Compiling & LInking the Booter / Interpreter — Parallax Forums
65816581 Posts: 132
edited 2014-10-13 18:55 in Propeller 1
I am currently working on some scripts which will hopefully compile, link and generate
unscrambled hex files for using in P1V projects. In case I have missed it - are there any
binary versions of these available, so I can compare my results?
    edited 2014-10-13 03:10
    I have already created all the hex files including the spin programs that created them. Just search this forum back near the beginning.
  • 65816581 Posts: 132
    edited 2014-10-13 04:29
    Cluso99 wrote: »
    So you can re-compile the booter and add custom functions? I have trouble finding your code.
  • SeairthSeairth Posts: 2,474
    edited 2014-10-13 05:08
    6581 wrote: »
    As it happens, I have been working on a stand-alone assembler, written in Python. I have been testing it with the ROM source files, so I definitely know that it will work with those. The assembler's not quite complete, but I'll try to release it in the next day or so.
    edited 2014-10-13 05:29
    I've been using the Propeller tool to generate .binary files of my modified interpreter and booter.
    I have a program that links them together with the runner and sin/log tables and generates a unscrambled hex file.
    Is this what you guys are after?
    edited 2014-10-13 05:31
    ozpropdev wrote: »
    Exactly. I am planning to make a custom bootloader.
    edited 2014-10-13 05:51
    Here is a unscrambled hex file. I will post my linker tomorrow when I'm back at my development machine. :)
    Here's my hex file generator program.
    You can unscramble ,load binary files, modify Prop version number and insert some text info into the ROM.
    Just enough functions to allow modifying the interpreter and booter code.
    Hope this helps :)
    Cheers
    Brian
