simpleIDE and PropellerIDE — Parallax Forums
prof_brainoprof_braino Posts: 4,313
edited 2014-11-03 10:36 in Propeller 1
Last time I tried something other than the windows PropTool, I was unsuccessful.
This time, I was able to install, run, and burn an image to a quickstart, using both PropleereIDE and simpleIDE, on Linux 64 bit (Mint 17 but that shouldn't make a difference, its same as ubuntu without Unity).
The biggest issue was finding the correct instructions, in the correct order. Its not all than hard, but after my last experience, I was very cautious.
I did get lots (more than zero) of nasty warnings and errors, is this still expected at this stage?
Anyway, I made some "even Braino can do it" instructions at:
http://code.google.com/p/propforth/wiki/simpleIDE
and
http://code.google.com/p/propforth/wiki/PropellerIDE
I hope to use these with kids and parents, if anyone could suggest clarifications I would appreciate it. Feels free to copy and or improve these if you can.
    edited 2014-11-02 16:29
    Braino,
    In your instructions you have: "Powercycle so the changes take."
    Rebooting so as to get an application working is never necessary on a Linux machine.
    Heck, Debian and other distro's package managers can update just about everything on your system with out a reboot.
    Reboot is normally only required to get a new kernel into use.
    You may have to logout of your current session, shell or X Windows, and log back in again when adding yourself to a new group before that gets recognized. Not sure if even that is required.
    edited 2014-11-02 17:30
    Prof,
    Noticed these typos (and a few lines where lowercase follows full stop)...
    START simple IDE first time form a command line
    From the following ling, select the download for your system:
    navigate to your downloads directory (shown is FIRFOX's default)
    configure default locattion for your SPIN files
    ALSO - I had to shutdown and restart the virtual machine for this GROUP setting o update. SO:
    If I knew what I was doing, I could enter a command to update the groups setting. But I don't, and power ccyling is quicker than googling 4000
    you should the PROP0 Cog6 OK propforth propmpt
    edited 2014-11-03 09:33
    Heater. wrote: »
    Braino,
    Thanks for the comments!
    My observation was it did not work until after reboot. This is another virgin install on a virtualbox , and I have noticed that dialout group often give a problem. Maybe I tricked myself. Whatever the issue, reboot always works, and only takes a minute.
    Sure a reboot can get what you want. Perhaps running a single app in a VM this is a quick way to go.
    It just feels wrong. I hate to have to shut down my browsers, IDEs, editors, whatever else I am doing, just to change a simple setting.
    A reboot is an inconvenience but also if some application really needs it then there is something very wrong with the application that would worry me.
