What is your go to RGB LED driver? — Parallax Forums
T ChapT Chap Posts: 4,249
edited 2014-10-12 18:00 in Propeller 1
I am looking at a common anode LED built into a pushbutton. I want to put from any combination of 4 buttons up to 32 on a module. What are you guys using for controlling this type of LED from the Prop?
http://www.digikey.com/product-detail/en/KP0115ANBKG03RGB-2SJB/360-2465-ND/2355693
  • tomcrawfordtomcrawford Posts: 1,129
    edited 2014-10-10 14:51
    1. I would think you would want to multiplex the LEDs; if so you need honkin' pull-up transistors. I have used Mitsu M54564 eight-to-a-package successfully. You can drive them directly from Prop output pins. If you decide not to mux, you could just tie the anodes directly to Vcc.
    2. You need to decide whether you want just eight colors or lots of colors. If just eight colors you could use shift registers for pull-downs with fixed resistor to limit current. If you want lots of colors you can use constant current like TI TLC5916 for pull-downs.
    0. That's a mighty fancy switch you found there.
  • Mag748Mag748 Posts: 269
    edited 2014-10-10 15:47
    T Chap wrote: »
    Hey there,
    That is a decent switch. I've used a few of these and a bunch of the R/G only versions. They're just so dang expensive. I use the TLC5947DAP for driving the LEDs and the CD74HC165M96 to read the switches. I have some code snippets I can lend you if you decide to go that route.
    Marcus
  • T ChapT Chap Posts: 4,249
    edited 2014-10-10 15:58
    Thanks for the links. I will use my fav PCF8575 16 bit i2c to read. I want 8 bits per color ideally. I wish there were a cheaper RGB button for less but I turned up nothing. If there is a cheaper one I'd love to see it. I need at least 20 per row, maybe 2 rows used in some cases.
  • MJBMJB Posts: 1,235
    edited 2014-10-12 09:51
    what about a WS2812 or similar RGB-LED drivers?
    found this on Sparkfun - what a great key but seems retired
    https://www.sparkfun.com/products/retired/8493
    of course you can just multiplex with a either I2C extender or SPI type 595 shift register.
    32 * 3 colors could be made into a matrix 16 * 6 using either 3 * xx595 shift register or 16 + 8 I2C extender.
    number of colors the depends on your PWM.
    or use this for the 16 * sink:
    http://www.maximintegrated.com/en/products/all-products/archive/MAX16809.html
    I am liking this IC for 12 bit per color. TLC5940. Anyone used this?
    http://www.ti.com/lit/ds/symlink/tlc5940.pdf
