Propeller Project Board USB — Parallax Forums
mnemonicsmnemonics Posts: 23
edited 2014-10-29 13:13 in Propeller 1
Ok before I freak out what happened to the Propeller Project Board USB.. I hope we are getting them soon. I need one ASAP so if anyone has one they can sell me let me know.
    edited 2014-10-16 03:01
  • mnemonicsmnemonics Posts: 23
    edited 2014-10-21 15:01
    Thanks for the reply ..but I really need one now. What do I need to add to the quick start board to power it from an external power supply. It's powered from the usb but I can't run it like that on my project. Do I need to put a 5 volt regulator and send the power to the VDD and Ground. I have access to all the pins on that board so I can use it if I can power it from and external source.. Thanks
  • RickInTexasRickInTexas Posts: 124
    edited 2014-10-21 23:28
    mnemonics wrote: »
    Thanks for the reply ..but I really need one now. What do I need to add to the quick start board to power it from an external power supply. It's powered from the usb but I can't run it like that on my project. Do I need to put a 5 volt regulator and send the power to the VDD and Ground. I have access to all the pins on that board so I can use it if I can power it from and external source.. Thanks[/QUOTE
    My local MICROCENTER has two in stock. I was going to grqb q couple tomorrow or so.
    They do have that nice 3 Amp 3.3v Hi-eff dpwitch supply on them.
    http://www.microcenter.com/product/409089/Propeller_Project_Board_USB
    Rick
    edited 2014-10-27 17:33
    Rick[/QUOTE]
    Wow... thanks I just ordered one. I appreciate it..
  • Ken GraceyKen Gracey Posts: 7,400
    edited 2014-10-27 19:04
    I just dispatched a system-wide tracer on this to return to this thread with some real information. Somewhere, somehow, this board is stuck and I don't know why.
    I concur, this is taking way too long! Fail at Parallax! I'd be happy to have you spend your money at Parallax so I'll fix this right away.
    edited 2014-10-28 10:08
    We approved the first article on October 17th and full production is scheduled to be done on November 20th.
    Somewhere, deep in a thread elsewhere, I promised that these boards would be in stock (in volume) by the end of December. We should be slightly ahead of that schedule.
    And the Propeller Proto Board has been put back into production, too. I think we'll see it around the same time but I'll get specifics later.
    edited 2014-10-28 10:11
    Good to hear Ken!
    In the mean time, if anyone needs a Project Board immediately, I have one extra.
    edited 2014-10-28 17:03
    Publison wrote: »
    Good to hear Ken!
    MSg me the info and how much you want for it. I will take it too.
  • Hal AlbachHal Albach Posts: 747
    edited 2014-10-28 17:42
    I have two Rev B's I can throw into the mix.
    edited 2014-10-29 04:42
    I msg you Hal Thanks
    edited 2014-10-29 05:28
    I sent a reply msg, first time for me. If you can't see it let me know.
  • PropGuy2PropGuy2 Posts: 360
    edited 2014-10-29 05:49
    Great news - I use the Prop Project boards USB a lot as a base for my products. Can't wait for the new Prop boards to become available. Are they going to have the same form factor, same pin layout, any new features ???
    edited 2014-10-29 06:06
    mnemonics wrote: »
    Message sent.
  • Little-endianLittle-endian Posts: 91
    Ken Gracey wrote: »
    Hi Ken, Would it be possible for you to put a tracer on the Spinnernet 2.0 Web Server? I've asked in two separate threads, but haven't received a response yet.
