P2 and HS USB, new FT4222H — Parallax Forums
jmgjmg Posts: 15,199
edited 2014-10-03 18:29 in Propeller 2
I see FTDI have a new High Speed USB member
http://www.ftdichip.com/Products/ICs/FT4222H.html
This claims i2c to 3.4Mb/s and QSPI to 28MB/s, and QFN32 and under $2 in 100+
That makes having QuadSPI support in HW in P2, more important, as it gives a low cost method to get decent link speeds. Hopefully, QuadSPI is still in the SmartPin feature list.
Other comments :
The FT4222H is unclear on 5V tolerant ? the main bullets and MAX do NOT mention it, but the Ioz figures give 10uA and Vin = 5.5V or 0 - their other FT232H devices are 5V tolerant.
The i2c seems to use different pins, so it may support SPI and i2c, dual use (but perhaps not like a dual UART ?)
There is no mention of JTAG support, which just needs modest extensions to SPI.
(variable data length, and sync control of TDO and TMS ( MOSI / SSn ) )
Seems surprising FTDI would miss supporting JTAG on a new peripheral device ?
Addit: After asking FTDI, I can add some clarifies
* Part is NOT 5V tolerant (which is sure to bite many,given their other H parts are)
* SPI clock choices are coarse (1/2^N) and QuadSPI sustained speed is limited by the total system design to 28.1Mbps @ 20MHz, so ~ 25.6% of Clock bandwidth, and 5.85% of the peak USB bandwidth.
ie better than FS USB, but poor for any HS USB chip.
* JTAG is NOT supported in HW, and the GPIO calls are bit-level
No numbers yet on possible SW only speeds, but they would be low, and GPIO is not mappable to SPI pins (and overlays i2c pins ).
The price and package still makes this an interesting part, shame about the missing details.
FT4222H is still a very good match for P2, as those details impact P2 less than general use. (A FT4222H P2 design can probably use a single crystal.)
  • oscar4oscar4 Posts: 9
    edited 2014-10-01 10:59
    Thanks for the info, jmg
    FTDI already had USB high speed support on some of their other ICs, it seems - 313H, 323H, etc
    Are any of these ICs used on prop boards or is there any USB HS support on any current production prop board, at the moment?
  • jmgjmg Posts: 15,199
    edited 2014-10-01 11:39
    oscar4 wrote: »
    On standard P1 boards, not that I know of.
    I know the the Lattice CPLD boards use FT2232H, which is a good choice as it can do JTAG and UART, but the FT232H/FT2232H are larger and more expensive than the new FT4222H, which seems to be the lowest price for USB HS.
  • tonyp12tonyp12 Posts: 1,951
    edited 2014-10-01 12:02
    If you want JTAG and a mix of uart/i2c/spi
    Two-channel configurable SPI interfaces Master/slave up to 3 MHz (but looks like no quadspi)
    http://www.mouser.com/ProductDetail/Cypress-Semiconductor/CY7C65215-32LTXI/?qs=sGAEpiMZZMsOYvreY40OSr0Sq2DnL0xZ
    edited 2014-10-01 13:08
    These QFN packages are not very DIY friendly
    Has anybody used one of these FTDI 4232 USB hi-speed hubs as a front end to a prop board?
    edited 2014-10-01 15:05
    tonyp12 wrote: »
    Interesting part, but not High Speed USB - and JTAG is 400KHz, which will be rather too slow for FPGA updates.
    Another SPI part, that looks interesting is the new Freescale MC33664 Transceiver - targets isolated links over Battery Stacks.
    2.0 Mbps isolated network communication rate
    Dual SPI architecture for message confirmation
    Robust conducted and radiated immunity with wake-up
    3.3 V and 5.0 V compatible logic thresholds
    Engineered for 5.0 meter, 15 node system
    Low sleep mode current with automatic bus wake-up
    Ultra-low radiated emissions
    Comes in SO-150mil package, so looks cheap, no price or full data yet.
    There are plenty of P2 ( & P1) apps where 2.0 Mbps isolated network communication would be useful.
