Ok before I freak out what happened to the Propeller Project Board USB.. I hope we are getting them soon. I need one ASAP so if anyone has one they can sell me let me know.
Thanks for the reply ..but I really need one now. What do I need to add to the quick start board to power it from an external power supply. It's powered from the usb but I can't run it like that on my project. Do I need to put a 5 volt regulator and send the power to the VDD and Ground. I have access to all the pins on that board so I can use it if I can power it from and external source.. Thanks
Thanks for the reply ..but I really need one now. What do I need to add to the quick start board to power it from an external power supply. It's powered from the usb but I can't run it like that on my project. Do I need to put a 5 volt regulator and send the power to the VDD and Ground. I have access to all the pins on that board so I can use it if I can power it from and external source.. Thanks[/QUOTE
My local MICROCENTER has two in stock. I was going to grqb q couple tomorrow or so.
They do have that nice 3 Amp 3.3v Hi-eff dpwitch supply on them.
I just dispatched a system-wide tracer on this to return to this thread with some real information. Somewhere, somehow, this board is stuck and I don't know why.
I concur, this is taking way too long! Fail at Parallax! I'd be happy to have you spend your money at Parallax so I'll fix this right away.
We approved the first article on October 17th and full production is scheduled to be done on November 20th.
Somewhere, deep in a thread elsewhere, I promised that these boards would be in stock (in volume) by the end of December. We should be slightly ahead of that schedule.
And the Propeller Proto Board has been put back into production, too. I think we'll see it around the same time but I'll get specifics later.
Great news - I use the Prop Project boards USB a lot as a base for my products. Can't wait for the new Prop boards to become available. Are they going to have the same form factor, same pin layout, any new features ???
Hi Ken, Would it be possible for you to put a tracer on the Spinnernet 2.0 Web Server? I've asked in two separate threads, but haven't received a response yet.
http://forums.parallax.com/showthread.php/157340-Propeller-Project-Board-USB
http://www.microcenter.com/product/409089/Propeller_Project_Board_USB
Rick[/QUOTE]
Wow... thanks I just ordered one. I appreciate it..
In the mean time, if anyone needs a Project Board immediately, I have one extra.
MSg me the info and how much you want for it. I will take it too.
Message sent.
