the FillRect method. Also, it appears on any width and height. Thanks!
    1024 x 768 - 81K
  • JRetSapDoogJRetSapDoog Posts: 954
    edited 2014-11-13 22:49
    [D]oes anyone know what causes a black line to appear on the right side of any rectangles...
    If it's not generated from code, perhaps it's some kind of "bleeding" of the pixels at the pixel boundary between different colors. Wonder if the black bar would happen at the bottom of the rectangle (based on the orientation in the photo) if you inverted the colors of the rectangle and background. Well, an inversion might not exhibit the line as the line might be from the specific order of the RGB sub-pixels. Looking closely, you can see how the red pixels are slightly shifted from the green. My apologies if this is caused by code (haven't looked at that). BTW, I guess that's a portrait style screen rather than a landscape one, even though the pic shows the screen in a horizontal (landscape) orientation.
    edited 2014-11-14 07:41
    I just figured it out actually, you are sort of right. If you zoom in on the picture you can tell that it is caused by the strong contrast in colors(Red, Green(2 of the three actual LED pixel colors)) and the large pixel size, this makes the space between the LED's appear black. I also confirmed this because the same code works perfectly without a line on my larger resolution screen(with smaller pixels). Thanks for your input!
    BTW: It's just the bmp format that favors an even number of four pixels. I think there's also a 32-bit alignment issue, but that isn't a problem with four 24-bit pixels.
    You can easily display bmps that are not multiple of four, you just need extra code to handle that case. It hasn't nothing to do with the LCD.
