WS2811/WS2812 driver for the Propeller - Page 3 — Parallax Forums
13
    edited 2014-10-03 08:28
    After looking at JonnyMac's jm_ws2812.spin driver it looks like the only thing needed to make the driver for the WS2811 LEDs instead is to comment out the routine fix_colors which moves the color bytes for red and green.
    Robert
    edited 2014-10-03 08:30
    Robert
    All I did was add another parameter and a TJZ to skip over that code if the parameter is not set. The parameter gets set for swapping R and G.
  • JonnyMacJonnyMac Posts: 9,787
    edited 2014-10-03 10:16
    I've never seen WS2812 style LEDs that DIDN'T require the swap. In my WS2801 code, there is a swap parameter. I'll add that to my WS2812 code (later -- have to prep for Hacakday event).
    edited 2014-10-04 06:44
    I think I have Jon's single-shot update mode working in my C code but I'm having a bit of trouble with calls to ws2812_execute that are too close together. Can anyone see the problem? If I add a delay between the calls then things seem to work okay. First, I'll show some of the C++ code I've been playing with to support the single-shot driver.
    Here is my test program. It uses two animation classes: ws2812_FillWheelDim fills a color array with a rainbow of colors and rotates the rainbow on every update and ws2812_Chase does Jon's chase effect. In this program I'm using two AdaFruit LED devices, one 16 LED ring and an 8 LED strip. The ring is being driven by the ws2812_FillWheelDim animation (matching my Christmas ornament from last year) and the strip is being driven by the ws2812_Chase animation. Each device is on a different Propeller pin illustrating that more than one chain of LEDs can be managed by Jon's single-shot update mode.
    #include <propeller.h>
    #include "ws2812.h"
    #define LED_PIN     15
    #define LED_COUNT   16
    #define LED2_PIN    14
    #define LED2_COUNT  8
    uint32_t Chakras[] = {
        COLOR_RED,
        COLOR_ORANGE,
        COLOR_YELLOW,
        COLOR_GREEN,
        COLOR_BLUE,
        COLOR_INDIGO
    int Chackras_count = sizeof(Chakras) / sizeof(uint32_t);
    int main(void)
         int cog;
        // 16 LED ring
        uint32_t colors[LED_COUNT];
        ws2812_FillWheelDim wheel(colors, LED_COUNT, LED_COUNT+5, 128);
        // 8 LED strip
        uint32_t colors2[LED2_COUNT];
        ws2812_Chase chase(colors2, LED2_COUNT, Chakras, Chackras_count);
        // animation array
        ws2812_Animation *animations[] = {
            &wheel,
            &chase
        if ((cog = ws2812_init()) < 0)
            return 1;
        for (;;) {
            for (unsigned int i = 0; i < sizeof(animations) / sizeof(animations[0]); ++i)
                animations[i]->update();
            ws2812_execute(LED_PIN, colors, LED_COUNT);
            ws2812_pause(10); [COLOR="#FF0000"]// why is this needed?[/COLOR]
            ws2812_execute(LED2_PIN, colors2, LED2_COUNT);
            ws2812_pause(100);
        cogstop(cog);
        return 0;
    Here is the PASM code that is invoked when you call ws2812_execute(). I've also attached a .zip file containing all of the code including the C++ class definitions for ws2812_FillWheelDim and ws2812_Chase. These are in test.cpp which is a file I've been using to test a C++ animation interface.
    '' Modified for use with PropGCC by David Betz
    ''  Derived from:
    ''   File....... jm_ws2812.spin
    ''   Purpose.... 800kHz driver for WS2812 LEDs
    ''   Author..... Jon "JonnyMac" McPhalen
    ''               Copyright (c) 2013 Jon McPhalen
        // parameter structure
        typedef struct {
            uint32_t pin;
            uint32_t *colors;
            volatile uint32_t count;
        } ws2812_params;
        // driver header structure
        typedef struct {
            uint32_t    jmp_inst;
            uint32_t    resettix;
            uint32_t    bit0hi;
            uint32_t    bit0lo;
            uint32_t    bit1hi;
            uint32_t    bit1lo;
            uint32_t    swaprg;
        } ws2812_hdr;
    pub driver
      return @ws2812
    dat
                            org     0
    ws2812                  jmp     #get_cmd
    resettix                long    0                               ' frame reset timing
    bit0hi                  long    0                               ' bit0 high timing
    bit0lo                  long    0                               ' bit0 low timing
    bit1hi                  long    0                               ' bit1 high timing
    bit1lo                  long    0                               ' bit1 low timing
    swaprg                  long    0                               ' swap r and g
    clear_cmd               mov     t1, #0                          ' clear last command
                            wrlong  t1, par
    get_cmd                 rdlong  t1, par                 wz      ' look for packed command
            if_z            jmp     #get_cmd
                            mov     t2, t1                          ' get pin
                            and     t2, #$1F                        ' isolate
                            mov     txmask, #1                      ' create mask for tx
                            shl     txmask, t2
                            andn    outa, txmask                    ' set to output low
                            or      dira, txmask
                            mov     ledcount, t1                    ' get count
                            shr     ledcount, #8                    ' isolate
                            and     ledcount, #$FF
                            add     ledcount, #1                    ' update (1 to 256 leds)
                            mov     hubpntr, t1                     ' get hub address
                            shr     hubpntr, #16                    ' isolate
    temporary               mov     t1, #0                          ' clear last command
                            wrlong  t1, par
    rgbmain                 mov     bittimer, resettix              ' set reset timing
                            add     bittimer, cnt                   ' sync timer
                            waitcnt bittimer, #0                    ' let timer expire
                            mov     addr, hubpntr                   ' point to rgbbuf[0]
                            mov     nleds, ledcount                 ' set # active leds
    frame_loop              rdlong  colorbits, addr                 ' read a channel
                            add     addr, #4                        ' point to next
    ' Correct placement of color bytes for WS2812
    '   $RR_GG_BB --> $GG_RR_BB
    fix_colors              tjz     swaprg, #shift_out              ' skip if R and G don't need swapping
                            mov     t1, colorbits                   ' copy for red
                            mov     t2, colorbits                   ' copy for green
                            and     colorbits, HX_0000FF            ' isolate blue
                            shr     t1, #8                          ' fix red pos (byte1)
                            and     t1, HX_00FF00                   ' isolate red
                            or      colorbits, t1                   ' add red back in
                            shl     t2, #8                          ' fix green pos (byte2)
                            and     t2, HX_FF0000                   ' isolate green
                            or      colorbits, t2                   ' add green back in
    ' Shifts long in colorbits to WS2812 chain
    '  WS2812 Timing
    '  0   &#61569;&#61570;&#61574;&#61573;&#61569;&#61569;&#61569;&#61570;    0.35us / 0.80us
    '  1   &#61569;&#61570;&#61574;&#61574;&#61574;&#61573;&#61569;&#61569;&#61570;   0.70us / 0.60us
    '  WS2812B Timing
    '  0   &#61569;&#61570;&#61574;&#61573;&#61569;&#61569;&#61569;&#61570;    0.35us / 0.90us
    '  1   &#61569;&#61570;&#61574;&#61574;&#61574;&#61573;&#61569;&#61570;    0.90us / 0.35us
    '  At least 50us (reset) between frames
    shift_out               shl     colorbits, #8                   ' left-justify bits
                            mov     nbits, #24                      ' shift 24 bits (3 x 8)
    :loop                   rcl     colorbits, #1           wc      ' msb --> C
            if_c            mov     bittimer, bit1hi                ' set bit timing
            if_nc           mov     bittimer, bit0hi
                            or      outa, txmask                    ' tx line 1
                            add     bittimer, cnt                   ' sync bit timer
            if_c            waitcnt bittimer, bit1lo
            if_nc           waitcnt bittimer, bit0lo
                            andn    outa, txmask                    ' tx line 0
                            waitcnt bittimer, #0                    ' hold while low
                            djnz    nbits, #:loop                   ' next bit
                            djnz    nleds, #frame_loop              ' done with all leds?
                            jmp     #clear_cmd                      ' get ready for next command
    HX_0000FF               long    $0000FF                         ' byte masks
    HX_00FF00               long    $00FF00
    HX_FF0000               long    $FF0000
    hubpntr                 res     1                               ' pointer to rgb array
    ledcount                res     1                               ' # of rgb leds in chain
    txmask                  res     1                               ' mask for tx output
    bittimer                res     1                               ' timer for reset/bit
    addr                    res     1                               ' address of current rgb bit
    nleds                   res     1                               ' # of channels to process
    colorbits               res     1                               ' rgb for current channel
    nbits                   res     1                               ' # of bits to process
    t1                      res     1                               ' work vars
    t2                      res     1
                            fit     496
      Terms of Use: MIT License
      Permission is hereby granted, free of charge, to any person obtaining a copy of this
      software and associated documentation files (the "Software"), to deal in the Software
      without restriction, including without limitation the rights to use, copy, modify,
      merge, publish, distribute, sublicense, and/or sell copies of the Software, and to
      permit persons to whom the Software is furnished to do so, subject to the following
      conditions:
      The above copyright notice and this permission notice shall be included in all copies
      or substantial portions of the Software.
      THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED,
      INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A
      PARTICULAR PURPOSE AND NON-INFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
      HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF
      CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE
      OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
    ws2812.zip
    edited 2014-10-04 07:56
    Here's a not-very-good video of my LED ring and strip test program.
    [video=youtube_share;OmJZKRz4uGk]
    edited 2014-10-04 15:30
    I figured out why I needed the additional delay. I had inadvertently left some debugging code in my version of JonnyMac's driver. Here is a working version of the driver that actually matches Jon's code better as well.
    ''  Derived from:
        typedef struct {
            uint32_t pin;
            uint32_t *colors;
        } ws2812_params;
        typedef struct {
            uint32_t    jmp_inst;
            uint32_t    resettix;
            uint32_t    bit0hi;
            uint32_t    bit0lo;
            uint32_t    bit1hi;
            uint32_t    bit1lo;
            uint32_t    swaprg;
        } ws2812_hdr;
    pub driver
      return @ws2812
    dat
                            org     0
    ws2812                  jmp     #get_cmd
    reset_delay             mov     bittimer, resettix              ' set reset timing
                            wrlong  t1, par
            if_z            jmp     #get_cmd
                            shl     txmask, t2
                            or      dira, txmask
                            and     ledcount, #$FF
    '  WS2812 Timing
    '  WS2812B Timing
                            jmp     #reset_delay                    ' get ready for next command
    t2                      res     1
                            fit     496
      conditions:
    edited 2014-10-05 16:22
    I'm glad you got it all sorted out. I just finished mounting a bunch of the WS2811 5mm LEDs in metal holders. It seems that many places stopped carrying the LED holders to I tried some of the imported ones on ebay. I wasn't really thrilled about those since they are smaller and the finish isn't as nice. I may end up using them on another project. The best ones I could still find came from Radio Shack of all places. They run about $1 each for the holders but they are well made and the finish is great. They are the same physical size as some early ones that I wanted to replace. The trick was to use a small pick to poke two extra holes in the rubber piece that locks the LED in place. The results were exactly what I wanted.
    Robert
    1024 x 808 - 160K
    1024 x 801 - 85K
    edited 2014-10-05 16:55
    Robert
    I've started playing with my WS2811 5mm LEDs from AdaFruit and I can't get them to do anything except glow blue.
    edited 2014-10-05 17:33
    Hello David,
    I thought you mentioned that it was working now. Attached it a picture of how I was testing them, I had five WS2811 LEDs and then two WS2812B LEDs all in the same chain. If you are just using the C code then it may be worth trying the latest SPIN object in the OBEX to see if it behaves the same. At least that will help determine if there is an odd issue with the LEDs/wiring or something that needs to be adjusted in the C version of the driver.
    Robert
    1024 x 618 - 102K
    edited 2014-10-05 17:38
    Hello David,
    Robert
    The driver works with both an AdaFruit LED ring and an LED strip so I think it's okay. The PASM code is pretty much identical to what is in JonnyMac's driver. My wiring looks pretty much like yours except that I'm using the breadboard on an ActivityBoard so I don't have power rails. I daisy chained the power for each of the LEDs and connected the one at the end of the string to the power headers on the ActivityBoard. I currently have only one LED connected to try to diagnose this problem. Here is a picture.
    800 x 600 - 186K
    edited 2014-10-05 17:54
    David Betz wrote: »
    Are you LEDs water clear or diffused? The ones I picked up from Pololu are diffused white when off. I wonder if they are the same and how many variations are out there.
    With all those short jumper wires there are a lot of extra connections. Maybe one of the wires is loose for an open connection.
    Robert
    edited 2014-10-05 17:58
    Robert
    They are clear. In fact, they are of a type that has since been discontinued by AdaFruit. I thought the wires looked overly complex myself so I removed all of the jumpers and wired everything directly to power and ground. The LED still glows blue with no DIN signal applied. I have 10 LEDs. I guess I could try some of the others.
    edited 2014-10-05 18:29
    David Betz wrote: »
    I thought I read somewhere that the older versions of these style LEDs were limited to a 400Khz refresh. I may be wrong about that but if that is the case then maybe the current driver you have is sending the data too fast for it.
    Robert
    edited 2014-10-05 18:34
    Robert
    That could be but these LEDs glow blue even with no data being sent to them at all. They should be off in that case shouldn't they?
    edited 2014-10-05 18:41
    David Betz wrote: »
    You would think that but I saw one of mine turn blue when it wasn't getting data properly. Maybe that is what some of them do if they receive invalid data. I'm not sure how the DIN would react if left disconnected on a breadboard. Do they have any sort of weak pull-up/pull-down resistor on the DIN or act more like CMOS with an input not connected. It sounds like there may be something odd about the particular batch of LEDs that you have.
    Robert
    edited 2014-10-05 18:54
    Robert
    Actually, DIN is connected to ground through a 2.2K resistor. This was suggested to me by someone on the AdaFruit forum for attempting to diagnose this problem. I have 10 LEDs and have tried 6 of them and they all exhibit this behavior. I guess this could be the result of two different problems. Maybe these particular LEDs have an idle state of blue and they also require more than 3.3v on their DIN pin to successfully transmit data. Maybe I should try a level converter between the Propeller pin and the LED DIN? Actually, the LEDs aren't very useful to me if they don't have "off" as their idle state when receiving no data because I don't want to constantly drive the DIN pin just to keep them off.
    edited 2014-10-05 20:01
    David Betz wrote: »
    I just read the following on the Pololu site which sells similar LEDs:
    "After power is applied to these LEDs, they will emit bright blue light until the first color command is received."
    That is exactly what mine are doing. I guess it could be that the 3.3v output on the Propeller pin is not sufficient to drive DIN on these LEDs and hence the color never changes from the default color. I have an ATtiny85 5V module I may try tomorrow to verify this. If that works, I guess I need a level shifter to use these on a Propeller.
  • TubularTubular Posts: 4,771
    edited 2014-10-05 21:16
    Try the "other" frequency too. Ie if you think your leds are 800kHz and its not working, try 400kHz. Or vice versa
    You can also run WS2812's successfully from 3v3, its just the green and blue won't be as bright, but for test purposes it'll help nail whats going on
    edited 2014-10-06 01:48
    Tubular wrote: »
    You can also run them from +5V but through a suitable diode which will drop around 0.7V or so and this is enough margin for 3.3V to be regarded as a valid high level input. I also use this trick in designs when it is not really that important that the driver has exactly +5V, just that it runs from the +5V supply rather than the 3.3V logic supply.
    edited 2014-10-06 06:39
    Do you have any 74HC14 chips on hand? I've used two gates from one (back to back) as a buffer from the 3.3V propeller to a 5V device. The 74HC14 is powered by the 5V supply. You also need to ties the other 4 unused inputs on that chip either high or low unless you are using them for something else. Maybe worth trying if you have one.
    Robert
    edited 2014-10-06 06:44
    Robert
    I don't think I have one. I'll have to order a few I guess. Thanks for the suggestion.
    edited 2014-10-06 08:23
    Robert
    I have one of these: https://www.adafruit.com/products/757
    Do you think that would work?
    edited 2014-10-06 09:30
    I don't think you want to use those, David; they are bi-directional, open-collector/drain interfaces that are best for I2C and half-duplex serial coms (all EFX-TEK boards use that circuit; I've talked about it in my N&V columns many times).
    My favorite (hence recommended) little booster for 3.3v-to-5.0v is the TC4427. It's actually a MOSFET driver with very stiff output so it works very well against long cables. I've used it with WS2801s (Wes Borland costume), WS2812s (Cylon dress for Jinyo), and even a focus/zoom app for a client that uses servos. It comes in breadboard-friendly DIP form, too.
    -- http://www.digikey.com/product-detail/en/TC4427CPA/TC4427CPA-ND/115309
    Vih for the part is 2.4v which makes it very compatible with the Propeller. The output voltage is set by what you connect to the Vdd pin -- which can be up to 18V; obviously, this should be connected to a 5V supply for WS281x apps.
  • BTXBTX Posts: 674
    edited 2014-10-06 09:39
    David, later but sure.
    I was playing with that leds strips, it's very easy to controll them, (anyway you've enough info yet).
    Also try a code with: netDrv : "etherCog-enc28j60", sock : "etherCog-udp-socket", and bufq : "etherCog-buffer-queue" code, and you'll be able to control them in Art-Net way, using the free Jinx software, or you can use also the Madrix software to test them free.
    Good luck !!
    edited 2014-10-06 10:00
    JonnyMac wrote: »
    Thanks for the suggestion. I just ordered a few.
    edited 2014-10-06 10:05
    Put a 10K pull-down (one side connected to pin, other side connected to ground) on the WS281x control pin that goes into the TC4427; this will keep the line in a 0 state when the Propeller is booting.
    645 x 549 - 39K
    edited 2014-10-06 10:25
    JonnyMac wrote: »
    Jon,
    One more question. Are you saying that this module won't work or just that it's overkill since it is bi-directional? Can I use it until my TC4427 chips arrive?
    David
    edited 2014-10-06 10:38
    It may work, but no better than if you changed the WS2812 driver to open-drain output with a 10K pull-up on the signal line. The output of the circuit is somewhat "soft." Give it a try, I could be wrong. I would never use that with WS2812s in a client project though -- the TC4427 is designed to drive against capacitive loads, so it works really well in this app (and many others, it's one of my favorite parts).
    I've attached my variation of the circuit you want to use.
    Notes:
    -- if the input is floating, the output will be high (this may cause problems on WS28xx lines during reset
    -- I use stiffer pull-ups than the Adafruit board
    You're probably wondering how this circuit differs from the TC4427
    -- default state for FET circuit is high (better for serial coms)
    -- default state for TC4427 circuit is low (better for WS28xx LEDs)
    -- the FET circuit can pull to ground, but high goes through pull-up on output side
    -- TC4427 uses totem-pole FET outputs to drive pins directly to Vdd or ground (up to 1.5A peak)
    1024 x 447 - 28K
    edited 2014-10-06 10:52
    JonnyMac wrote: »
    Thanks for the schematic!
  • T ChapT Chap Posts: 4,260
    edited 2014-10-28 08:29
    Thanks Jon for the hard work, got in a 8x8 array and this was very simple to make run.
    640 x 480 - 143K
