Ohhh.......... Ahhh.......... Now I am really excited!
idbruce
I just received a 50 piece PCB drill bet set. All of them with 1/8" shank and 1-1/2" long. I have been waiting a very long time for these.
More appealing than a Sports Illustrated Swimsuit Issue!!!!!!!!!!!!!!!!!!!!!!!
I only have one question: What is the easiest way to manipulate the collars?
Seriously, though, I'm not sure what you mean by "collars" in the other context. Did you mean "collets?"
As seen in the photo below, I am referring to all the different color depth collars.
EDIT: They are really kind of stubborn. I have a pinion gear puller that might work well for this.
Now, I can understand the "50 piece PCB drill bet set. All of them with 1/8" shank and 1-1/2" long."
I can also appreciate the "More appealing than a Sports Illustrated Swimsuit!!!!!!!!!!!!!!!!!!!!!!!"
Being the mechanical nerd that you and many of us are.
But, like Phil, I don't understand the question "What is the easiest way to manipulate the collars?"
I am referring to the adjustment or removal of the depth collars
If I am not mistaken, the depth ring or collar is utilized to set appropriate placement within the drill chuck. Then the depth stop of the drill press can be used consistently.
For a more complete discussion of the depth collars, refer to the folloing link:
http://www.thinktink.com/stack/volumes/voliii/reference/depth_setting_rings.htm
Drill a 5/32" hole 1 3/4" deep into a solid block of wood. Then use an arbor press to push it through. Also a bench vise and claw hammer works -- the metal on the shank seems to be less brittle. Just like pulling a nail, and I only broke a couple.
Dom.
No, they are also perfectly adaptable to a common drill press for the same purpose.
That is the problem Phil. They are in my way. I wish they weren't, considering the easy to read size markings, but they are.
The block of wood is a good idea. I assume the drill press could push them out or adjust them, as compared to an arbor press.
However, I would not use a "common" drill press to drill holes with these very brittle bits, unless you've spent about $300- $400 for a good chuck:
Otherwise, you're just going to be breaking bits left and right. Moreover, such bits are designed to be run at very high RPMs -- not those typical of a regular drill press. Nonetheless, they will work at lower RPMs if you keep the feed rate low enough.
Somehow this reminds me of that girl who wore blue candy-stripes appearing in Popular Mechanics years and years ago last century.
I was just using the words "common drill press" as an example to explain that a CNC machine is not necessary for the collars to be useful.
The bearings are so worn in my drill press, I am surprised that black oxide bits are not snapping on a regular basis.
