What is your go to RGB LED driver?
I am looking at a common anode LED built into a pushbutton. I want to put from any combination of 4 buttons up to 32 on a module. What are you guys using for controlling this type of LED from the Prop?
http://www.digikey.com/product-detail/en/KP0115ANBKG03RGB-2SJB/360-2465-ND/2355693
2. You need to decide whether you want just eight colors or lots of colors. If just eight colors you could use shift registers for pull-downs with fixed resistor to limit current. If you want lots of colors you can use constant current like TI TLC5916 for pull-downs.
0. That's a mighty fancy switch you found there.
Hey there,
That is a decent switch. I've used a few of these and a bunch of the R/G only versions. They're just so dang expensive. I use the TLC5947DAP for driving the LEDs and the CD74HC165M96 to read the switches. I have some code snippets I can lend you if you decide to go that route.
Marcus
found this on Sparkfun - what a great key but seems retired
https://www.sparkfun.com/products/retired/8493
of course you can just multiplex with a either I2C extender or SPI type 595 shift register. 32 * 3 colors could be made into a matrix 16 * 6 using either 3 * xx595 shift register or 16 + 8 I2C extender.
number of colors the depends on your PWM.
or use this for the 16 * sink:
http://www.maximintegrated.com/en/products/all-products/archive/MAX16809.html
http://www.ti.com/lit/ds/symlink/tlc5940.pdf
