Demo Board not working - Solved
blittled
I recently got a used Demo Board. When I plugged in the USB the leds flash but I get a "No Propeller found" error. Upon inspection of the board the surface of the leftmost regulator appears silver rather than black so I checked the 5V output and got 3.2V also the VDD output is 0V even when on. It appears that the leftmost regulator is the 5V regulator and not working correctly. Am I correct? Also what is the part number of the regulators. I'm about to order some parts from Digikey and I'll add them to the list. Thanks.
Most Propeller boards with USB connections can be powered from the USB but not the Demo Board.
Cool Beans! Glad you got it running. I can't imagine why that was there in the first place. Maybe to run an external supply?
Didn't even notice that on my Demo Board. It's always been in place.
