Serial issue receiving binay data - lots of 0xFF bytes
I'm using using the code below to receive binary serial data from a device sending at 19,200, 8bit, 1 stop, 1 start bit.The device has a pullup to 3.6v and I'm using a 220ohm resistor between it and the Prop.
It's working and the data I'm receiving is valid. Each frame starts with 0x72 and they are 10 bytes long. When I receive the data using fdserial_rxCheck it appears it's even capturing a spurious 0xFF within the frame. This is my first time using the the Prop to receive serial data and I just wanted to confirm I should be receiving 0xFF bytes while the line is pulled up and eight bits ticks by w/o a stop or start bit? Maybe I'm supposed to, just not sure as I've never done this before. It appears the spurious 0xFF bytes are eliminated when using fdserial_rxTime. I was hoping I could use the time between the frames when no bytes are waiting to determine when a frame started/stopped as well as parsing and processing the data in the frame.
Any help would be appreciated.
This is using c = fdserial_rxTime(xbee, 1);
This is using c = fdserial_rxCheck(xbee); Getting some random 0xFF within the valid frame.
Here's what the Saleae output looks like between the frames beginning with 0x72.
#include "simpletools.h" #include "fdserial.h" fdserial *xbee; fdserial *term; int main() { xbee = fdserial_open(9, 8, 0, 19200); term = fdserial_open(31, 30, 0, 115200); simpleterm_close(); char c; fdserial_rxFlush(xbee); while (fdserial_rxReady) { c = fdserial_rxCheck(xbee); //c = fdserial_rxTime(xbee, 1); if (c != -1) { dprint(term, "%x ", c); } } }
http://learn.parallax.com/propeller-c-simple-protocols/full-duplex-serial
In the next example further down on the page c is defined as int.
All I needed to do to resolve this is change c from char to int in my example above. Not sure I completely understand why char does not work since it's defined as a one byte.
so you need int not char. to distinguish $FF from -1 (no char available)
Enjoy!
That explains it! Thanks!
